编程事务之基于注解的声明式事务控制
执久呀 发表于 2022/10/27 16:09:21 2022/10/27
【摘要】 ​基于注解的声明式事务控制使用注解方式(改动bean,自定义的bean用注解,非自定义的bean配置到配置文件中去),需要改动两个,一个是配置文件applicationContext,另一个是AccountServiceImpl类package com_1.service.impl;import com.dao.AccountDao;import com.service.AccountSer...
基于注解的声明式事务控制
import com.service.AccountService;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Service;
import org.springframework.transaction.annotation.Isolation;
import org.springframework.transaction.annotation.Propagation;
import org.springframework.transaction.annotation.Transactional;
@Service("accountService")
//在类上使用事务,其中的所有方法都会生效
@Transactional(isolation = Isolation.REPEATABLE_READ)
public class AccountServiceImpl implements AccountService {
    @Autowired
    private AccountDao accountDao;
    @Transactional(isolation = Isolation.READ_COMMITTED,propagation = Propagation.REQUIRED)
    public void transfer(String outMan, String inMan, double money) {
        accountDao.out(outMan,money);
        accountDao.in(inMan,money);
applicationContext配置文件
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:aop="http://www.springframework.org/schema/aop"
       xmlns:context="http://www.springframework.org/schema/context"
       xmlns:tx="http://www.springframework.org/schema/tx"
       xsi:schemaLocation="
       http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
       http://www.springframework.org/schema/aop http://www.springframework.org/schema/aop/spring-aop.xsd
       http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx.xsd
       http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd
    <!--组件扫描,才能扫到@Service注解-->
    <context:component-scan base-package="com_1"/>
    <bean id="dataSource" class="com.mchange.v2.c3p0.ComboPooledDataSource">
        <property name="driverClass" value="com.mysql.jdbc.Driver"/>
        <property name="jdbcUrl" value="jdbc:mysql://localhost:3306/test"/>
        <property name="user" value="root"/>
        <property name="password" value="123456"/>
    </bean>
    <bean id="jdbcTemplate" class="org.springframework.jdbc.core.JdbcTemplate">
        <property name="dataSource" ref="dataSource"/>
    </bean>
    <bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
    </bean>
    <!--事务的注解驱动,不写就没开启事务-->
    <tx:annotation-driven transaction-manager="transactionManager"/>
</beans>
运行结果
编辑
 注解配置声明式事务控制解析
①使用@Transactional在需要进行事务控制的类或是方法上修饰,注解可用的属性同xml配置方式,例如隔离级别、传播行为等。
②注解使用在类上,那么该类下的所有方法都使用同一套注解参数配置
③使用在方法上,不同的方法可以采用不同的事务参数配置。
④xml配置文件中要开启事务的注解驱动<tx:annotation-driven/>
配置要点
平台事务管理器配置(xml方式)
事务通知的配置(@Transactional注解)
事务注解驱动的配置<tx:annotation-driven/>
