Spring ApplicationListener
【摘要】 《读尽源码 第二十八篇》
demo
package com.huifer.source.spring.applicationListener;
import org.springframework.context.ApplicationEvent;
import org.springframework.context.ApplicationListener;
public class DemoApplicationListener implements ApplicationListener {
@Override
public void onApplicationEvent(ApplicationEvent event) {
System.out.println("com.huifer.source.spring.applicationListener.DemoApplicationListener.onApplicationEvent");
Copy to clipboardErrorCopied
<beans xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://www.springframework.org/schema/beans"
xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd">
<bean id="demoApplicationListener" class="com.huifer.source.spring.applicationListener.DemoApplicationListener"/>
</beans>Copy to clipboardErrorCopied
public class ListenerSourceCode {
ApplicationContext context = new ClassPathXmlApplicationContext("Listener-demo.xml");
}Copy to clipboardErrorCopied
初始化入口
- org.springframework.context.support.AbstractApplicationContext.refresh中的initApplicationEventMulticaster方法
protected void initApplicationEventMulticaster() {
ConfigurableListableBeanFactory beanFactory = getBeanFactory();
// 判断是否存在名字applicationEventMulticaster的bean
if (beanFactory.containsLocalBean(APPLICATION_EVENT_MULTICASTER_BEAN_NAME)) {
this.applicationEventMulticaster =
beanFactory.getBean(APPLICATION_EVENT_MULTICASTER_BEAN_NAME, ApplicationEventMulticaster.class);
if (logger.isTraceEnabled()) {
logger.trace("Using ApplicationEventMulticaster [" + this.applicationEventMulticaster + "]");
else {
// 创建一个
this.applicationEventMulticaster = new SimpleApplicationEventMulticaster(beanFactory);
beanFactory.registerSingleton(APPLICATION_EVENT_MULTICASTER_BEAN_NAME, this.applicationEventMulticaster);
logger.trace("No '" + APPLICATION_EVENT_MULTICASTER_BEAN_NAME + "' bean, using " +
"[" + this.applicationEventMulticaster.getClass().getSimpleName() + "]");
注册
protected void registerListeners() {
// Register statically specified listeners first.
// 读取 ApplicationListener
for (ApplicationListener<?> listener : getApplicationListeners()) {
getApplicationEventMulticaster().addApplicationListener(listener);
// Do not initialize FactoryBeans here: We need to leave all regular beans
// uninitialized to let post-processors apply to them!
* 寻找类型为{@link ApplicationListener} 的beanName,目标文件为用户配置文件
String[] listenerBeanNames = getBeanNamesForType(ApplicationListener.class, true, false);
for (String listenerBeanName : listenerBeanNames) {
* 1. 获取 {@link applicationEventMulticaster}
* 2. 添加监听器名称
getApplicationEventMulticaster().addApplicationListenerBean(listenerBeanName);
// Publish early application events now that we finally have a multicaster...
Set<ApplicationEvent> earlyEventsToProcess = this.earlyApplicationEvents;
this.earlyApplicationEvents = null;
if (earlyEventsToProcess != null) {
for (ApplicationEvent earlyEvent : earlyEventsToProcess) {
getApplicationEventMulticaster().multicastEvent(earlyEvent);
finishRefresh 发布
protected void finishRefresh() {
// Clear context-level resource caches (such as ASM metadata from scanning).
clearResourceCaches();
// Initialize lifecycle processor for this context.
initLifecycleProcessor();
// Propagate refresh to lifecycle processor first.
getLifecycleProcessor().onRefresh();
// Publish the final event.
// 发布事件做处理
publishEvent(new ContextRefreshedEvent(this));
// Participate in LiveBeansView MBean, if active.
LiveBeansView.registerApplicationContext(this);
- org.springframework.context.support.AbstractApplicationContext#publishEvent(org.springframework.context.ApplicationEvent)
- org.springframework.context.support.AbstractApplicationContext#publishEvent(java.lang.Object, org.springframework.core.ResolvableType)
protected void publishEvent(Object event, @Nullable ResolvableType eventType) {
Assert.notNull(event, "Event must not be null");
// Decorate event as an ApplicationEvent if necessary
ApplicationEvent applicationEvent;
if (event instanceof ApplicationEvent) {
applicationEvent = (ApplicationEvent) event;
else {
applicationEvent = new PayloadApplicationEvent<>(this, event);
if (eventType == null) {
eventType = ((PayloadApplicationEvent<?>) applicationEvent).getResolvableType();
// Multicast right now if possible - or lazily once the multicaster is initialized
if (this.earlyApplicationEvents != null) {
this.earlyApplicationEvents.add(applicationEvent);
else {
* 执行监听事件
* {@link ApplicationEventMulticaster} ->{@link SimpleApplicationEventMulticaster}
getApplicationEventMulticaster().multicastEvent(applicationEvent, eventType);
// Publish event via parent context as well...
if (this.parent != null) {
if (this.parent instanceof AbstractApplicationContext) {
((AbstractApplicationContext) this.parent).publishEvent(event, eventType);
else {
this.parent.publishEvent(event);
- 执行监听方法
protected void invokeListener(ApplicationListener<?> listener, ApplicationEvent event) {
ErrorHandler errorHandler = getErrorHandler();
if (errorHandler != null) {
try {
doInvokeListener(listener, event);
catch (Throwable err) {
errorHandler.handleError(err);
else {
@SuppressWarnings({"rawtypes", "unchecked"})
private void doInvokeListener(ApplicationListener listener, ApplicationEvent event) {
try {
// 最后调用方法
listener.onApplicationEvent(event);
catch (ClassCastException ex) {
String msg = ex.getMessage();
if (msg == null || matchesClassCastMessage(msg, event.getClass())) {
// Possibly a lambda-defined listener which we could not resolve the generic event type for
// -> let's suppress the exception and just log a debug message.
Log logger = LogFactory.getLog(getClass());
logger.trace("Non-matching event type for listener: " + listener, ex);
else {
throw ex;
cloudbbs@huaweicloud.com
