解决方案:Springboot+Vue3+Mybatis+Axios 前后端分离项目中 遇见的若干报错和踩坑避坑(一)
中杯可乐多加冰 发表于 2022/11/28 17:09:25 2022/11/28
【摘要】 @TOC missing script:serve报错问题:npm ERR! missing script: servenpm ERR! A complete log of this run can be found in:npm ERR! C:\Users.........问题原因:这个错误一般是忘记进入项目目录里面而导致的。解决方案:只需要先 cd 切换到创建的项目的目录里面再使...
@TOC
问题:
问题原因:
解决方案:
只需要先 cd 切换到创建的项目的目录里面再使用npm run
serve,否则就会报错
跨域限制:CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
问题:使用Axios无法成功跨域
Access to XMLHttpRequest at 'http://localhost:8080/api' from origin 'http://localhost:8088' has been blocked by CORS policy:
No 'Access-Control-Allow-Origin' header is present on the requested resource.
问题原因:proxy代理没配置好,或者springboot端的接口对应不上。
解决方案:1、检查vue.config.js
module.exports = {
  devServer: { // 配置跨域代理
    host: 'localhost',
    port: '8088', //vue程序端口换成8088,避免与Spring Boot项目端口冲突
    https: false,
    open: true,
    proxy: {
      '/api': { // 匹配所有以 '/api'开头的请求路径
        target: 'http://localhost:8080', // 代理目标的基础路径
        changeOrigin: true, // 支持跨域
        pathRewrite: { // 重写路径: 去掉路径中开头的'/api'
          '^/api': ''
2、检查axios请求:
axios.get('http://localhost:8080/api/connect').then(function(response) {
            if (response.data) {
              console.log(response.data)
          }).catch(function(error){
            console.log(error);
          console.log("response done!")
3、检查后台代码,在后台controller加上@CrossOrigin注解
@RestController
@CrossOrigin
public class VueTest {
    @GetMapping("/api/connect")
    public String hivue(){
        System.out.println("vue connect success!");
        //System.out.println(mail);
        //System.out.println(password);
        return "regist successs";
this.axios is not a function
问题:this.axios is not a function或者this.$axios is not a function
解决方案:Vue抛弃了this的概念,不要再用this.
运行项目失败 显示:npm ERR! code ELIFECYCLE errno 1 …@0.1.0 serve: vue-cli-service serve
问题:
code ELIFECYCLE
npm ERR! errno 1
npm ERR! usermana@0.1.0 serve: `vue-cli-service serve`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the usermana@0.1.0 serve script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
问题原因:可能是在某次关闭项目时出错,是node_modules丢失了部分文件
解决方案:删除node_modules,重新配置和安装依赖包
首先删除node_modules,然后强制清除缓存,然后重新安装
rm package-lock.json
npm cache clear --force
npm install
