GEE云平台——Landsat8系列和使用图像所需的相关质量信息
此星光明 发表于 2022/10/31 09:38:24 2022/10/31
【摘要】 ​ This chapter provides an overview of the Landsat collections and relevant quality information necessary for using the imagery.本节概述了Landsat8系列和使用图像所需的相关质量信息。Landsat platform.Landsat processing tie...
Landsat platform.
Landsat processing tiers.
Landsat 8
Landsat 8 collection.
Surface Reflectance (SR)
  • USGS Landsat 8 Surface Reflectance Tier 1
  • USGS Landsat 8 Surface Reflectance Tier 2
Top of Atmosphere (TOA)
  • USGS Landsat 8 Collection 1 Tier 1 TOA Reflectance
  • USGS Landsat 8 Collection 1 Tier 1 and Real-Time data TOA Reflectance
  • USGS Landsat 8 Collection 1 Tier 2 TOA Reflectance
Raw Images
  • USGS Landsat 8 Collection 1 Tier 1 Raw Scenes
  • USGS Landsat 8 Collection 1 Tier 1 and Real-Time data Raw Scenes
  • USGS Landsat 8 Collection 1 Tier 2 Raw Scenes
Derived Datasets
  • Burned Area Index (BAI)
  • Enhanced Vegetation Index (EVI)
  • Normalized Difference Vegetation Index (NDVI)
  • Normalized Burn Ratio Thermal (NBRT)
  • Normalized Difference Snow Index (NDSI)
  • Normalized Difference Water Index (NDWI)
Specifications and Quality
Section 6 of the Landsat 8 Collection 1 (C1) Land Surface Reflectance Code (LaSRC) product guide provides information related to the SR specifications as well to the data quality measurements.
Surface Reflectance Specifications
Band Designation
Band Name
Data Type
Units
Range
Valid Range
Fill Value
Saturate Value
Scale Factor
ProductID_sr_band1
Band 1
16-Bit Signed Integer
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band2
Band 2
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band3
Band 3
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band4
Band 4
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band5
Band 5
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band6
Band 6
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_sr_band7
Band 7
Reflectance
-2000 - 16000
0 - 10000
-9999
20000
0.0001
ProductID_pixel_qa
Level 2 Quality Band
16-Bit Unsigned Integer
Bit Index
0 - 32768
0 - 32768
1 (Bit 0)
NA
NA
ProductID_sr_aerosol
Aerosol QA
8-Bit Unsigned Integer
Bit Index
0 - 255
0 - 255
NA
NA
NA
ProductID_radsat_qa
Radiometric Saturation QA
Bit Index
0 - 32768
0 - 32768
1 (Bit 0)
NA
NA
ProductID_MTL.txt
Level 1 Metadata File
NA
NA
NA
NA
NA
NA
NA
ProductID_ANG.txt
Level 1 Angle Coefficient File
NA
NA
NA
NA
NA
NA
NA
Pixel Quality Assessment (QA) Band
Bit
Bit Value
Cumulative Sum
Attribute
0
1
1
Fill
1
2
3
Clear
2
4
7
Water
3
8
15
Cloud Shadow
4
16
31
Snow
5
32
63
Cloud
6-7
64 / 128
127 / 255
Cloud Confidence
00 (0) = None
01 (1) = Low
10 (2) = Medium
11 (3) = High
8-9
256 / 512
511 / 1023
Cirrus Confidence
00 (0) = Not Set
01 (1) = Low from OLI Band 9 Reflectance
10 (2) = Medium from OLI Band 9 Reflectance (Not Used)
11 (3) = High from OLI Band 9 Reflectance
10
1024
2047
Terrain Occlusion
11
2048
4095
Unused
12
4096
8191
Unused
13
8192
16383
Unused
14
16384
32767
Unused
15
32768
655535
Unused
Attribute
Pixel Value
Fill
1
Clear
322, 386, 834, 898, 1346
Water
324, 388, 836, 900, 1348
Cloud Shadow
328, 392, 840, 904, 1350
Snow/Ice
336, 368, 400, 432, 848, 880, 912, 944, 1352
Cloud
352, 368, 416, 432, 480, 864, 880, 928, 944, 992
Low Confidence Cloud
322, 324, 328, 336, 352, 368, 834, 836, 840, 848, 864, 880
Medium Confidence Cloud
386, 388, 392, 400, 416, 432, 898, 900, 904, 928, 944
High Confidence Cloud
480, 992
Low Confidence Cirrus
322, 324, 328, 336, 352, 368, 386, 388, 392, 400, 416, 432, 480
High Confidence Cirrus
834, 836, 840, 848, 864, 880,898,900, 904, 912, 928, 944, 992
Terrain Occlusion
1346, 1348, 1350, 135
Radiometric Saturation QA Band
Bit
Bit Value
Cumulative Sum
Description
0
1
1
Data Fill Flag (0 valid data, 1 invalid data)
1
2
3
Band 1 Data Saturation Flag (0 valid data, 1 saturated data)
2
4
7
Band 2 Data Saturation Flag (0 valid data, 1 saturated data)
3
8
15
Band 3 Data Saturation Flag (0 valid data, 1 saturated data)
4
16
31
Band 4 Data Saturation Flag (0 valid data, 1 saturated data)
5
32
63
Band 5 Data Saturation Flag (0 valid data, 1 saturated data)
6
64
127
Band 6 Data Saturation Flag (0 valid data, 1 saturated data)
7
128
255
Band 7 Data Saturation Flag (0 valid data, 1 saturated data)
8
NA
NA
Not Used
9
512
1023
Band 9 Data Saturation Flag (0 valid data, 1 saturated data)
10
1024
2047
Band 10 Data Saturation Flag (0 valid data, 1 saturated data)
11
2048
4095
Band 11 Data Saturation Flag (0 valid data, 1 saturated data)
Surface Reflectance Aerosol Band
Bit
Bit Value
Cumulative Sum
Attribute
0
1
1
Fill
1
2
3
Valid Aerosol Retrieval (center pixel of 3x3 pixel window)
2
4
7
Water Pixel (or water pixel was used in the fill-the-window interpolation)
3
8
15
Cloud or Cirrus
4
16
31
Cloud Shadow
5
32
63
Non-center window pixel for which aerosol was interpolated from surrounding 3x3 window center pixels
6-7
64 / 128
127 / 255
Aerosol Level
00 (0) = Climatology
01 (1) = Low
10 (2) = Medium
11 (3) = High
Attribute
Pixel Value
Fill
1
Valid Aerosol Retrieval (center pixel of 3x3 window)
2,66, 130, 194
4, 68, 100, 132, 164, 196, 228
Cloud or Cirrus
8, 72, 136, 200
Cloud Shadow
16, 80, 144, 208
Non-center window pixel for which aerosol was interpolated from surrounding 3x3 center pixels
32, 96, 100, 160, 164, 224, 228
Low-level aerosol
66, 68, 72, 80, 96, 100
Medium-level aerosol
130, 132, 136, 144, 160, 164
High-level aerosol
194, 196, 200, 208, 224, 228
​往期推荐:​
