云原生(四十) | Kubernetes篇之整合EFK
Lansonli 发表于 2022/10/31 00:19:40 2022/10/31
【摘要】 ​整合EFK部署前预习ElasticSearch 的 配置文件位置简单的ElasticSearch 配置管理章节ElasticStack 安装kompose 转换 compose为k8s文件kubectl get pvc -n devops| grep es | awk '{print $1}' | xargs kubectl delete pvc -n devops使用Es官方Operat...
​整合EFK
部署前预习
使用Es官方Operator方式
一、安装operator
Quickstart | Elastic Cloud on Kubernetes [2.4] | Elastic
kubectl apply -f https://download.elastic.co/downloads/eck/1.6.0/all-in-one.yaml
#查看状态
kubectl -n elastic-system logs -f statefulset.apps/elastic-operator
ECK安装的每个组件如何配置
二、部署ES集群
apiVersion: elasticsearch.k8s.elastic.co/v1
kind: Elasticsearch
metadata:
  # 可以指定名称空间
spec:
  version: 7.13.1
  nodeSets:
  - name: masters
    count: 3
    config:
      node.roles: ["master"]
      xpack.ml.enabled: true
    volumeClaimTemplates:
    - metadata:
      spec:
        accessModes:
        - ReadWriteOnce
        resources:
          requests:
            storage: 5Gi
        storageClassName: "rook-ceph-block"
  - name: data
    count: 4
    config:
      node.roles: ["data", "ingest", "ml", "transform"]
    - metadata:
      spec:
        accessModes:
        - ReadWriteOnce
        resources:
          requests:
            storage: 5Gi
测试访问 Deploy an Elasticsearch cluster | Elastic Cloud on Kubernetes [2.4] | Elastic
1、本地访问密码测试
## elastic的访问
kubectl get secret es-cluster-es-elastic-user -o=jsonpath='{.data.elastic}' | base64 --decode; echo
## 1、集群内组件访问
###账号 elastic
###密码 t5upEg4l5J37629558659y8Ww
curl -u "elastic:2WC5On8Xio6E767K4x4ph1T7Q54" -k "https://es-cluster-es-http:9200"
curl -u "elastic:2WC5On8Xio6E767K4x4ph1T7Q54" -k "https://10.96.9.9:9200"
## 2、集群本地访问
kubectl port-forward service/es-cluster-es-http 9200
curl -u "elastic:$PASSWORD" -k "https://localhost:9200"
## 3、做成下面的Ingress访问
2、部署ingress访问
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  annotations:
    kubernetes.io/ingress.class: "nginx"
    nginx.ingress.kubernetes.io/backend-protocol: "HTTPS"
    nginx.ingress.kubernetes.io/server-snippet: |
      proxy_ssl_verify off;
spec:
  tls:
  - hosts:
      - elastic.it.com
    secretName: it.com
  rules:
  - host: elastic.it.com
    http:
      paths:
      - path: /
        pathType: Prefix
        backend:
          service:
            port:
              number: 9200
三、部署kibana
apiVersion: kibana.k8s.elastic.co/v1
kind: Kibana
metadata:
spec:
  version: 7.13.1
  count: 1
  elasticsearchRef:
1、访问密码
### 账号  elastic
### 密码  618FAZBH5a26990707098798798
###登录即可
2、配置Ingress
kind: Ingress
metadata:
  annotations:
spec:
  tls:
  - hosts:
      - kibana.it.com
    secretName: it.com
  rules:
  - host: kibana.it.com
    http:
      paths:
      - path: /
        pathType: Prefix
        backend:
          service:
            port:
              number: 5601
四、部署FileBeats
apiVersion: beat.k8s.elastic.co/v1beta1
kind: Beat
metadata:
spec:
  type: filebeat
  version: 7.13.1
  elasticsearchRef:
  config:
    filebeat.inputs:
    - type: container
      paths:
      - /var/log/containers/*.log
  daemonSet:
    podTemplate:
      spec:
        dnsPolicy: ClusterFirstWithHostNet
        hostNetwork: true
        securityContext:
          runAsUser: 0
        containers:
        - name: filebeat
          volumeMounts:
          - name: varlogcontainers
            mountPath: /var/log/containers
          - name: varlogpods
            mountPath: /var/log/pods
          - name: varlibdockercontainers
            mountPath: /var/lib/docker/containers
        volumes:
          hostPath:
            path: /var/log/containers
        - name: varlogpods
          hostPath:
            path: /var/log/pods
          hostPath:
            path: /var/lib/docker/containers
