Spring 事务最全最深解析
龙哥手记 发表于 2022/11/16 23:30:32 2022/11/16
【摘要】 《读尽源码 第十九篇》
声明式事务
Propagation
  • 事务传播
public enum Propagation {
    * 有事务则加入,没有则新建
   REQUIRED(TransactionDefinition.PROPAGATION_REQUIRED),
    * 有事务就用,如果没有就不开启(继承关系)
    * @see org.springframework.transaction.support.AbstractPlatformTransactionManager#setTransactionSynchronization
   SUPPORTS(TransactionDefinition.PROPAGATION_SUPPORTS),
    *  必须在已有事务中
   MANDATORY(TransactionDefinition.PROPAGATION_MANDATORY),
    * 不管是否已有事务,都要开启新事务,老事务挂起
    * @see org.springframework.transaction.jta.JtaTransactionManager#setTransactionManager
   REQUIRES_NEW(TransactionDefinition.PROPAGATION_REQUIRES_NEW),
    * 不开启事务
   NOT_SUPPORTED(TransactionDefinition.PROPAGATION_NOT_SUPPORTED),
    * 必须在没有事务的方法中调用,否则抛出异常
   NEVER(TransactionDefinition.PROPAGATION_NEVER),
    * 果已有事务,则嵌套执行,如果没有,就新建(和REQUIRED类似,和REQUIRES_NEW容易混淆)
    * @see org.springframework.jdbc.datasource.DataSourceTransactionManager
   NESTED(TransactionDefinition.PROPAGATION_NESTED);
   private final int value;
   Propagation(int value) {
      this.value = value;
   public int value() {
      return this.value;
}Copy to clipboardErrorCopied
Isolation
  • 事务级别
public enum Isolation {
    * @see java.sql.Connection
   DEFAULT(TransactionDefinition.ISOLATION_DEFAULT),
    * 读未提交
    * @see java.sql.Connection#TRANSACTION_READ_UNCOMMITTED
   READ_UNCOMMITTED(TransactionDefinition.ISOLATION_READ_UNCOMMITTED),
    * 读已提交
    * @see java.sql.Connection#TRANSACTION_READ_COMMITTED
   READ_COMMITTED(TransactionDefinition.ISOLATION_READ_COMMITTED),
    * 可重复读
    * @see java.sql.Connection#TRANSACTION_REPEATABLE_READ
   REPEATABLE_READ(TransactionDefinition.ISOLATION_REPEATABLE_READ),
    * 可串行化
    * @see java.sql.Connection#TRANSACTION_SERIALIZABLE
   SERIALIZABLE(TransactionDefinition.ISOLATION_SERIALIZABLE);
   Isolation(int value) {
      this.value = value;
      return this.value;
EnableTransactionManagement
  • 下面代码是一个注解方式的事务配置使用 EnableTransactionManagement来开启事务支持
@ComponentScan(basePackages = "org.source.hot.spring.overview.ioc.tx.declarative")
@EnableTransactionManagement
public class TxConfig {
    @Bean // 数据源
    public DataSource dataSource() {
        DruidDataSource dataSource = new DruidDataSource();
        dataSource.setUsername("");
        dataSource.setPassword("");
        dataSource.setUrl("");
        dataSource.setDriverClassName(com.mysql.jdbc.Driver.class.getName());
        return dataSource;
    @Bean
    public JdbcTemplate jdbcTemplate(DataSource dataSource) {
        return new JdbcTemplate(dataSource);
    @Bean //事务管理器
    public PlatformTransactionManager platformTransactionManager(DataSource dataSource) {
        return new DataSourceTransactionManager(dataSource);
  • 注解源码如下,关注于@Import(TransactionManagementConfigurationSelector.class)
@Target(ElementType.TYPE)
@Retention(RetentionPolicy.RUNTIME)
@Documented
public @interface EnableTransactionManagement {
   boolean proxyTargetClass() default false;
   AdviceMode mode() default AdviceMode.PROXY;
   int order() default Ordered.LOWEST_PRECEDENCE;
public class TransactionManagementConfigurationSelector extends AdviceModeImportSelector<EnableTransactionManagement> {
   @Override
   protected String[] selectImports(AdviceMode adviceMode) {
      // 根据切面类型进行初始化
      switch (adviceMode) {
         case PROXY:
              // 默认值
            return new String[] {AutoProxyRegistrar.class.getName(),
                  ProxyTransactionManagementConfiguration.class.getName()};
         case ASPECTJ:
            return new String[] {determineTransactionAspectClass()};
         default:
            return null;
   private String determineTransactionAspectClass() {
      return (ClassUtils.isPresent("javax.transaction.Transactional", getClass().getClassLoader()) ?
            TransactionManagementConfigUtils.JTA_TRANSACTION_ASPECT_CONFIGURATION_CLASS_NAME :
            TransactionManagementConfigUtils.TRANSACTION_ASPECT_CONFIGURATION_CLASS_NAME);
@Configuration(proxyBeanMethods = false)
public class ProxyTransactionManagementConfiguration extends AbstractTransactionManagementConfiguration {
    * 事务切面
    * @param transactionAttributeSource
    * @param transactionInterceptor
    * @return
   @Bean(name = TransactionManagementConfigUtils.TRANSACTION_ADVISOR_BEAN_NAME)
   @Role(BeanDefinition.ROLE_INFRASTRUCTURE)
   public BeanFactoryTransactionAttributeSourceAdvisor transactionAdvisor(
         TransactionAttributeSource transactionAttributeSource,
         TransactionInterceptor transactionInterceptor) {
      // 事务切面
      BeanFactoryTransactionAttributeSourceAdvisor advisor = new BeanFactoryTransactionAttributeSourceAdvisor();
      // 事务属性
      advisor.setTransactionAttributeSource(transactionAttributeSource);
      advisor.setAdvice(transactionInterceptor);
      if (this.enableTx != null) {
         // 执行顺序
         advisor.setOrder(this.enableTx.<Integer>getNumber("order"));
      return advisor;
   @Bean
   public TransactionAttributeSource transactionAttributeSource() {
      return new AnnotationTransactionAttributeSource();
    * 事务拦截器
    * @return
   @Bean
   public TransactionInterceptor transactionInterceptor(
         TransactionAttributeSource transactionAttributeSource) {
      TransactionInterceptor interceptor = new TransactionInterceptor();
      interceptor.setTransactionAttributeSource(transactionAttributeSource);
      if (this.txManager != null) {
         // 事务管理器注入
         interceptor.setTransactionManager(this.txManager);
      return interceptor;
  • 实现了org.aopalliance.intercept.MethodInterceptor接口的方法
@Override
@Nullable
public Object invoke(MethodInvocation invocation) throws Throwable {
   // Work out the target class: may be {@code null}.
   // The TransactionAttributeSource should be passed the target class
   // as well as the method, which may be from an interface.
   Class<?> targetClass = (invocation.getThis() != null ? AopUtils.getTargetClass(invocation.getThis()) : null);
   // Adapt to TransactionAspectSupport's invokeWithinTransaction...
   return invokeWithinTransaction(invocation.getMethod(), targetClass, invocation::proceed);
  • 这段代码会在具有Transactional 的注解方法上生效
@Service
public class IssueServiceImpl {
   @Autowired
   private JdbcTemplate jdbcTemplate;
   @Transactional()
   public boolean insertIssue() throws Exception {
      jdbcTemplate.execute("INSERT INTO `scrum`.`issue`() VALUES ()");
      throw new Exception("a");
public class DeclarativeTransactionTest {
    public static void main(String[] args) throws Exception {
        AnnotationConfigApplicationContext applicationContext = new AnnotationConfigApplicationContext(
                TxConfig.class);
        IssueServiceImpl bean = applicationContext.getBean(IssueServiceImpl.class);
        bean.insertIssue();
        System.out.println();
        applicationContext.close();
断点开始进行查阅. 再断点后执行一步会直接进入 cglib 代理对象
org.springframework.aop.framework.CglibAopProxy.DynamicAdvisedInterceptor#intercept 具体不展开,继续往下执行
走到invoke方法了
入参对象查看
  • 获取事务属性
    @Override
    @Nullable
    public TransactionAttribute getTransactionAttribute(Method method,
          @Nullable Class<?> targetClass) {
       if (method.getDeclaringClass() == Object.class) {
          return null;
       // First, see if we have a cached value.
       // 尝试缓存中获取
       Object cacheKey = getCacheKey(method, targetClass);
       TransactionAttribute cached = this.attributeCache.get(cacheKey);
       if (cached != null) {
          // Value will either be canonical value indicating there is no transaction attribute,
          // or an actual transaction attribute.
          if (cached == NULL_TRANSACTION_ATTRIBUTE) {
             return null;
             return cached;
          // We need to work it out.
          // 自行构建一个事务属性
          TransactionAttribute txAttr = computeTransactionAttribute(method, targetClass);
          // Put it in the cache.
          if (txAttr == null) {
             this.attributeCache.put(cacheKey, NULL_TRANSACTION_ATTRIBUTE);
             String methodIdentification = ClassUtils
                   .getQualifiedMethodName(method, targetClass);
             if (txAttr instanceof DefaultTransactionAttribute) {
                ((DefaultTransactionAttribute) txAttr).setDescriptor(methodIdentification);
             if (logger.isTraceEnabled()) {
                logger.trace("Adding transactional method '" + methodIdentification
                      + "' with attribute: " + txAttr);
             this.attributeCache.put(cacheKey, txAttr);
          return txAttr;
  protected Object getCacheKey(Method method, @Nullable Class<?> targetClass) {
      return new MethodClassKey(method, targetClass);
![image-20200729162023837](/images/spring/image-20200729162023837.png)
- 此处方法已经获取到了这个方法就是后面的一个切面
- 确定事务管理器
```java
@Nullable
protected TransactionManager determineTransactionManager(
      @Nullable TransactionAttribute txAttr) {
   // Do not attempt to lookup tx manager if no tx attributes are set
   // 空判断返回一个事务管理器
   if (txAttr == null || this.beanFactory == null) {
      return getTransactionManager();
   // 属性是否有别名
   String qualifier = txAttr.getQualifier();
   // 如果有
   if (StringUtils.hasText(qualifier)) {
      // 从 ioc 容器中根据类型和名称获取事务管理器
      return determineQualifiedTransactionManager(this.beanFactory, qualifier);
   } else if (StringUtils.hasText(this.transactionManagerBeanName)) {
            this.transactionManagerBeanName);
      // 通过get方法获取
      TransactionManager defaultTransactionManager = getTransactionManager();
      // 如果没有
      if (defaultTransactionManager == null) {
         // 尝试从缓存中获取
         defaultTransactionManager = this.transactionManagerCache
               .get(DEFAULT_TRANSACTION_MANAGER_KEY);
         // 缓存里面没有从 ioc 容器中获取并且设置缓存
            defaultTransactionManager = this.beanFactory.getBean(TransactionManager.class);
            this.transactionManagerCache.putIfAbsent(
                  DEFAULT_TRANSACTION_MANAGER_KEY, defaultTransactionManager);
      return defaultTransactionManager;
  • 类型转换
    @Nullable
    private PlatformTransactionManager asPlatformTransactionManager(
          @Nullable Object transactionManager) {
       if (transactionManager == null
             || transactionManager instanceof PlatformTransactionManager) {
          return (PlatformTransactionManager) transactionManager;
          throw new IllegalStateException(
                "Specified transaction manager is not a PlatformTransactionManager: "
                      + transactionManager);
  • 获取方法切面
    private String methodIdentification(Method method, @Nullable Class<?> targetClass,
       String methodIdentification = methodIdentification(method, targetClass);
       if (methodIdentification == null) {
             // 直接就获取了.方法签名.
             methodIdentification = ((DefaultTransactionAttribute) txAttr).getDescriptor();
             methodIdentification = ClassUtils.getQualifiedMethodName(method, targetClass);
       return methodIdentification;
  • 创建一个新的事务根据事务传播性
        @SuppressWarnings("serial")
        protected TransactionInfo createTransactionIfNecessary(@Nullable PlatformTransactionManager tm,
                @Nullable TransactionAttribute txAttr, final String joinpointIdentification) {
            // If no name specified, apply method identification as transaction name.
            // 把切面的地址放进去
            if (txAttr != null && txAttr.getName() == null) {
                txAttr = new DelegatingTransactionAttribute(txAttr) {
                    @Override
                    public String getName() {
                        return joinpointIdentification;
            TransactionStatus status = null;
            if (txAttr != null) {
                if (tm != null) {
                    // 事务状态
                    // 获取事务
                    status = tm.getTransaction(txAttr);
                    if (logger.isDebugEnabled()) {
                        logger.debug("Skipping transactional joinpoint [" + joinpointIdentification +
                                "] because no transaction manager has been configured");
            // 处理出一个 TransactionInfo
            return prepareTransactionInfo(tm, txAttr, joinpointIdentification, status);
  • tm.getTransaction
    @Override
    public final TransactionStatus getTransaction(@Nullable TransactionDefinition definition)
          throws TransactionException {
       // Use defaults if no transaction definition given.
       // 获取事务的定义
       TransactionDefinition def = (definition != null ? definition
             : TransactionDefinition.withDefaults());
       // 获取事务
       Object transaction = doGetTransaction();
       boolean debugEnabled = logger.isDebugEnabled();
       // 是否存在事务
       if (isExistingTransaction(transaction)) {
          // Existing transaction found -> check propagation behavior to find out how to behave.
          // 存在事务后处理什么操作
          return handleExistingTransaction(def, transaction, debugEnabled);
       // Check definition settings for new transaction.
       // 超时的校验. 小于默认值抛出异常
       if (def.getTimeout() < TransactionDefinition.TIMEOUT_DEFAULT) {
          throw new InvalidTimeoutException("Invalid transaction timeout", def.getTimeout());
       // No existing transaction found -> check propagation behavior to find out how to proceed.
       // 没有事务抛出异常
       if (def.getPropagationBehavior() == TransactionDefinition.PROPAGATION_MANDATORY) {
          throw new IllegalTransactionStateException(
                "No existing transaction found for transaction marked with propagation 'mandatory'");
       } else if (def.getPropagationBehavior() == TransactionDefinition.PROPAGATION_REQUIRED ||
             def.getPropagationBehavior() == TransactionDefinition.PROPAGATION_REQUIRES_NEW ||
             def.getPropagationBehavior() == TransactionDefinition.PROPAGATION_NESTED) {
          SuspendedResourcesHolder suspendedResources = suspend(null);
          if (debugEnabled) {
             logger.debug("Creating new transaction with name [" + def.getName() + "]: " + def);
          try {
             boolean newSynchronization = (getTransactionSynchronization()
                   != SYNCHRONIZATION_NEVER);
             DefaultTransactionStatus status = newTransactionStatus(
                   def, transaction, true, newSynchronization, debugEnabled,
                   suspendedResources);
             doBegin(transaction, def);
             prepareSynchronization(status, def);
             return status;
          } catch (RuntimeException | Error ex) {
             resume(null, suspendedResources);
             throw ex;
          // Create "empty" transaction: no actual transaction, but potentially synchronization.
          if (def.getIsolationLevel() != TransactionDefinition.ISOLATION_DEFAULT && logger
                .isWarnEnabled()) {
             logger.warn(
                   "Custom isolation level specified but no actual transaction initiated; " +
                         "isolation level will effectively be ignored: " + def);
                == SYNCHRONIZATION_ALWAYS);
          return prepareTransactionStatus(def, null, true, newSynchronization, debugEnabled,
                null);
    • org.springframework.transaction.support.AbstractPlatformTransactionManager#getTransaction
    • org.springframework.jdbc.datasource.DataSourceTransactionManager#doGetTransaction
      @Override
      protected Object doGetTransaction() {
         DataSourceTransactionObject txObject = new DataSourceTransactionObject();
         txObject.setSavepointAllowed(isNestedTransactionAllowed());
         // 数据库链接对象
         // 从事务管理器中获取数据库链接对象
         ConnectionHolder conHolder =
               (ConnectionHolder) TransactionSynchronizationManager
                     .getResource(obtainDataSource());
         txObject.setConnectionHolder(conHolder, false);
         return txObject;
    • org.springframework.transaction.support.AbstractPlatformTransactionManager#suspend
      @Nullable
      protected final SuspendedResourcesHolder suspend(@Nullable Object transaction)
         if (TransactionSynchronizationManager.isSynchronizationActive()) {
            List<TransactionSynchronization> suspendedSynchronizations = doSuspendSynchronization();
            try {
               Object suspendedResources = null;
               if (transaction != null) {
                  suspendedResources = doSuspend(transaction);
               // 线程名称
               String name = TransactionSynchronizationManager.getCurrentTransactionName();
               // 同步方法中设置
               TransactionSynchronizationManager.setCurrentTransactionName(null);
               // 只读设置
               boolean readOnly = TransactionSynchronizationManager.isCurrentTransactionReadOnly();
               // 同步方法中设置
               TransactionSynchronizationManager.setCurrentTransactionReadOnly(false);
               // 隔离级别
               Integer isolationLevel = TransactionSynchronizationManager
                     .getCurrentTransactionIsolationLevel();
               // 同步方法中设置
               TransactionSynchronizationManager.setCurrentTransactionIsolationLevel(null);
               // 是否活跃
               boolean wasActive = TransactionSynchronizationManager.isActualTransactionActive();
               TransactionSynchronizationManager.setActualTransactionActive(false);
               return new SuspendedResourcesHolder(
                     suspendedResources, suspendedSynchronizations, name, readOnly,
                     isolationLevel, wasActive);
               // doSuspend failed - original transaction is still active...
               doResumeSynchronization(suspendedSynchronizations);
               throw ex;
         } else if (transaction != null) {
            // Transaction active but no synchronization active.
            Object suspendedResources = doSuspend(transaction);
            return new SuspendedResourcesHolder(suspendedResources);
            // Neither transaction nor synchronization active.
            return null;
  • prepareTransactionInfo简单的new对象并且绑定线程
    protected TransactionInfo prepareTransactionInfo(@Nullable PlatformTransactionManager tm,
          @Nullable TransactionAttribute txAttr, String joinpointIdentification,
          @Nullable TransactionStatus status) {
       // 初始化
       TransactionInfo txInfo = new TransactionInfo(tm, txAttr, joinpointIdentification);
          // We need a transaction for this method...
             logger.trace(
                   "Getting transaction for [" + txInfo.getJoinpointIdentification() + "]");
          // The transaction manager will flag an error if an incompatible tx already exists.
          txInfo.newTransactionStatus(status);
          // The TransactionInfo.hasTransaction() method will return false. We created it only
          // to preserve the integrity of the ThreadLocal stack maintained in this class.
             logger.trace("No need to create transaction for [" + joinpointIdentification +
                   "]: This method is not transactional.");
       // We always bind the TransactionInfo to the thread, even if we didn't create
       // a new transaction here. This guarantees that the TransactionInfo stack
       // will be managed correctly even if no transaction was created by this aspect.
       // 和线程绑定
       txInfo.bindToThread();
       return txInfo;
  • retVal = invocation.proceedWithInvocation();
    • 这里走的是 CGLIB 的方法直接会执行结果将结果返回具体方法在
      org.springframework.aop.framework.CglibAopProxy.CglibMethodInvocation#proceed
            @Override
            @Nullable
            public Object proceed() throws Throwable {
                try {
                    return super.proceed();
                catch (RuntimeException ex) {
                    throw ex;
                catch (Exception ex) {
                    if (ReflectionUtils.declaresException(getMethod(), ex.getClass())) {
                        throw ex;
                    else {
                        throw new UndeclaredThrowableException(ex);
  • 如果没有异常就直接处理完成返回了
  • 我们现在是有异常的
    try {
       // This is an around advice: Invoke the next interceptor in the chain.
       // This will normally result in a target object being invoked.
       // 回调方法
    } catch (Throwable ex) {
       // target invocation exception
       // 回滚异常
       completeTransactionAfterThrowing(txInfo, ex);
       throw ex;
    } finally {
       // 消息清理
       cleanupTransactionInfo(txInfo);
  • completeTransactionAfterThrowing回滚异常的处理方法
    protected void completeTransactionAfterThrowing(@Nullable TransactionInfo txInfo,
          Throwable ex) {
       if (txInfo != null && txInfo.getTransactionStatus() != null) {
             logger.trace("Completing transaction for [" + txInfo.getJoinpointIdentification() +
                   "] after exception: " + ex);
          if (txInfo.transactionAttribute != null && txInfo.transactionAttribute.rollbackOn(ex)) {
             try {
                // 做回滚
                txInfo.getTransactionManager().rollback(txInfo.getTransactionStatus());
             } catch (TransactionSystemException ex2) {
                logger.error("Application exception overridden by rollback exception", ex);
                ex2.initApplicationException(ex);
                throw ex2;
             } catch (RuntimeException | Error ex2) {
                throw ex2;
             // We don't roll back on this exception.
             // Will still roll back if TransactionStatus.isRollbackOnly() is true.
             try {
                // org.springframework.transaction.support.AbstractPlatformTransactionManager.commit 的方法
                txInfo.getTransactionManager().commit(txInfo.getTransactionStatus());
                logger.error("Application exception overridden by commit exception", ex);
                throw ex2;
                throw ex2;
    • 整理一下这里的流程
      1. 有异常走回滚
      2. 没有异常直接提交
    • 注意: 这里的异常如果是 exception 不会走回滚
  • 判断是否需要回滚
    txInfo.transactionAttribute.rollbackOnCopy to clipboardErrorCopied
    • 链路
      • org.springframework.transaction.interceptor.DelegatingTransactionAttribute#rollbackOn
        • org.springframework.transaction.interceptor.RuleBasedTransactionAttribute#rollbackOn
          @Override
          public boolean rollbackOn(Throwable ex) {
                logger.trace(
                      "Applying rules to determine whether transaction should rollback on " + ex);
             RollbackRuleAttribute winner = null;
             int deepest = Integer.MAX_VALUE;
             if (this.rollbackRules != null) {
                for (RollbackRuleAttribute rule : this.rollbackRules) {
                   int depth = rule.getDepth(ex);
                   if (depth >= 0 && depth < deepest) {
                      deepest = depth;
                      winner = rule;
                logger.trace("Winning rollback rule is: " + winner);
             // User superclass behavior (rollback on unchecked) if no rule matches.
             if (winner == null) {
                logger.trace("No relevant rollback rule found: applying default rules");
                return super.rollbackOn(ex);
             return !(winner instanceof NoRollbackRuleAttribute);
          • org.springframework.transaction.interceptor.DefaultTransactionAttribute#rollbackOn
            @Override
               return (ex instanceof RuntimeException || ex instanceof Error);
            • 这就是我们的异常判断是否需要回滚
  • cleanupTransactionInfo
    数据清理
    protected void cleanupTransactionInfo(@Nullable TransactionInfo txInfo) {
       if (txInfo != null) {
          txInfo.restoreThreadLocalStatus();
    private void restoreThreadLocalStatus() {
       // Use stack to restore old transaction TransactionInfo.
       // Will be null if none was set.
       transactionInfoHolder.set(this.oldTransactionInfo);
编程式事务
DefaultTransactionDefinition
  • 默认的事务定义
    • 常见属性
      1. timeout
      2. readOnly
      3. ....
// 获取事务
TransactionStatus getTransaction(@Nullable TransactionDefinition definition)throws TransactionException;
// 提交事务
void commit(TransactionStatus status) throws TransactionException;
// 回滚事务
void rollback(TransactionStatus status) throws TransactionException;Copy to clipboardErrorCopied
  • 贴出一部分
  • AbstractPlatformTransactionManager 定义了一些基础属性 以及一些需要子类实现的方法
// 属性
defaultTimeout
nestedTransactionAllowed
validateExistingTransaction
globalRollbackOnParticipationFailure
failEarlyOnGlobalRollbackOnly
rollbackOnCommitFailure
// 方法
doGetTransaction
useSavepointForNestedTransaction
doBegin
doSuspend
doResume
shouldCommitOnGlobalRollbackOnly
prepareForCommit
doCommit
doRollback
doSetRollbackOnly
registerAfterCompletionWithExistingTransaction
doCleanupAfterCompletion
  • xml 配置如下
    <bean id="dataSource" class="com.alibaba.druid.pool.DruidDataSource">
        <property name="url"
                value=""/>
        <property name="username" value=""/>
        <property name="password" value=""/>
        <property name="driverClassName" value="com.mysql.jdbc.Driver"/>
    </bean>
    <bean id="jdbcTemplate" class="org.springframework.jdbc.core.JdbcTemplate">
        <property name="dataSource" ref="dataSource"/>
    </bean>
    <bean id="transactionManager"
            class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
    </bean>Copy to clipboardErrorCopied
  • 两个属性,通常我们会配置 datasource
        @Nullable
        private DataSource dataSource;
        private boolean enforceReadOnly = false;Copy to clipboardErrorCopied
    • bean 的属性注入就不具体描述了
  • InitializingBean
    • @Override
      public void afterPropertiesSet() {
         if (getDataSource() == null) {
            throw new IllegalArgumentException("Property 'dataSource' is required");
      • 如果dataSource为空会抛出异常
      • 默认单例会注册到 ioc 容器中.后续注册流程不具体描述
  • 方法注释
     * 获取datasource
    protected DataSource obtainDataSource() {
        DataSource dataSource = getDataSource();
        Assert.state(dataSource != null, "No DataSource set");
        return dataSource;
     * 创建事务
     * @return 事务对象
    @Override
        // 数据库链接对象
        // 从事务管理器中获取数据库链接对象
        return txObject;
     * 是否存在事务
     * @param transaction transaction object returned by doGetTransaction
     * @return
    @Override
    protected boolean isExistingTransaction(Object transaction) {
        DataSourceTransactionObject txObject = (DataSourceTransactionObject) transaction;
        return (txObject.hasConnectionHolder() && txObject.getConnectionHolder()
                .isTransactionActive());
     * This implementation sets the isolation level but ignores the timeout. 事务的开始方法
    @Override
    protected void doBegin(Object transaction, TransactionDefinition definition) {
        // 拿出事务
        // 链接对象
        Connection con = null;
        try {
            if (!txObject.hasConnectionHolder() ||
                    txObject.getConnectionHolder().isSynchronizedWithTransaction()) {
                // 数据库链接对象
                Connection newCon = obtainDataSource().getConnection();
                    logger.debug("Acquired Connection [" + newCon + "] for JDBC transaction");
                // 设置数据库连接
                txObject.setConnectionHolder(new ConnectionHolder(newCon), true);
            // 拿出链接对象并且设置同步事务
            txObject.getConnectionHolder().setSynchronizedWithTransaction(true);
            // 链接对象赋值
            con = txObject.getConnectionHolder().getConnection();
            // 获取事务级别
            Integer previousIsolationLevel = DataSourceUtils
                    .prepareConnectionForTransaction(con, definition);
            // 设置事务隔离级别
            txObject.setPreviousIsolationLevel(previousIsolationLevel);
            // 设置只读
            txObject.setReadOnly(definition.isReadOnly());
            // Switch to manual commit if necessary. This is very expensive in some JDBC drivers,
            // so we don't want to do it unnecessarily (for example if we've explicitly
            // configured the connection pool to set it already).
            // 判断是否自动提交
            if (con.getAutoCommit()) {
                txObject.setMustRestoreAutoCommit(true);
                    logger.debug("Switching JDBC Connection [" + con + "] to manual commit");
                con.setAutoCommit(false);
            // 事务链接准备
            prepareTransactionalConnection(con, definition);
            // 事务激活
            txObject.getConnectionHolder().setTransactionActive(true);
            // 超时时间获取
            int timeout = determineTimeout(definition);
            // 默认超时时间设置
            if (timeout != TransactionDefinition.TIMEOUT_DEFAULT) {
                txObject.getConnectionHolder().setTimeoutInSeconds(timeout);
            // Bind the connection holder to the thread.
            // 将链接和当前线程绑定
            if (txObject.isNewConnectionHolder()) {
                // k: datasource v: connectionHolder
                        .bindResource(obtainDataSource(), txObject.getConnectionHolder());
                // 释放链接
                DataSourceUtils.releaseConnection(con, obtainDataSource());
                txObject.setConnectionHolder(null, false);
            throw new CannotCreateTransactionException(
                    "Could not open JDBC Connection for transaction", ex);
     * 挂起事务
     * @param transaction transaction object returned by {@code doGetTransaction}
     * @return 移除的链接
    @Override
    protected Object doSuspend(Object transaction) {
        // 获取事务对象
        // 连接置空
        txObject.setConnectionHolder(null);
        // 解除资源绑定
        return TransactionSynchronizationManager.unbindResource(obtainDataSource());
     * 恢复事务
     * @param suspendedResources the object that holds suspended resources, as returned by
     *                           doSuspend
    @Override
    protected void doResume(@Nullable Object transaction, Object suspendedResources) {
        // 资源绑定
        TransactionSynchronizationManager.bindResource(obtainDataSource(), suspendedResources);
     * 做提交
     * @param status the status representation of the transaction
    @Override
    protected void doCommit(DefaultTransactionStatus status) {
        // 事务对象
        DataSourceTransactionObject txObject = (DataSourceTransactionObject) status
                .getTransaction();
        // 获取链接
        Connection con = txObject.getConnectionHolder().getConnection();
        if (status.isDebug()) {
            logger.debug("Committing JDBC transaction on Connection [" + con + "]");
        try {
            // 链接提交
            con.commit();
        } catch (SQLException ex) {
            throw new TransactionSystemException("Could not commit JDBC transaction", ex);
     * 事务回滚
    @Override
    protected void doRollback(DefaultTransactionStatus status) {
        // 事务对象
                .getTransaction();
        // 链接对象
            logger.debug("Rolling back JDBC transaction on Connection [" + con + "]");
        try {
            // 回滚方法
            con.rollback();
            throw new TransactionSystemException("Could not roll back JDBC transaction", ex);
     * 设置回滚
    @Override
    protected void doSetRollbackOnly(DefaultTransactionStatus status) {
                .getTransaction();
            logger.debug(
                    "Setting JDBC transaction [" + txObject.getConnectionHolder().getConnection() +
                            "] rollback-only");
        txObject.setRollbackOnly();
     * 清除
    @Override
    protected void doCleanupAfterCompletion(Object transaction) {
        // Remove the connection holder from the thread, if exposed.
            // 释放datasource绑定的资源
        // Reset connection.
        try {
            if (txObject.isMustRestoreAutoCommit()) {
                con.setAutoCommit(true);
            // 重置链接
            DataSourceUtils.resetConnectionAfterTransaction(
                    con, txObject.getPreviousIsolationLevel(), txObject.isReadOnly());
            logger.debug("Could not reset JDBC Connection after transaction", ex);
                logger.debug("Releasing JDBC Connection [" + con + "] after transaction");
            DataSourceUtils.releaseConnection(con, this.dataSource);
        txObject.getConnectionHolder().clear();
    * 事务准备
    protected void prepareTransactionalConnection(Connection con, TransactionDefinition definition)
            throws SQLException {
        if (isEnforceReadOnly() && definition.isReadOnly()) {
            try (Statement stmt = con.createStatement()) {
                // 执行sql 类似事务隔离级别
                stmt.executeUpdate("SET TRANSACTION READ ONLY");
内部类 DataSourceTransactionObject
    private static class DataSourceTransactionObject extends JdbcTransactionObjectSupport {
         * 是否有新的链接
        private boolean newConnectionHolder;
         * 是否自动提交
        private boolean mustRestoreAutoCommit;
  • abstract 修饰具体定义的方法不具体展开。主要关注实现org.springframework.transaction.PlatformTransactionManager的几个方法
commit 方法
@Override
public final void commit(TransactionStatus status) throws TransactionException {
   if (status.isCompleted()) {
            "Transaction is already completed - do not call commit or rollback more than once per transaction");
   // 事务状态
   DefaultTransactionStatus defStatus = (DefaultTransactionStatus) status;
   if (defStatus.isLocalRollbackOnly()) {
      if (defStatus.isDebug()) {
         logger.debug("Transactional code has requested rollback");
      // 处理回滚
      processRollback(defStatus, false);
      return;
   if (!shouldCommitOnGlobalRollbackOnly() && defStatus.isGlobalRollbackOnly()) {
         logger.debug(
               "Global transaction is marked as rollback-only but transactional code requested commit");
      // 处理回滚
      processRollback(defStatus, true);
      return;
   // 真正的处理提交
   processCommit(defStatus);
private void processCommit(DefaultTransactionStatus status) throws TransactionException {
   try {
      boolean beforeCompletionInvoked = false;
      try {
         boolean unexpectedRollback = false;
         prepareForCommit(status);
         triggerBeforeCommit(status);
         triggerBeforeCompletion(status);
         // 前置任务是否已经执行
         beforeCompletionInvoked = true;
         // 嵌套事务. 是否有保存点
         if (status.hasSavepoint()) {
               logger.debug("Releasing transaction savepoint");
            unexpectedRollback = status.isGlobalRollbackOnly();
            status.releaseHeldSavepoint();
         } else if (status.isNewTransaction()) {
               logger.debug("Initiating transaction commit");
            doCommit(status);
         } else if (isFailEarlyOnGlobalRollbackOnly()) {
         // Throw UnexpectedRollbackException if we have a global rollback-only
         // marker but still didn't get a corresponding exception from commit.
         if (unexpectedRollback) {
            throw new UnexpectedRollbackException(
                  "Transaction silently rolled back because it has been marked as rollback-only");
      } catch (UnexpectedRollbackException ex) {
         // can only be caused by doCommit
         // 事务的同步状态: 回滚
         triggerAfterCompletion(status, TransactionSynchronization.STATUS_ROLLED_BACK);
         throw ex;
      } catch (TransactionException ex) {
         // 提交失败 做回滚
         if (isRollbackOnCommitFailure()) {
            doRollbackOnCommitException(status, ex);
            // 事务的同步状态: 未知
            triggerAfterCompletion(status, TransactionSynchronization.STATUS_UNKNOWN);
         throw ex;
         if (!beforeCompletionInvoked) {
         throw ex;
      // Trigger afterCommit callbacks, with an exception thrown there
      // propagated to callers but the transaction still considered as committed.
      try {
         triggerAfterCommit(status);
      } finally {
         triggerAfterCompletion(status, TransactionSynchronization.STATUS_COMMITTED);
   } finally {
      // 完成后清理
      cleanupAfterCompletion(status);
rollback 方法
@Override
public final void rollback(TransactionStatus status) throws TransactionException {
   // 是否已完成
   // 执行回滚
private void processRollback(DefaultTransactionStatus status, boolean unexpected) {
   try {
      boolean unexpectedRollback = unexpected;
      try {
         // 嵌套事务
               logger.debug("Rolling back transaction to savepoint");
            // 回滚保存点
            status.rollbackToHeldSavepoint();
         // 独立事务
               logger.debug("Initiating transaction rollback");
            // 执行回滚
            doRollback(status);
            // Participating in larger transaction
            if (status.hasTransaction()) {
               if (status.isLocalRollbackOnly()
                     || isGlobalRollbackOnParticipationFailure()) {
                     logger.debug(
                           "Participating transaction failed - marking existing transaction as rollback-only");
                  // 设置回滚
                  doSetRollbackOnly(status);
                     logger.debug(
                           "Participating transaction failed - letting transaction originator decide on rollback");
               logger.debug(
                     "Should roll back transaction but cannot - no transaction available");
            // Unexpected rollback only matters here if we're asked to fail early
            if (!isFailEarlyOnGlobalRollbackOnly()) {
         throw ex;
      // Raise UnexpectedRollbackException if we had a global rollback-only marker
               "Transaction rolled back because it has been marked as rollback-only");
   } finally {
  • 事务同步管理器
  • 一些基本属性
     * 资源
    private static final ThreadLocal<Map<Object, Object>> resources =
            new NamedThreadLocal<>("Transactional resources");
     * 同步器
    private static final ThreadLocal<Set<TransactionSynchronization>> synchronizations =
            new NamedThreadLocal<>("Transaction synchronizations");
     * 事务名称
    private static final ThreadLocal<String> currentTransactionName =
            new NamedThreadLocal<>("Current transaction name");
     * 是否只读
    private static final ThreadLocal<Boolean> currentTransactionReadOnly =
            new NamedThreadLocal<>("Current transaction read-only status");
     * 事务隔离级别
    private static final ThreadLocal<Integer> currentTransactionIsolationLevel =
            new NamedThreadLocal<>("Current transaction isolation level");
     * 事务激活状态
    private static final ThreadLocal<Boolean> actualTransactionActive =
            new NamedThreadLocal<>("Actual transaction active");Copy to clipboardErrorCopied
资源方法
获取资源
public static Map<Object, Object> getResourceMap() {
   // 线程变量中获取
   Map<Object, Object> map = resources.get();
   // 判空 如果为空给个空map如果有就返回
   return (map != null ? Collections.unmodifiableMap(map) : Collections.emptyMap());
判断是否存在资源
public static boolean hasResource(Object key) {
   // 资源key获取
   // 通过 unwrapResourceIfNecessary 会走一次资源对象转换.
   // 1. InfrastructureProxy
   // 2. ScopedObject
   Object actualKey = TransactionSynchronizationUtils.unwrapResourceIfNecessary(key);
   Object value = doGetResource(actualKey);
   return (value != null);
  • unwrapResourceIfNecessary方法会将资源具体化到接口,从接口中调用方法获取具体的资源
    static Object unwrapResourceIfNecessary(Object resource) {
       Assert.notNull(resource, "Resource must not be null");
       Object resourceRef = resource;
       // unwrap infrastructure proxy
       if (resourceRef instanceof InfrastructureProxy) {
          resourceRef = ((InfrastructureProxy) resourceRef).getWrappedObject();
       if (aopAvailable) {
          // now unwrap scoped proxy
          resourceRef = ScopedProxyUnwrapper.unwrapIfNecessary(resourceRef);
       return resourceRef;
        private static class ScopedProxyUnwrapper {
            public static Object unwrapIfNecessary(Object resource) {
                if (resource instanceof ScopedObject) {
                    return ((ScopedObject) resource).getTargetObject();
                    return resource;
  • doGetResource 方法去获取资源
    @Nullable
    private static Object doGetResource(Object actualKey) {
       if (map == null) {
          return null;
       Object value = map.get(actualKey);
       // Transparently remove ResourceHolder that was marked as void...
       // 如果资源是下面两种的其中一个就删除这个资源
       if (value instanceof ResourceHolder && ((ResourceHolder) value).isVoid()) {
          map.remove(actualKey);
          // Remove entire ThreadLocal if empty...
          if (map.isEmpty()) {
             resources.remove();
          value = null;
       return value;
资源绑定
public static void bindResource(Object key, Object value) throws IllegalStateException {
   // 将资源转换为正真的key
   Assert.notNull(value, "Value must not be null");
   // set ThreadLocal Map if none found
   // 资源对象为空初始化
   if (map == null) {
      map = new HashMap<>();
      resources.set(map);
   // 原来的值
   Object oldValue = map.put(actualKey, value);
   // Transparently suppress a ResourceHolder that was marked as void...
   // 如果原来的值是下面的两种 抛出异常
   if (oldValue instanceof ResourceHolder && ((ResourceHolder) oldValue).isVoid()) {
      oldValue = null;
   if (oldValue != null) {
      throw new IllegalStateException("Already value [" + oldValue + "] for key [" +
            actualKey + "] bound to thread [" + Thread.currentThread().getName() + "]");
      logger.trace("Bound value [" + value + "] for key [" + actualKey + "] to thread [" +
  • debug 使用的是 druid 的数据
  • unwrapResourceIfNecessary 方法
   if (aopAvailable) {
   return resourceRef;
显然com.alibaba.druid.pool.DruidDataSource不是InfrastructureProxy
  • aopAvailable
    private static final boolean aopAvailable = ClassUtils.isPresent(
          "org.springframework.aop.scope.ScopedObject",
          TransactionSynchronizationUtils.class.getClassLoader());Copy to clipboardErrorCopied
    public static boolean isPresent(String className, @Nullable ClassLoader classLoader) {
       try {
          forName(className, classLoader);
          return true;
       catch (IllegalAccessError err) {
          throw new IllegalStateException("Readability mismatch in inheritance hierarchy of class [" +
                className + "]: " + err.getMessage(), err);
          // Typically ClassNotFoundException or NoClassDefFoundError...
          return false;
    看是否可以解析如果解析成功返回true 解析失败返回false
  • ScopedProxyUnwrapper.unwrapIfNecessary
             return resource;
    • com.alibaba.druid.pool.DruidDataSource不是ScopedObject 直接返回
后续就是一个map的put方法不具体展开
解除资源绑定
public static Object unbindResource(Object key) throws IllegalStateException {
   // 获取真正的资源对象
   // map 移除key
   Object value = doUnbindResource(actualKey);
   if (value == null) {
            "No value for key [" + actualKey + "] bound to thread [" + Thread
   return value;
    @Nullable
    private static Object doUnbindResource(Object actualKey) {
        if (map == null) {
            return null;
        Object value = map.remove(actualKey);
            resources.remove();
            value = null;
        if (value != null && logger.isTraceEnabled()) {
            logger.trace("Removed value [" + value + "] for key [" + actualKey + "] from thread [" +
        return value;
map 对象的 remove 操作
其他
  • 其他几个都是使用ThreadLocal进行数据设置操作即可.
TransactionTemplate
  • 属性
        @Nullable
        private PlatformTransactionManager transactionManager;
    前文说到 DataSourceTransactionManager 实现了 PlatformTransactionManager 因此配置的时候我们有如下片段
    <bean id="transactionTemplate"
          class="org.springframework.transaction.support.TransactionTemplate">
       <property name="transactionManager" ref="transactionManager"/>
  • 事务操作模板类图
  • org.springframework.beans.factory.InitializingBean接口的实现
    @Override
            if (this.transactionManager == null) {
                throw new IllegalArgumentException("Property 'transactionManager' is required");
execute
   @Override
   @Nullable
   public <T> T execute(TransactionCallback<T> action) throws TransactionException {
      Assert.state(this.transactionManager != null, "No PlatformTransactionManager set");
      // 事务管理是否是 xxx接口
      if (this.transactionManager instanceof CallbackPreferringPlatformTransactionManager) {
//       强转执行
         return ((CallbackPreferringPlatformTransactionManager) this.transactionManager)
               .execute(this, action);
         // 获取事务状态
         TransactionStatus status = this.transactionManager.getTransaction(this);
         // 返回结果
         T result;
         try {
            // 事务回调执行
            result = action.doInTransaction(status);
            // Transactional code threw application exception -> rollback
            // 回滚异常
            rollbackOnException(status, ex);
            throw ex;
            // Transactional code threw unexpected exception -> rollback
            // 回滚异常
            throw new UndeclaredThrowableException(ex,
                  "TransactionCallback threw undeclared checked exception");
         // 提交
         this.transactionManager.commit(status);
         return result;
