湖仓一体电商项目(二十):业务实现之编写写入DM层业务代码
Lansonli 发表于 2022/10/24 08:33:20 2022/10/24
【摘要】 ​业务实现之编写写入DM层业务代码DM层主要是报表数据,针对实时业务将DM层设置在Clickhouse中,在此业务中DM层主要存储的是通过Flink读取Kafka “KAFKA-DWS-BROWSE-LOG-WIDE-TOPIC” topic中的数据进行设置窗口分析,每隔10s设置滚动窗口统计该窗口内访问商品及商品一级、二级分类分析结果,实时写入到Clickhouse中。一、​​​​​​​​...
​业务实现之编写写入DM层业务代码
一、​​​​​​​​​​​​​​代码编写
具体代码参照“ProcessBrowseLogInfoToDM.scala”,大体代码逻辑如下:
object ProcessBrowseLogInfoToDM {
  def main(args: Array[String]): Unit = {
    //1.准备环境
    val env: StreamExecutionEnvironment = StreamExecutionEnvironment.getExecutionEnvironment
    val tblEnv: StreamTableEnvironment = StreamTableEnvironment.create(env)
    env.enableCheckpointing(5000)
    import org.apache.flink.streaming.api.scala._
      * 2.创建 Kafka Connector,连接消费Kafka dwd中数据
    tblEnv.executeSql(
        |create table kafka_dws_user_login_wide_tbl (
        |   user_id string,
        |   product_name string,
        |   first_category_name string,
        |   second_category_name string,
        |   obtain_points string
        |) with (
        | 'connector' = 'kafka',
        | 'topic' = 'KAFKA-DWS-BROWSE-LOG-WIDE-TOPIC',
        | 'properties.bootstrap.servers'='node1:9092,node2:9092,node3:9092',
        | 'scan.startup.mode'='earliest-offset', --也可以指定 earliest-offset 、latest-offset
        | 'properties.group.id' = 'my-group-id',
        | 'format' = 'json'
      """.stripMargin)
      * 3.实时统计每个用户最近10s浏览的商品次数和商品一级、二级种类次数,存入到Clickhouse
    val dwsTbl:Table = tblEnv.sqlQuery(
        | select user_id,product_name,first_category_name,second_category_name from kafka_dws_user_login_wide_tbl
      """.stripMargin)
    //4.将Row 类型数据转换成对象类型操作
    val browseDS: DataStream[BrowseLogWideInfo] = tblEnv.toAppendStream[Row](dwsTbl)
      .map(row => {
        val user_id: String = row.getField(0).toString
        val product_name: String = row.getField(1).toString
        val first_category_name: String = row.getField(2).toString
        val second_category_name: String = row.getField(3).toString
        BrowseLogWideInfo(null, user_id, null, product_name, null, null, first_category_name, second_category_name, null)
    val dwsDS: DataStream[ProductVisitInfo] = browseDS.keyBy(info => {
      info.first_category_name + "-" + info.second_category_name + "-" + info.product_name
      .timeWindow(Time.seconds(10))
      .process(new ProcessWindowFunction[BrowseLogWideInfo, ProductVisitInfo, String, TimeWindow] {
        override def process(key: String, context: Context, elements: Iterable[BrowseLogWideInfo], out: Collector[ProductVisitInfo]): Unit = {
          val currentDt: String = DateUtil.getDateYYYYMMDD(context.window.getStart.toString)
          val startTime: String = DateUtil.getDateYYYYMMDDHHMMSS(context.window.getStart.toString)
          val endTime: String = DateUtil.getDateYYYYMMDDHHMMSS(context.window.getEnd.toString)
          val arr: Array[String] = key.split("-")
          val firstCatName: String = arr(0)
          val secondCatName: String = arr(1)
          val productName: String = arr(2)
          val cnt: Int = elements.toList.size
          out.collect(ProductVisitInfo(currentDt, startTime, endTime, firstCatName, secondCatName, productName, cnt))
      * 5.将以上结果写入到Clickhouse表 dm_product_visit_info 表中
      *  create table dm_product_visit_info(
      *    current_dt String,
      *    window_start String,
      *    window_end String,
      *    first_cat String,
      *    second_cat String,
      *    product String,
      *    product_cnt UInt32
      *  ) engine = MergeTree() order by current_dt
    //准备向ClickHouse中插入数据的sql
    val insertIntoCkSql = "insert into dm_product_visit_info (current_dt,window_start,window_end,first_cat,second_cat,product,product_cnt) values (?,?,?,?,?,?,?)"
    val ckSink: SinkFunction[ProductVisitInfo] = MyClickHouseUtil.clickhouseSink[ProductVisitInfo](insertIntoCkSql,new JdbcStatementBuilder[ProductVisitInfo] {
      override def accept(pst: PreparedStatement, productVisitInfo: ProductVisitInfo): Unit = {
        pst.setString(1,productVisitInfo.currentDt)
        pst.setString(2,productVisitInfo.windowStart)
        pst.setString(3,productVisitInfo.windowEnd)
        pst.setString(4,productVisitInfo.firstCat)
        pst.setString(5,productVisitInfo.secondCat)
        pst.setString(6,productVisitInfo.product)
        pst.setLong(7,productVisitInfo.productCnt)
    //针对数据加入sink
    dwsDS.addSink(ckSink)
    env.execute()
二、创建Clickhouse-DM层表
代码在执行之前需要在Clickhouse中创建对应的DM层商品浏览信息表dm_product_visit_info,clickhouse建表语句如下:
#node1节点启动clickhouse
[root@node1 bin]# service clickhouse-server start
#node1节点进入clickhouse
[root@node1 bin]# clickhouse-client -m
#node1节点创建clickhouse-DM层表
 current_dt String,
 window_end String,
 first_cat String,
 second_cat String,
 product String,
 product_cnt UInt32
) engine = MergeTree() order by current_dt;
三、代码测试
以上代码编写完成后,代码执行测试步骤如下:
1、将代码中消费Kafka数据改成从头开始消费
代码中Kafka Connector中属性“scan.startup.mode”设置为“earliest-offset”,从头开始消费数据。
这里也可以不设置从头开始消费Kafka数据,而是直接启动向日志采集接口模拟生产日志代码“RTMockUserLogData.java”,需要启动日志采集接口及Flume。
2、执行代码,查看对应结果
以上代码执行后在,在Clickhouse-DM层中表“dm_product_visit_info”中查看对应数据结果如下:
