js: 前端浏览器存储方案整理及其扩展库
彭世瑜 发表于 2022/09/25 08:20:32 2022/09/25
【摘要】 方案/库文档简介cookieMDN一个键值对形式的字符串IndexedDBMDNIndexedDB 是一种底层 API,用于在客户端存储大量的结构化数据(也包括文件/二进制大型对象(blobs))sess...
方案/库 文档 简介
cookie MDN 一个键值对形式的字符串
IndexedDB MDN IndexedDB 是一种底层 API,用于在客户端存储大量的结构化数据(也包括文件/二进制大型对象(blobs))
sessionStorage MDN 数据在页面会话结束时会被清除
localStorage MDN 存储的数据没有过期时间设置
localforage 官网 localForage is a JavaScript library that improves the offline experience of your web app by using an asynchronous data store with a simple, localStorage-like API.
Dexie.js 官网 A Minimalistic Wrapper for IndexedDB
PouchDB 官网 PouchDB is an open-source JavaScript database inspired by Apache CouchDB that is designed to run well within the browser.
idb npmjs、github IndexedDB, but with promises
IDB-Keyval npmjs、github A super-simple-small promise-based keyval store implemented with IndexedDB
JsStore 官网、github JsStore is an IndexedDB Wrapper. It makes IndexedDB super easy with its SQL like apis.
Lovefield 官网、github Lovefield is a relational database for web apps.
原文链接:pengshiyu.blog.csdn.net/article/details/126996781
