解决 error: failed to push some refs to 'https://github.com/
timerring 发表于 2022/10/21 15:09:49 2022/10/21
【摘要】 Resolve error: failed to push some refs to 'https://github.com/报错:! [rejected] main -> main (fetch first)error: failed to push some refs to ‘https://github.com/XXX.git’原因:远程库和本地库不一致。通常出现在初始...
报错:
原因:远程库和本地库不一致。通常出现在初始化仓库有readme而本地没有等情况。
提示:git的提示同上。
hint: Updates were rejected because the remote contains work that you do
hint: not have locally. This is usually caused by another repository pushing
hint: to the same ref. You may want to first integrate the remote changes
hint: (e.g., ‘git pull …’) before pushing again.
hint: See the ‘Note about fast-forwards’ in ‘git push --help’ for details.
解决方法:
git pull --rebase origin master
原理:
把远程库中的更新合并到本地库中,–-rebase的作用是取消掉本地库中刚刚的commit,并把他们接到更新后的版本库之中。然后再进行push即可。
git pull -–rebase origin master 操作,意为先取消commit记录,并且把它们临时保存为补丁(patch)(这些补丁在”.git/rebase”目录中),之后同步远程库到本地,最后合并补丁到本地库之中。
注意:距离上次push提交至今,在本地库commit的记录均暂存为patch。
