基于 First Order Model 的 damedane/unravel 教程
HWCloudAI 发表于 2022/11/25 12:05:17 2022/11/25
【摘要】 基于 First Order Model 的 damedane/unravel 教程使用方法:点击上方菜单,选择 Run(运行) - Run All Cells(运行所有)如果需要修改输入视频和音频的名称,修改其中的 source_image_name 和 source_video_name 变量,并再运行之后的所有代码块使用的是Pytorch1.4环境 准备环境mox.file.copy...
使用的是Pytorch1.4环境
准备环境
mox.file.copy_parallel('obs://obs-aigallery-zc/clf/code/damedane.zip','damedane.zip')
! unzip damedane.zip
!ls -lah
pip install imageio-ffmpeg ffmpeg-python
import os
os.chdir('damedane')
import imageio
import numpy as np
import matplotlib.animation as animation
from skimage.transform import resize
from IPython.display import HTML
import warnings
warnings.filterwarnings("ignore")
# 下面修改输入图片的文件名
source_image_name = 'import.png'
# 下面修改输入视频的文件名
source_video_name = '蚂蚁呀嘿.mp4'
source_image = imageio.imread(source_image_name)
driving_video = imageio.get_reader(source_video_name)
# 调整图片和视频分辨率为 256x256
source_image = resize(source_image, (256, 256))[..., :3]
driving_video = [resize(frame, (256, 256))[..., :3] for frame in driving_video]
def display(source, driving, generated=None):
    fig = plt.figure(figsize=(8 + 4 * (generated is not None), 6))
    ims = []
    for i in range(len(driving)):
        cols = [source]
        cols.append(driving[i])
        if generated is not None:
            cols.append(generated[i])
        im = plt.imshow(np.concatenate(cols, axis=1), animated=True)
        plt.axis('off')
        ims.append([im])
    ani = animation.ArtistAnimation(fig, ims, interval=50, repeat_delay=1000)
    plt.close()
    return ani
HTML(display(source_image, driving_video).to_html5_video())
import ffmpeg
# 合并音频 + 视频
video = ffmpeg.input('export-no-audio.mp4')
audio = ffmpeg.input(source_video_name)
ffmpeg.concat(video, audio, v=1, a=1).output('export.mp4').overwrite_output().run()
