一文搞懂Spring Boot整合RocketMQ
海风极客 发表于 2022/10/16 19:08:57 2022/10/16
【摘要】 8 Spring Boot整合RocketMQ 8.1 Maven依赖<dependency> <groupId>org.apache.rocketmq</groupId> <artifactId>rocketmq-spring-boot-starter</artifactId> <version>2.2.0</version></dependency> 8.2 配置文件...
8.1 Maven依赖
<dependency>
</dependency>
8.2 配置文件
server:
  port: 0
rocketmq:
  name-server: 127.0.0.1:9876
  producer:
    group: my_mq_one  # 指定组名 必要参数
8.3 生产者代码
 * @desc: 消息生产者
 * @author: YanMingXin
 * @create: 2021/9/15-12:20
@Service
public class MessageProvider {
     * 注入RocketMQTemplate
    @Autowired
    private RocketMQTemplate rocketMQTemplate;
     * 发送普通消息
     * @param message
     * @return
    public boolean sendMessage(String message) {
        rocketMQTemplate.convertAndSend("Topic1:TagA", message);
        return true;
     * 发送Spring的消息
     * @param message
     * @return
    public boolean sendSpringMessage(String message) {
        rocketMQTemplate.send("Topic1:TagA", MessageBuilder.withPayload(message).build());
        return true;
     * 发送异步消息
     * @param message
     * @return
    public boolean sendAsyncMessage(String message) {
        //发送异步消息
        rocketMQTemplate.asyncSend("Topic1:TagA", message, new SendCallback() {
            @Override
            public void onSuccess(SendResult sendResult) {
                //发送成功
                return;
            @Override
            public void onException(Throwable throwable) {
                //发送失败
                return;
        return true;
     * 发送顺序消息
     * 注:需要加上synchronized,消费者多线程下会不保证顺序
     * @param list
     * @return
    public synchronized boolean sendAscMessage(List<String> list) {
        for (String str : list) {
            //发送顺序消息
            rocketMQTemplate.syncSendOrderly("Topic1", str, str + "hash");
        return true;
8.4 消费者代码
 * @desc: 消息消费者
@RocketMQMessageListener(topic = "Topic1", consumerGroup = "my_mq_consumer_one")
public class MessageConsumer implements RocketMQListener<String> {
    @Override
    public void onMessage(String s) {
        System.out.println("Get message is " + s);
8.5 测试
@SpringBootTest
class RocketmqSpringBootApplicationTests {
    @Autowired
    private MessageProvider provider;
    @Test
    void contextLoads() {
        provider.sendMessage("Hello World");
        provider.sendSpringMessage("Hello World By Spring");
        provider.sendAsyncMessage("Hello World Async Message");
        List<String> strings = Arrays.asList("A", "B", "C");
        provider.sendAscMessage(strings);
测试结果:
