sql注入关键字过滤fuzz字典
开心星人 发表于 2022/09/26 20:27:18 2022/09/26
【摘要】 length Length+handlerlikeLiKeselectSeleCT sleepSLEEpdatabaseDATABASedeletehavingoroRasAs-~BENCHMARKlimitLimItleftLeftselectSELECTinsertinsERTINSERTright#--+INFORMATION--;!%+xor<>(><).^=ANDANdBYByCA...
length
Length
handler
like
LiKe
select
SeleCT
sleep
SLEEp
database
DATABASe
delete
having
or
oR
as
As
BENCHMARK
limit
LimIt
left
Left
select
SELECT
insert
insERT
INSERT
right
INFORMATION
xor
AND
ANd
BY
By
CAST
COLUMN
COlumn
COUNT
Count
CREATE
END
case
'1'='1
when
admin'
length
REVERSE
ascii
ASSIC
ASSic
select
database
left
right
union
UNIon
UNION
oorr
anandd
GROUP
HAVING
IF
INTO
JOIN
LEAVE
LEFT
LEVEL
sleep
LIKE
NAMES
NEXT
NULL
OF
ON
infromation_schema
user
OR
ORDER
ORD
SCHEMA
SELECT
SET
TABLE
THEN
UNION
UPDATE
USER
USING
VALUE
VALUES
WHEN
WHERE
ADD
AND
prepare
set
update
delete
drop
inset
CAST
COLUMN
CONCAT
GROUP_CONCAT
group_concat
CREATE
DATABASE
DATABASES
alter
DELETE
DROP
floor
rand()
information_schema.tables
TABLE_SCHEMA
%df
concat_ws()
concat
LIMIT
ORD
ON
extractvalue
order
CAST()
by
ORDER
OUTFILE
RENAME
REPLACE
SCHEMA
SELECT
SET
updatexml
SHOW
SQL
TABLE
THEN
TRUE
instr
benchmark
format
bin
substring
ord
UPDATE
VALUES
VARCHAR
VERSION
WHEN
WHERE
users
%0a
%0A
%0b
mid
for
BEFORE
REGEXP
RLIKE
in
sys schemma
SEPARATOR
XOR
CURSOR
FLOOR
sys.schema_table_statistics_with_buffer
INFILE
count
%0c
from
%0d
%a0
else
%27
%23
%22
%20
