【C语言】字符串函数
平凡的人1 发表于 2022/10/18 12:39:36 2022/10/18
【摘要】 前面我们学习了4个函数——strlen\strcpy\strcat\strcmp,这些函数的长度都是不受限制的,今天,我们自然是要介绍一些其他的函数。内容可能相对来说比较多。 长度受限制的字符串函数 strncpychar * strncpy ( char * destination, const char * source, size_t num );Copies the first nu...
长度受限制的字符串函数
strncpy
image-20220707091932481
  1. Copies the first num characters of source to destination. If the end of the source C string (which is signaled by a null-character) is found before num characters have been copied, destination is padded with zeros until a total of num characters have been written to it.
  2. 拷贝num个字符从源字符串到目标空间。
  3. 如果源字符串的长度小于num,则拷贝完源字符串之后,在目标的后边追加0,直到num个。
下面,我们来简单测试一下:
#include <stdio.h>
#include <string.h>
int main()
	char arr1[20] = "abcdef";
	char arr2[] = "hello world";
	strncpy(arr1, arr2, 5);
	printf("%s\n", arr1);
	return 0;
运行:image-20220707093803269
我们来看看上面的==第3点==:
#include <stdio.h>
#include <string.h>
int main()
	char arr2[] = "ghi";
	strncpy(arr1, arr2, 5);//arr2只有3个这里却要拷贝5个,这是怎么一回事呢
	return 0;
F10调试看看还没拷贝前arr1和arr2是这样子的:image-20220707094657476
拷贝完成之后呢?image-20220707094744118
我们可以清楚的看到,内容不够时会用’\0’来补充!
strncat
image-20220707095134661
char * strncat ( char * destination, const char * source, size_t num );
  1. Appends the first num characters of source to destination, plus a terminating null-character.
  2. If the length of the C string in source is less than num, only the content up to the terminating null-character is copied.
#include <stdio.h>
#include <string.h>
int main()
	char arr1[20] = "hello\0xxxxx";
	char arr2[] = "world";
	strncat(arr1, arr2, 3);
	return 0;
结果我们都是知道的,那过程是什么样子的呢?我们不妨调试来看一看:追加之前:
追加后:image-20220707095641466
我们可以清楚的看到,会在最后面自动加上一个’\0’
那如果追加的长度大于本身呢?会不会像strncpy一样却多少就补多少个’\0’呢?测试一段代码:
#include <stdio.h>
#include <string.h>
int main()
	char arr2[] = "abc";
	strncat(arr1, arr2, 6);
	return 0;
追加前:image-20220707100015102
追加后:image-20220707100040572
答案是并没有,只会添加一个’\0’。通过简单的分析,我们也大概知道了strncat的原理。
strncmp
image-20220707100258557
int strncmp ( const char * str1, const char * str2, size_t num );
比较到出现另个字符不一样或者一个字符串结束或者num个字符全部比较完。
#include <stdio.h>
#include <string.h>
int main()
	char arr1[] = "abcdef";
	int ret = strncmp(arr1, arr2, 4);
	printf("%d\n", ret);
	if (ret == 0)
		printf("==\n");
	else if (ret < 0)
		printf("<\n");
	else
		printf(">\n");
	return 0;
image-20220707101140742
实际上,这些函数多了个n也就多了长度限制,并没有多大的区别,长度受限的字符串函数使得代码更加严谨一些,我们尽可能去使用。
字符串查找
strstr
image-20220707101413372
char * strstr ( const char *str1, const char * str2);
Returns a pointer to the first occurrence of str2 in str1, or a null pointer if str2 is not part of str1.
简单理解,这个函数就是查找子串的函数
#include <stdio.h>
#include <string.h>
int main()
	char email[] = "huangweichang@qq.com";
	char substr[] = "eichang";
	char*ret = strstr(email, substr);
	if (ret == NULL)
		printf("子串不存在\n");
	else
		printf("%s\n", ret);
	return 0;
image-20220707101942440
关于怎么使用并不是重点,重点是我们怎么去进行模拟实现!
strstr的模拟实现
我们先来说一说查找的过程:
可以分为两种情况来说明:
一种是简单的情况:一次匹配就能找到
另一种是比较复杂的情况:第一次匹配没有找到,需要记录当前的位置,继续匹配下去,需要找多次才能找到
image-20220707103859541
下面进行简单的模拟实现:
#include <assert.h>
#include <stdio.h>
char*my_strstr(const char*str1,const char*str2)
	assert(str1 && str2);
	const char* s1 = str1;
	const char* s2 = str2;
	const char* p = str1;
	while (*p)
		s1 = p;
		s2 = str2;
		while (*s1!='\0'&&*s2!='\0'&&* s1 == *s2)
			s1++;
			s2++;
		if (*s2 == '\0')
			return (char*)p;
		p++;
	return NULL;
int main()
	//char*ret = strstr(email, substr);
	char* ret = my_strstr(email, substr);
	if (ret == NULL)
		printf("子串不存在\n");
	else
	return 0;
找子串这里可以用KMP算法来进行实现,不过较为复杂,就不展开说明了。
strtok
image-20220707105048477
char * strtok ( char * str, const char * sep );
sep参数是个字符串,定义了用作分隔符的字符集合
第一个参数指定一个字符串,它包含了0个或者多个由sep字符串中一个或者多个分隔符分割的标 记。
strtok函数找到str中的下一个标记,并将其用 \0 结尾,返回一个指向这个标记的指针。(注: strtok函数会改变被操作的字符串,所以在使用strtok函数切分的字符串一般都是临时拷贝的内容 并且可修改。)
strtok函数的第一个参数不为 NULL ,函数将找到str中第一个标记,strtok函数将保存它在字符串 中的位置。
strtok函数的第一个参数为 NULL ,函数将在同一个字符串中被保存的位置开始,查找下一个标 记。
如果字符串中不存在更多的标记,则返回 NULL 指针.
我觉得这是一个比较奇怪的函数,不过并不妨碍我们认识它切割字符串
#include <stdio.h>
#include <string.h>
int main()
	const char* sep = "@.";
	char cp[30] = { 0 };
	strcpy(cp, email);
	char*ret = strtok(cp, sep);
	ret = strtok(NULL, sep);
	return 0;
image-20220707105512359
怎么和for循环联系起来❓
#include <stdio.h>
#include <string.h>
int main()
	strcpy(cp, email);
	char* ret = NULL;
	for (ret = strtok(cp, sep); ret != NULL; ret = strtok(NULL, sep))
	return 0;
错误信息报告
strerror
image-20220707105848512
char * strerror ( int errnum );
返回错误码,所对应的错误信息。
#include <stdio.h>
#include <string.h>
int main()
	printf("%s\n", strerror(0));
	printf("%s\n", strerror(1));
	printf("%s\n", strerror(2));
	printf("%s\n", strerror(3));
	printf("%s\n", strerror(4));
	printf("%s\n", strerror(5));
image-20220707110144327
这些并不需要我们记住,error-C语言设置的一个全局的错误码存放的变量
举个例子:
#include <stdio.h>
#include <string.h>
int main()
    FILE* pf = fopen("test.txt", "r");
	if (pf == NULL)
		printf("%s\n", strerror(errno));
		return 1;
	else
    return 0;
image-20220707110347132
字符分类函数
这些函数是比较多的,零零散散,并不 一一举例子说明了,在这里,大家可以认识认识并自己动手实践一下:
函数 如果他的参数符合下列条件就返回真
iscntrl 任何控制字符
isspace 空白字符:空格‘ ’,换页‘\f’,换行’\n’,回车‘\r’,制表符’\t’或者垂直制表符’\v’
isdigit 十进制数字 0~9 isxdigit 十六进制数字,包括所有十进制数字,小写字母a~f,大写字母A~F
islower 小写字母a~z
isupper 大写字母A~Z
isalpha 字母a~z或A~Z
isalnum 字母或者数字,a~z,A~Z,0~9
ispunct 标点符号,任何不属于数字或者字母的图形字符(可打印)
isgraph 任何图形字符
isprint 任何可打字符,包括图形字符和空白字符
#include <stdio.h>
#include <ctype.h>
int main()
    int i = 0;
    char str[] = "Test String.\n";
    char c;
    while (str[i])
        c = str[i];
        if (isupper(c))
            c = tolower(c);
        putchar(c);
        i++;
    return 0;
image-20220707111234962
