关于Python匿名函数的5道练习题
python教程 发表于 2022/11/29 19:37:08 2022/11/29
【摘要】 1.下面程序的输出结果是:d = lambda p:p*2t = lambda p:p*3x = 2x = d(x)x = t(x)x = d(x)print(x)# 242.现有两元组((‘a’),(‘b’)),((‘c’),(‘d’)),请使用python中匿名函数生成列表[{‘a’:‘c’},{‘b’:‘d’}]ret = max(dic,key=lambda k:dic[k])3.以...
1.下面程序的输出结果是:
d = lambda p:p*2
t = lambda p:p*3
x = 2
x = d(x)
x = t(x)
x = d(x)
print(x)# 24
3.以下代码的输出是什么?请给出答案并解释。
def multipliers():
    return [lambda x:i*x for i in range(4)]
print([m(2) for m in multipliers()])
请修改multipliers的定义来产生期望的结果。
[6, 6, 6, 6]
4.用map来处理字符串列表,把列表中所有人都变成sb,比方alex_sb
name=['alex','wupeiqi','yuanhao','nezha']
# def func(x):
#     return x+'_sb'
ret = list(map(lambda x:x+'_sb',name))
print(ret)
5: 用filter函数处理数字列表,将列表中所有的偶数筛选出来
num = [1,3,5,6,7,8]
num = [1,3,5,6,7,8]
print(list(filter(lambda x:x%2==0,num)))
