GEE数据集——瑞士0.1米超清分辨率影像数据
此星光明 发表于 2022/10/25 17:39:39 2022/10/25
【摘要】 ​ The SWISSIMAGE 10 cm orthophoto mosaic is an assembly of new color digital aerial images over the whole of Switzerland with a ground resolution of 10 cm in the plains and the main alpine valleys ...
 The SWISSIMAGE 10 cm orthophoto mosaic is an assembly of new color digital aerial images over the whole of Switzerland with a ground resolution of 10 cm in the plains and the main alpine valleys and 25 cm in the Alps. It is updated annually.
For more information, please see the SWISSIMAGE10cm_FR documentation
This RGB collection contains digital aerial images with three bands. Standard deviation for the precision in position: +/- 0.15 m for the ground sample distance of 0.1 m.
SWISSIMAGE 10厘米正射影像马赛克是整个瑞士新的彩色数字航空图像的组合,其地面分辨率在平原和主要高山峡谷为10厘米,在阿尔卑斯山为25厘米。它每年都会更新。
欲了解更多信息,请参见SWISSIMAGE10cm_FR文件。
这个RGB系列包含有三个波段的数字航空图像。位置精度的标准偏差。地面采样距离为0.1米,+/- 0.15米。
Dataset Availability
2017-01-01T00:00:00Z–2021-01-01T00:00:00
Dataset Provider
Topography swisstopo
影像集合代码:
ee.ImageCollection("ORTHO/Switzerland/SWISSIMAGE/10cm")
 波段:
Resolution
0.1 meters
Bands
Name Min Max Wavelength Description
R 0 255 619-651nm
Red
G 0 255 525-585nm
Green
B 0 255 435-495nm
Blue
代码:
var dataset = ee.Image('ORTHO/Switzerland/SWISSIMAGE/10cm/2017');
Map.setCenter(7.75, 46.02, 18);
Map.addLayer(dataset, null, 'Switzerland 10 cm');
使用说明:
Terms of Use
The free geodata and geoservices of swisstopo may be used, distributed and made accessible. Furthermore, they may be enriched and processed and also used commercially.
swisstopo的免费地理数据和地理服务可以被使用、传播和获取。此外,它们还可以被充实和处理,也可用于商业用途。
A reference to the source is mandatory. please see the Terms of use
数据引用:
Citations:
  • Copyright Federal Office of Topography swisstopo
 影像结果:
