【CANN训练营第三季】CANN6.0环境MMDeploy搭建笔记
JeffDing 发表于 2022/11/17 19:35:46 2022/11/17
【摘要】 CANN6.0环境MMDeploy搭建笔记
一、环境配置
华为云环境配置:
  • OS: ubuntu18.04
  • ARCH: aarch64
  • Ascend toolkit: 6.0.0.alpha001
  • Python虚拟环境:MiniAnaconda
  • CMAKE版本:3.24
二、环境安装
安装pip3
sudo apt install python3-pip
CANN 6.0安装
下载网站:https://www.hiascend.com/zh/software/cann/community
下载命令:
wget https://ascend-repo.obs.cn-east-2.myhuaweicloud.com/CANN/6.0.0.alpha001/Ascend-cann-toolkit_6.0.0.alpha001_linux-aarch64.run
添加可执行权限
chmod a+x Ascend-cann-toolkit_6.0.0.alpha001_linux-aarch64.run
执行安装
sudo ./Ascend-cann-toolkit_6.0.0.alpha001_linux-aarch64.run --full
添加环境变量
vim ~/.bahrc
添加如下内容
export PATH=/usr/local/Ascend/ascend-toolkit/latest/bin:/usr/local/Ascend/ascend-toolkit/latest/compiler/ccec_compiler/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/Ascend/ascend-toolkit/latest/lib64:/usr/local/Ascend/ascend-toolkit/latest/lib64/plugin/opskernel:/usr/local/Ascend/ascend-toolkit/latest/lib64/plugin/nnengine:$LD_LIBRARY_PATH
export PYTHONPATH=/usr/local/Ascend/ascend-toolkit/latest/python/site-packages:/usr/local/Ascend/ascend-toolkit/latest/opp/op_impl/built-in/ai_core/tbe:$PYTHONPATH
export ASCEND_AICPU_PATH=/usr/local/Ascend/ascend-toolkit/latest
export ASCEND_OPP_PATH=/usr/local/Ascend/ascend-toolkit/latest/opp
export TOOLCHAIN_HOME=/usr/local/Ascend/ascend-toolkit/latest/toolkit
export ASCEND_HOME_PATH=/usr/local/Ascend/ascend-toolkit/latest
更新环境变量
source ~/.bashrc
安装Ascend固件及驱动
这一步非必须,如果遇到模型转换报错acl.rt.set_device,57033错误的话需要更新一下固件及驱动
下载地址:https://www.hiascend.com/hardware/firmware-drivers?tag=community
下载安装命令脚本
wget 'https://obs-9be7.obs.cn-east-2.myhuaweicloud.com/turing/resourcecenter/Software/AtlasI/Ascend%20HDK%2022.0.RC2/A300-3000-npu-driver_5.1.rc2_linux-aarch64.run?response-content-type=application/octet-stream' --no-check-certificate
mv A300-3000-npu-driver_5.1.rc2_linux-aarch64.run\?response-content-type\=application%2Foctet-stream A300-3000-npu-driver_5.1.rc2_linux-aarch64.run
./A300-3000-npu-driver_5.1.rc2_linux-aarch64.run --full
安装cmake
camke下载地址:https://cmake.org/download/
安装步骤:
wget https://github.com/Kitware/CMake/releases/download/v3.24.3/cmake-3.24.3.tar.gz
tar -xvf cmake-3.24.3.tar.gz
cd cmake
./configure
make
sudo make install
三、模型依赖环境安装
安装miniconda
wget https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-aarch64.sh
bash Miniconda3-latest-Linux-aarch64.sh
export PATH=$HOME/miniconda3/bin:$PATH
创建虚拟环境
conda create --name mmlab python=3.8 -y
conda activate mmlab
安装python
pip install torch==1.8.1 torchvision==0.9.1 --extra-index-url https://download.pytorch.org/whl/cpu
安装MMCV
pip install openmim
pip install mmcv-full
模型推理依赖环境
sudo apt-get update
sudo apt-get install libopencv-dev
mmdeploy依赖安装
git clone --recursive https://github.com/open-mmlab/mmdeploy.git
cd mmdeploy
安装mmdeploy模型转换器
pip install -v -e .
编译 mmdeploy 推理SDK
#设置 ascend-toolkit环境变量
source /usr/local/Ascend/ascend-toolkit/set_env.sh
mkdir -p build && cd build
cmake .. -DMMDEPLOY_BUILD_SDK=ON -DMMDEPLOY_BUILD_SDK_PYTHON_API=ON -DMMDEPLOY_TARGET_BACKENDS=acl
make -j$(nproc) && make install
cd ..
验证
#检查mmdeploy模型转换器是否安装成功
python tools/check_env.py
#检查mmdeploy推理SDK是否编译安装成功
export PYTHONPATH=$(pwd)/build/lib:$PYTHONPATH
python -c "import mmdeploy_python"
注意:如果遇到报onnx报找不到执行
pip install onnx
