探索Pulsar之使用Go和Java操作Pulsar
1 前言
Pulsar官方支持的客户端库:
- C++
- Python
- WebSocket
- Go client
- Node.js
- C#
- Java
GitHub中三方的客户端库:
- Go
- Haskell
- Scala
- Rust
- .NET
- Node.js
具体可参看:https://pulsar.apache.org/docs/zh-CN/next/client-libraries/
本次仅演示Go和Java的客户端操作。
2 单机模式运行Pulsar
[root@iZ2ze4m2 bin]# pwd
/root/apache-pulsar-2.10.0/bin
[root@iZ2ze4m2 bin]# ./pulsar standalone
PS:针对单机启动报错问题,如下面的:
可以尝试使用该命令进行启动:
./pulsar standalone -nss
3 Go客户端操作Pulsar
(1)添加依赖
go get -u "github.com/apache/pulsar-client-go/pulsar"
(2)生产者
package main
import (
"context"
"fmt"
"log"
"time"
func main() {
client, err := pulsar.NewClient(pulsar.ClientOptions{
URL: "pulsar://192.168.71.143:6650", //支持:"pulsar://localhost:6650,localhost:6651,localhost:6652"
OperationTimeout: 60 * time.Second,
ConnectionTimeout: 60 * time.Second,
defer client.Close()
if err != nil {
log.Fatalf("Could not instantiate Pulsar client: %v", err)
producer, err := client.CreateProducer(pulsar.ProducerOptions{
Topic: "my-topic",
if err != nil {
log.Fatal(err)
_, err = producer.Send(context.Background(), &pulsar.ProducerMessage{
Payload: []byte("hello"),
defer producer.Close()
if err != nil {
fmt.Println("Failed to publish message", err)
fmt.Println("Published message")
(3)消费者
package main
import (
"context"
"fmt"
"log"
"time"
func main() {
if err != nil {
consumer, err := client.Subscribe(pulsar.ConsumerOptions{
Topic: "my-topic",
SubscriptionName: "my-sub",
Type: pulsar.Shared,
if err != nil {
log.Fatal(err)
defer consumer.Close()
for i := 0; i < 10; i++ {
msg, err := consumer.Receive(context.Background())
if err != nil {
log.Fatal(err)
fmt.Printf("Received message msgId: %#v -- content: '%s'\n",
msg.ID(), string(msg.Payload()))
consumer.Ack(msg)
if err := consumer.Unsubscribe(); err != nil {
log.Fatal(err)
4 Java&Spring客户端操作Pulsar
4.1 Java客户端
(1)pom依赖
<properties>
<pulsar.version>2.9.1</pulsar.version>
</properties>
<dependencies>
<dependency>
<groupId>org.apache.pulsar</groupId>
<artifactId>pulsar-client</artifactId>
<version>${pulsar.version}</version>
</dependency>
</dependencies>
(2)生产者和消费者
class SbPursarApplicationTests {
private PulsarClient client;
private void init() throws PulsarClientException {
client = PulsarClient.builder()
.serviceUrl("pulsar://192.168.71.147:6650")
.build();
@Test
void producer() throws Exception {
init();
Producer<byte[]> producer = client.newProducer()
.topic("my-topic")
.create();
// 然后你就可以发送消息到指定的broker 和topic上:
producer.send("My message".getBytes());
client.close();
@Test
void consumer() throws PulsarClientException {
init();
Consumer consumer = client.newConsumer()
.topic("my-topic")
.subscriptionName("my-subscription")
.subscribe();
while (true) {
Message msg = consumer.receive();
try {
System.out.println("Message received: " + new String(msg.getData()));
//消息确认
consumer.acknowledge(msg);
} catch (Exception e) {
consumer.negativeAcknowledge(msg);
4.2 Spring客户端
(1)依赖
<properties>
<java.version>1.8</java.version>
<!-- in your <properties> block -->
</properties>
<dependencies>
<dependency>
<artifactId>spring-boot-starter</artifactId>
</dependency>
<dependency>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
<!-- in your <dependencies> block -->
<dependency>
</dependency>
<dependency>
<artifactId>spring-boot-starter-test</artifactId>
<scope>test</scope>
</dependency>
</dependencies>
(2)项目结构
![[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-FsWvdVEp-1651490859260)(Apache Pulsar 2.assets/image-20220502125120250.png)]](https://img-blog.csdnimg.cn/cdad67f5f16b462aad64ef5e5dac66f7.png)
(3)配置类
主要用于将自定义Bean放入Spring中
@Configuration
public class PulsarConfig {
@Bean
public Producer pulsarProducer() throws PulsarClientException {
PulsarClient client = PulsarClient.builder()
.build();
.newProducer()
.topic("my-topic")
.create();
return producer;
@Bean
public Consumer pulsarConsumer() throws PulsarClientException {
.build();
.topic("my-topic")
.subscribe();
return consumer;
(4)控制器类:生产者
@RestController
public class HelloPulsarController {
@Autowired
private Producer pulsarProducer;
@RequestMapping("/hello/{msg}")
public String hello(@PathVariable("msg") String msg) {
try {
pulsarProducer.send(msg.getBytes());
} catch (PulsarClientException e) {
return "发送失败";
return "发送成功";
(3)消费者
直接使用自定义Bean,并在Spring Boot启动后自动调用该方法
@Service
public class PulsarConsumerService implements ApplicationRunner {
@Autowired
private Consumer pulsarConsumer;
public void consumer() throws PulsarClientException {
while (true) {
Message msg = pulsarConsumer.receive();
try {
pulsarConsumer.acknowledge(msg);
pulsarConsumer.negativeAcknowledge(msg);
@Override
public void run(ApplicationArguments args) throws Exception {
consumer();
5 通过pulsar-manager搭建可视化管理界面
5.1 下载链接
https://github.com/apache/pulsar-manager#access-pulsar-manager
或
https://pulsar.apache.org/en/download/
5.2 启动并配置
启动
$ wget https://dist.apache.org/repos/dist/release/pulsar/pulsar-manager/pulsar-manager-0.2.0/apache-pulsar-manager-0.2.0-bin.tar.gz
$ tar -zxvf apache-pulsar-manager-0.2.0-bin.tar.gz
$ cd pulsar-manager
$ tar -xvf pulsar-manager.tar
$ cd pulsar-manager
$ cp -r ../dist ui
$ ./bin/pulsar-manager
配置账号密码
$ CSRF_TOKEN=$(curl http://127.0.0.1:7750/pulsar-manager/csrf-token)
$ curl \
-H "X-XSRF-TOKEN: $CSRF_TOKEN" \
-H "Cookie: XSRF-TOKEN=$CSRF_TOKEN;" \
-H 'Content-Type: application/json' \
-X PUT http://127.0.0.1:7750/pulsar-manager/users/superuser \
-d '{"name": "admin", "password": "apachepulsar", "description": "test", "email": "username@test.org"}'
5.3 使用
访问http://localhost:9527就可以打开pulsar-manager界面:
![[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-KpVG1fzF-1651490859261)(Apache Pulsar 2.assets/image-20220502153256105.png)]](https://img-blog.csdnimg.cn/83d261c8be8b4836afe19b6607821932.png)
参考:
https://pulsar.apache.org/docs/zh-CN/client-libraries-go/
https://pulsar.apache.org/docs/zh-CN/client-libraries-java/
https://blog.csdn.net/ycf921244819/article/details/120907372
![[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-bWI2jbMB-1651490859257)(Apache Pulsar 2.assets/image-20220502124604132.png)]](https://img-blog.csdnimg.cn/6b00dd404f254867879182df7c0d51c5.png)
