云原生(三十八) | Kubernetes篇之Jenkins入门和安装
Lansonli 发表于 2022/10/30 11:09:59 2022/10/30
【摘要】 ​Jenkins入门和安装一、helm安装#可定制镜像FROM jenkins/jenkins:ltsRUN jenkins-plugin-cli --plugins kubernetes workflow-aggregator git configuration-as-code#helm 安装helm repo add jenkinsci https://charts.jenkins.io...
​Jenkins入门和安装
一、helm安装
#可定制镜像
#helm 安装
helm repo add jenkinsci https://charts.jenkins.io/
helm pull jenkinsci/jenkins --version 3.3.18
controller:
  componentName: "jenkins-controller"
  image: "jenkinsci/blueocean"
  tag: "1.24.7"
  imagePullPolicy: "Always"
  adminSecret: true
  adminUser: "admin"
  adminPassword: "admin"
  servicePort: 8080
  targetPort: 8080
  serviceType: ClusterIP
  healthProbes: true
  probes:
    startupProbe:
      httpGet:
        path: '{{ default "" .Values.controller.jenkinsUriPrefix }}/login'
        port: http
      periodSeconds: 10
      timeoutSeconds: 5
      failureThreshold: 12
    livenessProbe:
      failureThreshold: 5
      httpGet:
        port: http
      periodSeconds: 10
      timeoutSeconds: 5
    readinessProbe:
      failureThreshold: 3
      httpGet:
        port: http
      periodSeconds: 10
      timeoutSeconds: 5
  agentListenerServiceType: "ClusterIP"
  installPlugins:
    - kubernetes:1.29.4
    - workflow-aggregator:2.6
    - git:4.7.1
    - configuration-as-code:1.51
  initializeOnce: true
  ingress:
    enabled: true
    paths:
    - backend:
        service:
            port:
              number: 8080
      path: "/"
      pathType: Prefix
    apiVersion: "networking.k8s.io/v1s"
    kubernetes.io/ingress.class: nginx
    hostName: jenkins.itlansonli.com
    tls:
    - secretName: itlansonli.com
      hosts:
        - jenkins.itlansonli.com
  prometheus:
    enabled: true
    scrapeInterval: 60s
    scrapeEndpoint: /prometheus
agent:
  enabled: true
  workspaceVolume:
     type: PVC
     claimName: jenkins-workspace-pvc
     readOnly: false
additionalAgents:
  maven:
    podName: maven
    customJenkinsLabels: maven
    image: jenkins/jnlp-agent-maven
persistence:
  enabled: true
  storageClass: "rook-ceph-block"
  accessMode: "ReadWriteOnce"
 openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout tls.key -out tls.cert -subj "/CN=*.itlansonli.com/O=*.itlansonli.com"
kubectl create ns devops
kubectl create secret tls itlansonli.com --key tls.key --cert tls.cert -n devops
helm install -f values.yaml -f override.yaml jenkins ./ -n devops
1. Get your 'admin' user password by running:
  kubectl exec --namespace devops -it svc/jenkins -c jenkins -- /bin/cat /run/secrets/chart-admin-password && echo
2. Visit http://jenkins.itlansonli.com
3. Login with the password from step 1 and the username: admin
4. Configure security realm and authorization strategy
5. Use Jenkins Configuration as Code by specifying configScripts in your values.yaml file, see documentation: http://jenkins.itlansonli.com/configuration-as-code and examples: https://github.com/jenkinsci/configuration-as-code-plugin/tree/master/demos
For more information on running Jenkins on Kubernetes, visit:
https://cloud.google.com/solutions/jenkins-on-container-engine
For more information about Jenkins Configuration as Code, visit:
https://jenkins.io/projects/jcasc/
NOTE: Consider using a custom image with pre-installed plugins
二、手动安装
#创建证书,或者使用以前的证书
openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout tls.key -out tls.crt -subj "/CN=*.itlansonli.com/O=*.itlansonli.com"
1、编写Jenkins配置文件
apiVersion: apps/v1
kind: StatefulSet
metadata:
  namespace: devops
spec:
  selector:
    matchLabels:
      app: jenkins # has to match .spec.template.metadata.labels
  serviceName: "jenkins"
  replicas: 1
  template:
    metadata:
      labels:
        app: jenkins # has to match .spec.selector.matchLabels
    spec:
      serviceAccountName: "jenkins"
      terminationGracePeriodSeconds: 10
      containers:
      - name: jenkins
        image: jenkinsci/blueocean:1.24.7
        securityContext:
          runAsUser: 0                      #设置以ROOT用户运行容器
          privileged: true                  #拥有特权
        ports:
        - containerPort: 8080
        - name: jnlp                        #jenkins slave与集群的通信口
          containerPort: 50000
        resources:
          limits:
            memory: 2Gi
            cpu: "2000m"
          requests:
            memory: 700Mi
            cpu: "500m"
        env:
        - name: LIMITS_MEMORY
          valueFrom:
            resourceFieldRef:
              resource: limits.memory
              divisor: 1Mi
        - name: "JAVA_OPTS" #设置变量,指定时区和 jenkins slave 执行者设置
          value: "
                   -Xmx$(LIMITS_MEMORY)m
                   -XshowSettings:vm
                   -Dhudson.slaves.NodeProvisioner.initialDelay=0
                   -Dhudson.slaves.NodeProvisioner.MARGIN=50
                   -Dhudson.slaves.NodeProvisioner.MARGIN0=0.75
                   -Duser.timezone=Asia/Shanghai
        volumeMounts:
        - name: home
          mountPath: /var/jenkins_home
  volumeClaimTemplates:
  - metadata:
    spec:
      accessModes: [ "ReadWriteOnce" ]
      storageClassName: "rook-ceph-block"
      resources:
        requests:
          storage: 5Gi
apiVersion: v1
kind: Service
metadata:
  namespace: devops
spec:
  selector:
    app: jenkins
  type: ClusterIP
  ports:
  - name: web
    port: 8080
    targetPort: 8080
    protocol: TCP
  - name: jnlp
    port: 50000
    targetPort: 50000
    protocol: TCP
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  namespace: devops
spec:
  tls:
  - hosts:
  rules:
  - host: jenkins.itlansonli.com
    http:
      paths:
      - path: /
        pathType: Prefix
        backend:
          service:
            port:
              number: 8080
apiVersion: v1
kind: ServiceAccount
metadata:
  namespace: devops
apiVersion: rbac.authorization.k8s.io/v1
kind: ClusterRole
metadata:
rules:
  - apiGroups: ["extensions", "apps"]
    resources: ["deployments"]
    verbs: ["create", "delete", "get", "list", "watch", "patch", "update"]
  - apiGroups: [""]
    resources: ["services"]
  - apiGroups: [""]
    resources: ["pods"]
    verbs: ["create","delete","get","list","patch","update","watch"]
  - apiGroups: [""]
    resources: ["pods/exec"]
  - apiGroups: [""]
    resources: ["pods/log"]
    verbs: ["get","list","watch"]
  - apiGroups: [""]
    resources: ["secrets"]
    verbs: ["get"]
kind: ClusterRoleBinding
metadata:
roleRef:
  kind: ClusterRole
  apiGroup: rbac.authorization.k8s.io
subjects:
- kind: ServiceAccount
  namespace: devops
2、安装核心插件
- kubernetes
- docker
#以上插件可能无法下载,可以手动去jenkins-plugins下载并上传.
kubectl cp /root/other/kubernetes-client-api.hpi devops/jenkins-0:/var/jenkins_home/plugins/
#配置镜像源
https://updates.jenkins.io/update-center.json   默认的
http://updates.jenkins-ci.org/update-center.json
#或者国内源
https://mirrors.tuna.tsinghua.edu.cn/jenkins/updates/update-center.json
3、配置集群整合
3.1、动态slave架构
3.2、配置整合
点击《系统管理》—>《Configure System》—>《配置一个云》—>《kubernetes》,如下:
3.3、配置kubernetes集群信息
3.4、配置slave的pod模板
Slave就是动态运行起来的容器环境.
jenkins的所有构建命令会在这个容器里面运行
  • 注意配置以下内容
    • 名称: 自定义
    • 命名空间 : devops
    • 标签列表: 自定义
    • 容器名称、镜像: jenkins/inbound-agent:4.7-1-alpine
    • serviceAccount挂载项: jenkins
    • 运行命令: 改为 jenkins-slave
注意:
  • jenkins-url如果是一个域名,测试环境下可能不能访问,此时需要给各个主机配置域名转发到vpc网络的ip
  • 修改各个主机的 /etc/hosts文件即可
  • 也可以直接设置jenkins-url为公网ip地址
4、测试动态slave
4.1、自由风格
4.2、流水线写法
pipeline {
    agent {
      label 'maven-jnlp-slave'
    stages {
        stage('Hello') {
            steps {
                echo 'Hello World'
5、配置更多的slave
slave-label
镜像
集成工具
maven
registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/jnlp-maven:3.6.3
jq、curl、maven
nodejs
registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/jnlp-nodejs:14.16.1
jq、curl、nodejs、npm(已经设置全局目录在 /root/npm下)
kubectl
registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/jnlp-kubectl:1.21.1
kubectl、helm、helm-push、jq、curl、
allin
registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/jnlp-all:v1.0
kubectl、helm、maven、nodejs、jq、curl
docker
registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/jnlp-docker:20.10.2
jq、curl、docker
根据自己环境可以有很多定制的slave
三、slave参考配置
下面的截图忘了选中 user,group 都应该为 0,0 也就是root用户
每个打包机都应该hostPath模式挂载/etc/hosts文件。方便统一域名管理。或者全系统内部都不用域名,都使用ip进行交互也可以【但是推荐域名,域名可以统一修改,ip变化所有引用的地方都来修改很麻烦】
1、maven配置
使用要求
  • 1、提前创建好maven的settings.xml,并且以configMap的形式保存到k8s集群的devops名称空间。configmap名叫maven-conf,里面有一个键名settings.xml,值为 maven配置文件的值
  • 2、准备名为maven-jar-pvc 的pvc 在 devops名称空间下。为RWX模式
  • 例如:
  • kubectl create configmap maven-conf --from-file=settings.xml=/root/settings.xml -n devops
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
namespace: devops
labels:
  app: maven-jar-pvc
spec:
storageClassName: rook-cephfs
accessModes:
- ReadWriteMany
resources:
requests:
storage: 5Gi
<settings xmlns="http://maven.apache.org/SETTINGS/1.0.0"
          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
          xsi:schemaLocation="http://maven.apache.org/SETTINGS/1.0.0 http://maven.apache.org/xsd/settings-1.0.0.xsd">
  <!-- 这个目录是被maven打包机使用pvc挂载出去的
  <localRepository>/root/maven/.m2</localRepository>
  <pluginGroups>
  </pluginGroups>
  <proxies>
  </proxies>
  <servers>
  </servers>
  <mirrors>
	 <mirror>
        <id>nexus-aliyun</id>
        <mirrorOf>central</mirrorOf>
        <name>Nexus aliyun</name>
        <url>http://maven.aliyun.com/nexus/content/groups/public</url>
	 </mirror>
  </mirrors>
  <profiles>
		<profile>
			 <id>jdk-1.8</id>
			 <activation>
			   <activeByDefault>true</activeByDefault>
			   <jdk>1.8</jdk>
			 </activation>
			 <properties>
			   <maven.compiler.source>1.8</maven.compiler.source>
			   <maven.compiler.target>1.8</maven.compiler.target>
			   <maven.compiler.compilerVersion>1.8</maven.compiler.compilerVersion>
			 </properties>
		</profile>
  </profiles>
</settings>
apiVersion: v1
metadata:
  namespace: devops
  labels:
    app: maven-jar-pvc
spec:
  accessModes:
  - ReadWriteMany
  resources:
    requests:
      storage: 5Gi
2、kubectl配置
在容器内 /root/.kube/config,config文件的内容是我们集群之前的admin.conf的内容
使用要求
  • 必须提前给集群创建一个ConfigMap,名叫 kubectl-admin.conf,里面有一个键名叫config,键值可以是master节点 /root/.kube/config的内容
  • 例如
  • kubectl create configmap kubectl-admin.conf --from-file=config=/root/.kube/config -n devops
3、nodejs配置
使用说明
  • 准备名为npm-modules-pvc 的pvc 在 devops名称空间下。为RWX模式
apiVersion: v1
metadata:
    namespace: devops
    labels:
       app: npm-modules-pvc
spec:
    accessModes:
    - ReadWriteMany
    resources:
       requests:
         storage: 5Gi
4、docker配置
使用注意:
  • docker访问harbor之类的私有仓库且是https,要注意配置证书受信任。提前各个机器配置好
四、示例流水线
1、打包机检查
pipeline {
    //无代理,各阶段声明自己的代理
    agent none
    stages {
        stage('检查nodejs打包机') {
            //使用nodejs代理
            agent {
                label 'nodejs'
            steps {
                echo "nodejs版本:"
                sh 'node -v'
                echo "npm modules目录位置"
                sh 'npm config ls -l | grep prefix'
                echo "检查完成..."
        stage('检查maven打包机') {
            //使用nodejs代理
            agent {
                label 'maven'
            steps {
                echo "maven版本:"
                sh 'mvn -v'
                echo "maven配置文件"
                sh 'cat /app/maven/settings.xml'
                echo "maven目录位置信息"
                sh 'ls -al /app/maven/'
        stage('检查docker打包机') {
            //使用nodejs代理
            agent {
                label 'docker'
            steps {
                echo "docker版本:"
                sh 'docker version'
                sh 'docker images'
        stage('检查kubectl打包机') {
            //使用nodejs代理
            agent {
                label 'kubectl'
            steps {
                echo "kubectl版本:"
                sh ' kubectl version'
                echo "kubectl操作集群: 所有Pod"
                sh 'kubectl get pods'
                echo "kubectl操作集群: 所有nodes"
                sh 'kubectl get nodes'
2、复杂流水线
2.1、java-Dockerfile模板
#这个也得有
FROM openjdk:8-jre-alpine
LABEL maintainer="xxxxx@qq.com"
#复制打好的jar包
COPY target/*.jar /app.jar
RUN  apk add -U tzdata; \
ln -sf /usr/share/zoneinfo/Asia/Shanghai /etc/localtime; \
echo 'Asia/Shanghai' >/etc/timezone; \
touch /app.jar;
ENV JAVA_OPTS=""
ENV PARAMS=""
EXPOSE 8080
ENTRYPOINT [ "sh", "-c", "java -Djava.security.egd=file:/dev/./urandom $JAVA_OPTS -jar /app.jar $PARAMS" ]
2.1、准备数据库镜像
FROM mysql:5.7
# 所有在 /docker-entrypoint-initdb.d 下的sql,数据库会自己初始化
COPY mall.sql /docker-entrypoint-initdb.d
2.2、准备示例项目
mall: mall项目是一套电商系统,包括前台商城系统及后台管理系统,基于SpringBoot+MyBatis实现,采用Docker容器化部署。 前台商城系统包含首页门户、商品推荐、商品搜索、商品展示、购物车、订单流程、会员中心、客户服务、帮助中心等模块。 后台管理系统包含商品管理、订单管理、会员管理、促销管理、运营管理、内容管理、统计报表、财务管理、权限管理、设置等模块。
