深入浅出Spring Boot接口
torchstar 发表于 2022/11/30 22:43:39 2022/11/30
【摘要】 深入浅出Spring Boot接口
统一返回格式
定义一个业务CODE枚举类
public enum ResultCodeEnum {
    SUCCESS(1, "成功"),
    //参数错误
    ILLEGAL_PARAMETER(10001, "非法参数");
    private Integer code;
    private String msg;
    ResultCodeEnum(Integer code, String msg) {
        this.code = code;
        this.msg = msg;
    public Integer getCode() {
        return code;
    public String getMsg() {
        return msg;
定义统一返回类
public class R<T> implements Serializable {
    private T data;
    private String msg;
    public static <T> R<T> ok(T data) {
        R<T> r = new R<>();
        r.setData(data);
        return r;
    public static <T> R<T> ok(ResultCodeEnum codeEnum, T data) {
        R<T> r = new R<>();
        r.setData(data);
        r.setCode(codeEnum.getCode());
        r.setMsg(codeEnum.getMsg());
        return r;
    public static <T> R<T> fail(Integer code, String msg) {
        R<T> r = new R<>();
        r.setCode(code);
        r.setMsg(msg);
        return r;
    public static <T> R<T> fail(ResultCodeEnum codeEnum) {
        R<T> r = new R<>();
        return r;
	//省略部分代码
这样每个接口都需要使用R.ok()包裹返回值,下面我们通过一些配置来实现自动包裹。
定义一个封装注解
@Retention(RetentionPolicy.RUNTIME)
@Target(ElementType.TYPE)
@Documented
public @interface Result {
ResponseBodyAdvice接口
Allows customizing the response after the execution of an @ResponseBody or a ResponseEntity controller method but before the body is written with an HttpMessageConverter.
这个接口作用在Controller返回结果之后和written with an HttpMessageConverter之前。
true if beforeBodyWrite should be invoked; false otherwise
重写supports方法 ,返回true调用beforeBodyWrite 。
    @Override
    public boolean supports(MethodParameter returnType, Class<? extends HttpMessageConverter<?>> converterType) {
        //方法所在class
        Class<?> methodClass = returnType.getContainingClass();
        //获取注解
        Result r = methodClass.getAnnotation(Result.class);
        //如果不存在不处理
        if (ObjectUtils.isEmpty(r)) {
            return false;
        //如果已经是R返回false,如果不是R返回true
        boolean assignableFrom = returnType.getParameterType().isAssignableFrom(R.class);
        return !assignableFrom;
当接口返回String类型报错如下
R cannot be cast to java.lang.String
	at org.springframework.http.converter.StringHttpMessageConverter.addDefaultHeaders
Invoked after an HttpMessageConverter is selected and just before its write method is invoked.
beforeBodyWrite 调用在HttpMessageConverter选择后和write 方法调用之前。
重写beforeBodyWrite方法
    @Override
    public Object beforeBodyWrite(Object body, MethodParameter returnType,
                                  MediaType selectedContentType,
                                  Class<? extends HttpMessageConverter<?>> selectedConverterType,
                                  ServerHttpRequest request,
                                  ServerHttpResponse response) {
        if (body instanceof String) {
            try {
                ObjectMapper objectMapper = new ObjectMapper();
                //修改返回类型
                response.getHeaders().add("Content-Type", MediaType.APPLICATION_JSON_VALUE);
                R<Object> r = R.ok(body);
                return objectMapper.writeValueAsString(r);
            } catch (JsonProcessingException e) {
                e.printStackTrace();
        return R.ok(body);
到这里我们就不需要使用R.ok来包裹返回类型了。
selectedContentType和selectedConverterType是选定的ContentType和ConverterType
打印一下这两个值
        logger.info("selectedContentType:" + selectedContentType);
        logger.info("selectedConverterType:" + selectedConverterType);
输出
//String
selectedConverterType:class org.springframework.http.converter.StringHttpMessageConverter
selectedContentType:text/html
//其他
selectedContentType:application/json
selectedConverterType:class org.springframework.http.converter.json.MappingJackson2HttpMessageConverter
那么谁调用的 beforeBodyWrite 这个方法呢 ?
beforeBodyWrite 调用过程
在方法内部打一个断点定位到RequestResponseBodyAdviceChain,processBody中141行调用beforeBodyWrite
				body = ((ResponseBodyAdvice<T>) advice).beforeBodyWrite((T) body, returnType,
						contentType, converterType, request, response);
beforeBodyWrite中116行调用processBody
		return processBody(body, returnType, contentType, converterType, request, response);
AbstractMessageConverterMethodProcessor中268行调用了beforeBodyWrite
					body = getAdvice().beforeBodyWrite(body, returnType, selectedMediaType,
							(Class<? extends HttpMessageConverter<?>>) converter.getClass(),
							inputMessage, outputMessage);
全局异常处理
迭代到这里,只需要在类上加入@Result注解就可以实现接口的封装处理,那么异常的情况呢?
在ResultBodyAdvice中加入这一段代码,通过code和msg来统一处理异常。
    @ExceptionHandler(Exception.class)
    public R runtimeExceptionHandle(Throwable e) {
        if (RuntimeException.class.equals(e.getClass())) {
            return R.fail(ResultCodeEnum.SERVER_ERROR);
        } else if (IllegalArgumentException.class.equals(e.getClass())) {
            return R.fail(ResultCodeEnum.ILLEGAL_PARAMETER);
            return R.fail(3000, "其他错误");
参数校验
目的:消灭 if 条件判断。
约定:Get请求不传body,Post请求通过body传参。RequestParam绑定url参数,RequestBody 绑定body体中参数。
@RequestParam("id") Integer id
@RequestBody String name
@Validated
添加依赖
        <dependency>
            <artifactId>spring-boot-starter-validation</artifactId>
        </dependency>
public class Hello6VO {
    @Min(value = 10, message = "最小值10")
    private Integer id;
    @Min(value = 5, message = "最小值5")
    private Integer id2;
    @GetMapping("hello6")
    public void hello6(@Validated Hello6VO vo) {
        System.out.println(vo.getId());
    @PostMapping("hello7")
    public void hello7(@RequestBody @Validated  Hello6VO vo) {
捕获失败异常
else if (e instanceof org.springframework.validation.BindException) {
            BindException exception = (org.springframework.validation.BindException) e;
            //优先处理字段错误
            List<FieldError> fieldErrorsList = exception.getBindingResult().getFieldErrors();
            List<String> fieldErrorMessageList = new ArrayList<>(fieldErrorsList.size());
            //获取默认提示信息列表
            for (FieldError fieldError : fieldErrorsList) {
                //字段名
                String field = fieldError.getField();
                //提示信息
                String message = fieldError.getDefaultMessage();
                //拒绝的值
                Object rejectedValue = fieldError.getRejectedValue();
                String str = "字段:" + field + " 提示信息:" + message + " 拒绝的值:" + rejectedValue;
                fieldErrorMessageList.add(str);
            return R.fail(ResultCodeEnum.VALIDATE_FAILED.getCode(), fieldErrorMessageList.toString());
输出
  "data": null,
  "code": 1002,
  "msg": "[字段:id 提示信息:最小值10 拒绝的值:1, 字段:id2 提示信息:最小值5 拒绝的值:2]"
