OpenPose人体姿态识别
HWCloudAI 发表于 2022/12/01 11:21:50 2022/12/01
【摘要】 OpenPose人体姿态识别OpenPose人体姿态识别项目是美国卡耐基梅隆大学(CMU)基于卷积神经网络和监督学习并以caffe为框架开发的开源库。可以实现人体动作、面部表情、手指运动等姿态估计。适用于单人和多人,具有极好的鲁棒性。是世界上首个基于深度学习的实时多人二维姿态估计应用,基于它的实例如雨后春笋般涌现。人体姿态估计技术在体育健身、动作采集、3D试衣、舆情监测等领域具有广阔的应用...
OpenPose人体姿态识别
OpenPose人体姿态识别项目是美国卡耐基梅隆大学(CMU)基于卷积神经网络和监督学习并以caffe为框架开发的开源库。可以实现人体动作、面部表情、手指运动等姿态估计。适用于单人和多人,具有极好的鲁棒性。是世界上首个基于深度学习的实时多人二维姿态估计应用,基于它的实例如雨后春笋般涌现。人体姿态估计技术在体育健身、动作采集、3D试衣、舆情监测等领域具有广阔的应用前景,人们更加熟悉的应用就是抖音尬舞机。
此案例使用的是PyTorch版本
下载代码和模型
!wget https://obs-aigallery-zc.obs.cn-north-4.myhuaweicloud.com/algorithm/openpose.zip
!unzip openpose.zip
检测人体图像
!pip install ffmpeg-python
!pip install imageio
import sys
sys.path.insert(0, './openpose/src/')
import cv2
import copy
import numpy as np
import model
import util
from body import Body
from hand import Hand
from glob import glob
import os
import argparse
import json
# video file processing setup
# from: https://stackoverflow.com/a/61927951
import subprocess
from pathlib import Path
from typing import NamedTuple
body_estimation = Body('./openpose/models/body_pose_model.pth')
hand_estimation = Hand('./openpose/models/hand_pose_model.pth')
test_image = './openpose/images/demo.jpg'
oriImg = cv2.imread(test_image)  # B,G,R order
candidate, subset = body_estimation(oriImg)
canvas = copy.deepcopy(oriImg)
canvas = util.draw_bodypose(canvas, candidate, subset)
# detect hand
hands_list = util.handDetect(candidate, subset, oriImg)
all_hand_peaks = []
for x, y, w, is_left in hands_list:
    # cv2.rectangle(canvas, (x, y), (x+w, y+w), (0, 255, 0), 2, lineType=cv2.LINE_AA)
    # cv2.putText(canvas, 'left' if is_left else 'right', (x, y), cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 0, 255), 2)
    # if is_left:
        # plt.imshow(oriImg[y:y+w, x:x+w, :][:, :, [2, 1, 0]])
        # plt.show()
    peaks = hand_estimation(oriImg[y:y+w, x:x+w, :])
    peaks[:, 0] = np.where(peaks[:, 0]==0, peaks[:, 0], peaks[:, 0]+x)
    peaks[:, 1] = np.where(peaks[:, 1]==0, peaks[:, 1], peaks[:, 1]+y)
    # else:
    #     peaks = hand_estimation(cv2.flip(oriImg[y:y+w, x:x+w, :], 1))
    #     peaks[:, 0] = np.where(peaks[:, 0]==0, peaks[:, 0], w-peaks[:, 0]-1+x)
    #     peaks[:, 1] = np.where(peaks[:, 1]==0, peaks[:, 1], peaks[:, 1]+y)
    #     print(peaks)
    all_hand_peaks.append(peaks)
canvas = util.draw_handpose(canvas, all_hand_peaks)
plt.imshow(canvas[:, :, [2, 1, 0]])
plt.axis('off')
plt.show()
检测人体视频
输入视频为’./openpose/images/play.mp4’,可替换成需要检测的
由于视频太长只处理了其中的10帧
输出gif图,路径output_file会打印
import imageio
class FFProbeResult(NamedTuple):
    return_code: int
    json: str
    error: str
def ffprobe(file_path) -> FFProbeResult:
    command_array = ["ffprobe",
                     "-v", "quiet",
                     "-print_format", "json",
                     "-show_format",
                     "-show_streams",
                     file_path]
    result = subprocess.run(command_array, stdout=subprocess.PIPE, stderr=subprocess.PIPE, universal_newlines=True)
    return FFProbeResult(return_code=result.returncode,
                         json=result.stdout,
                         error=result.stderr)
def process_frame(frame, body=True, hands=True):
    canvas = copy.deepcopy(frame)
    if body:
        candidate, subset = body_estimation(frame)
    if hands:
        hands_list = util.handDetect(candidate, subset, frame)
        all_hand_peaks = []
            peaks = hand_estimation(frame[y:y+w, x:x+w, :])
    return canvas
# writing video with ffmpeg because cv2 writer failed
# https://stackoverflow.com/questions/61036822/opencv-videowriter-produces-cant-find-starting-number-error
import ffmpeg
# open specified video
video_file = './openpose/images/play.mp4'
cap = cv2.VideoCapture(video_file)
# get video file info
ffprobe_result = ffprobe(video_file)
info = json.loads(ffprobe_result.json)
videoinfo = [i for i in info["streams"] if i["codec_type"] == "video"][0]
input_fps = videoinfo["avg_frame_rate"]
# input_fps = float(input_fps[0])/float(input_fps[1])
input_pix_fmt = videoinfo["pix_fmt"]
input_vcodec = videoinfo["codec_name"]
# define a writer object to write to a movidified file
output_file = ".".join(video_file.split(".")[:-1])+".processed.gif"
print(output_file)
buff=[]
count = 0
while(cap.isOpened()):
    ret, frame = cap.read()
    if frame is None or count>10:  # 修改这里可调节视频处理帧数
        break
    posed_frame = process_frame(frame, body=True,
                                       hands=True)
    buff.append(posed_frame)
    count += 1
gif=imageio.mimsave(output_file,buff,'GIF')
cap.release()
cv2.destroyAllWindows()
./openpose/images/play.processed.gif
