玩转Apache Tomcat
海风极客 发表于 2022/10/16 17:55:13 2022/10/16
【摘要】 玩转Tomcat 1 下载解压下载:https://tomcat.apache.org/download-90.cgi解压:ymx@ymx-PC:~/Desktop$ lsapache-tomcat-9.0.52.tar.gz ymx@ymx-PC:~/Desktop$ tar -zxvf apache-tomcat-9.0.52.tar.gz ymx@ymx-PC:~/Desktop$ ...
玩转Tomcat
1 下载解压
下载:
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-ALk7yAqP-1631369856352)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911111011757.png)]
解压:
2 启动测试访问
ymx@ymx-PC:~/Desktop$ cd apache-tomcat-9.0.52/
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52$ ls
bin  BUILDING.txt  conf  CONTRIBUTING.md  lib  LICENSE  logs  NOTICE  README.md  RELEASE-NOTES  RUNNING.txt  temp  webapps  work
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52$ cd webapps/
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps$ ls
docs  examples  host-manager  manager  ROOT
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps$ mkdir test
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps$ cd test/
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps/test$ touch index.html
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps/test$ echo "Hello This is My test" > index.html
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps/test$ cat index.html
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/webapps/test$ cd ../../bin/
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52/bin$ ./startup.sh
Using CATALINA_BASE:   /home/ymx/Desktop/apache-tomcat-9.0.52
Using CATALINA_HOME:   /home/ymx/Desktop/apache-tomcat-9.0.52
Using CATALINA_TMPDIR: /home/ymx/Desktop/apache-tomcat-9.0.52/temp
Using JRE_HOME:        /usr/local/jdk1.8.0_141/jre
Using CLASSPATH:       /home/ymx/Desktop/apache-tomcat-9.0.52/bin/bootstrap.jar:/home/ymx/Desktop/apache-tomcat-9.0.52/bin/tomcat-juli.jar
Using CATALINA_OPTS:
Tomcat started.
访问:http://localhost:8080/
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-3HEBune0-1631369856356)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911111652371.png)]
访问:http://localhost:8080/test/
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-g0oLCes4-1631369856360)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911111725995.png)]
3 开始研究
3.1 请求URL
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-4OeVkdQy-1631369856363)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911125718781.png)]
注意:当项目路径目录为ROOT时,"/test/"以及后边的url都是资源路径
3.2 URL与Tomcat中webapp目录的关系
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-fYZoup2K-1631369856367)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911130138601.png)]
3.3 URL与Tomcat配置文件的关系
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-8KHjDS2d-1631369856368)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911131033020.png)]
4 Tomcat各个目录以及重要文件的作用
目录总览:
ymx@ymx-PC:~/Desktop/apache-tomcat-9.0.52$ ls -l
总用量 148
drwxr-x--- 2 ymx ymx  4096 9月  11 11:10 bin
-rw-r----- 1 ymx ymx 18949 7月  31 12:12 BUILDING.txt
drwx------ 3 ymx ymx  4096 9月  11 13:33 conf
-rw-r----- 1 ymx ymx  6210 7月  31 12:12 CONTRIBUTING.md
drwxr-x--- 2 ymx ymx  4096 9月  11 11:10 lib
-rw-r----- 1 ymx ymx 57092 7月  31 12:12 LICENSE
drwxr-x--- 2 ymx ymx  4096 9月  11 11:14 logs
-rw-r----- 1 ymx ymx  2333 7月  31 12:12 NOTICE
-rw-r----- 1 ymx ymx  3372 7月  31 12:12 README.md
-rw-r----- 1 ymx ymx  6898 7月  31 12:12 RELEASE-NOTES
-rw-r----- 1 ymx ymx 16507 7月  31 12:12 RUNNING.txt
drwxr-x--- 2 ymx ymx  4096 9月  11 11:10 temp
drwxr-x--- 8 ymx ymx  4096 9月  11 11:13 webapps
drwxr-x--- 3 ymx ymx  4096 9月  11 11:14 work
重要目录:
  • bin:存放可执行文件,如启动文件,停止文件
  • conf:存放配置文件
  • lib:存放依赖包,jar文件
  • logs:存放服务器日志文件
  • temp:存放临时文件
  • webapps:存放所有web项目
  • work:存放tomcat在运行时的编译后文件,例如JSP编译后的文件
重要文件:
  • bin/startup.sh:Tomcat服务器启动文件
  • bin/shundown.sh:Tomcat启动后的停止文件
  • config/server.xml:总配置文件
  • config/web.xml:当前Server的web配置文件
5 详解server.xml配置文件
5.1 Tomcat默认server.xml文件内容
<Server port="8005" shutdown="SHUTDOWN">
  <Listener className="org.apache.catalina.startup.VersionLoggerListener" />
  <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
  <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
  <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
  <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
  <GlobalNamingResources>
    <Resource name="UserDatabase" auth="Container"
              type="org.apache.catalina.UserDatabase"
              description="User database that can be updated and saved"
              factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
              pathname="conf/tomcat-users.xml" />
  </GlobalNamingResources>
  <Service name="Catalina">
    <Connector port="8080" protocol="HTTP/1.1"
               connectionTimeout="20000"
               redirectPort="8443" />
    <Engine name="Catalina" defaultHost="localhost">
      <Realm className="org.apache.catalina.realm.LockOutRealm">
        <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
               resourceName="UserDatabase"/>
      </Realm>
      <Host name="localhost"  appBase="webapps"
            unpackWARs="true" autoDeploy="true">
        <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
               prefix="localhost_access_log" suffix=".txt"
               pattern="%h %l %u %t &quot;%r&quot; %s %b" />
      </Host>
    </Engine>
  </Service>
</Server>
5.2 各标签含义
5.2.1 Server标签
Server元素表示整个Catalina的servlet容器。因此,它必须是单个最外层元素在conf/server.xml配置文件中。它的属性将servlet容器的特性表示为一个整体。
5.2.2 Listener标签
Listener元素定义执行发生特定事件时的操作,通常是Tomcat启动或Tomcat停止,侦听器可以嵌套在Server中,engine,host或context。
5.2.3 GlobalNamingResources标签
GlobalNamingResources元素定义了全局服务器的JNDI资源,这些资源列在服务器的全局JNDI资源上下文中。
此上下文不同于每个web应用程序的JNDI上下文描述于JNDI资源。此元素中定义的资源在中不可见除非您将每个web应用程序上下文显式链接到ResourceLink元素。
5.2.4 Resources标签
Resources元素表示所有资源可用于web应用程序。这包括类、JAR文件、HTML和JSP以及任何其他有助于web应用程序的文件。启动位置是用来使用目录、JAR文件和WAR作为这些文件的源的资源和资源实施可扩展以提供支持对于以其他形式存储的文件,如数据库或版本控制的存储库,默认情况下缓存资源
注意:运行基于非文件系统的webapp只有在webapp不支持的情况下,资源实现才可能依靠文件系统对其自身资源的直接访问,并使用在ServletContext界面中访问它们。
资源元素可以嵌套在上下文组件。如果不包括在内,,将自动创建基于文件系统的默认资源,这对于大多数需求来说是足够的
5.2.5 Service标签
Service元素表示一个或多个服务的组合更多连接器共享单个用于处理传入数据的引擎组件请求。可以嵌套一个或多个Service元素在一个Server元素中
5.2.6 Connector标签
Connector表示接收请求的端点然后返回响应。
5.2.7 Engine标签
Engine元素表示整个请求与特定Catalina相关的Engine Server。它接收和处理数据来自一个或多个连接器的所有请求,并将完成的响应返回给连接器,以进行最终验证传输回客户端必须在内部嵌套一个Engine元素,Service元素,在所有与此Server关联的相应Connector元素。
5.2.8 Realm标签
Realm元素表示用户名的“数据库”,密码和分配的角色(类似于Unix组给那些用户。Realm的不同实现允许使用Catalina集成到已存储此类身份验证信息的环境中被创建和维护,然后利用这些信息来实现容器管理的安全性)
5.2.9 Host标签
Host元素表示一个虚拟主机
5.2.10 Valve标签
Valve元件表示将要安装的部件插入到关联的请求的请求处理管道中Catalina容器(engine,host,或context)。
单个阀门具有不同的处理能力,并且下文单独描述
5.3 标签的层级关系
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-in1aipe4-1631369856370)(/home/ymx/Desktop/玩转Tomcat.assets/image-20210911135757818.png)]
6 常用(可调优)参数
6.1 Connector常用调优参数
<Executor name="tomcatThreadPool"
          namePrefix="catalina-exec-"
          maxThreads="150"
          minSpareThreads="4"/>
           protocol="HTTP/1.1"
           executor="tomcatThreadPool"
           maxThreads="150"
           SSLEnabled="true"
           maxConnections="100"
           minSpareThreads="10"
  • port:连接端口号
  • protocol:协议
  • executor:线程池配置
  • maxThreads:最大线程数
  • SSLEnabled:是否开启SSL(HTTPS)
  • connectionTimeout:连接超时等待时间
  • maxConnections:最大连接数
  • redirectPort:重定向端口号
  • minSpareThreads:最小线程数
6.2 Host常用参数
  • name:主机名
  • appBase:项目根目录
  • unpackWARs:是否自动解压
  • autoDeploy:是否自动部署
