【Oracle客户端】PLSQL Developer 15 (64 bit)最新版安装使用教程(亲测)【Oracle客户端】PL
xcc-2022 发表于 2022/11/28 18:53:43 2022/11/28
【摘要】 @[toc] PLSQL Developer 15 和下载instantclient-basic-windows.x64-21.7.0.0.0dbru都在里面百度网盘下载链接:PLSQL Developer 15 (64 bit)+instantclient-basic-windows.x64-21.7.0.0.0dbru提取码:nfx5 我的信息数据库用户为xccip是192.168.22...
@[toc]
提取码:nfx5
我的信息
image-20221106072013084
数据库用户为xcc
image-20221106072046226
ip是192.168.220.133
序列号
  product code : ke4tv8t5jtxz493kl8s2nn3t6xgngcmgf3
       serial Number: 264452
       password: xs374ca
或者也可用下面这个
       product code: 4vkjwhfeh3ufnqnmpr9brvcuyujrx3n3le
       serial number: 226959
       password: xs374ca
image-20221106071831902
环境变量
1.乱码解决
image-20221106070159794
NLS_LANG
SIMPLIFIED CHINESE_CHINA.ZHS16GBK
2.数据库实例
image-20221106070353016
ORACLE_HOME
D:\edge\instantclient-basic-windows.x64-21.7.0.0.0dbru\instantclient_21_7
3.tnsnames.ora
image-20221106070445289
TNS_ADMIN
D:\edge\instantclient-basic-windows.x64-21.7.0.0.0dbru\instantclient_21_7\network\admin
image-20221106071743476
ORCL =
(DESCRIPTION =
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = TCP)(HOST = 服务器ip)(PORT = 1521))
    (CONNECT_DATA =
      (SERVICE_NAME = ORCL)
出现以下ORCL就说明,文本内容没错,环境变量也没错
image-20221106072233883
尝试连接确定,连接为Normal,如果出现问题,说明你路径出错了,可以在不登录情况下进入到软件中设置连接目录,需同步
软件内部
image-20221106070646316
把下面两个路径添加好
image-20221106070832017
TNS名称
ORCL =
(DESCRIPTION =
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.220.133)(PORT = 1521))
    (CONNECT_DATA =
image-20221106071010377
image-20221106071050432
如果觉得难,可以选择Navical Premium,有教程说明,只需一键下载就可以了
image-20221106072748301
Navical Premium下载
提取码:2zpx
image-20221106073740775
image-20221106073649055
评论(0
