Unity 使用this关键字进行函数拓展 - string
CoderZ1010 发表于 2022/09/25 05:14:00 2022/09/25
【摘要】 Example: private string str = "Test"; private void Start() { bool isNullOrEmpty = str.IsNullOrEmpty(); bool isNullOrWhiteSpace = str.IsNullOrWhiteSpace(); ...
Example:
    bool containChinese = str.ContainChinese();
    bool isValidEmail = str.IsValidEmail();
    bool isValidMobilePhoneNumber = str.IsValidMobilePhoneNumber();
    string uppercaseFirst = str.UppercaseFirst();
    string lowercaseFirst = str.LowercaseFirst();
    string path = Application.streamingAssetsPath.PathCombine("readme.txt");
    bool existsFile = path.ExistsFile();
    bool deleteFileCarefully = path.DeleteFileCarefully();
Extension:
    /// <summary>
    /// The extension of string.
    /// </summary>
    public static class StringExtension
        /// <summary>
        /// The string value is null/empty or not.
        /// </summary>
        /// <param name="self"></param>
        /// <returns>return true if the string value is null or empty, otherwise retrun false.</returns>
        public static bool IsNullOrEmpty(this string self)
            return string.IsNullOrEmpty(self);
        /// <summary>
        /// The string value is null/white space or not.
        /// </summary>
        /// <returns>return true if the string value is null or white space, otherwise return false.</returns>
        public static bool IsNullOrWhiteSpace(this string self)
            return string.IsNullOrWhiteSpace(self);
        /// <summary>
        /// The string value contains chinese or not.
        /// </summary>
        /// <returns>return true if the string value contains chinese, otherwise return false.</returns>
        public static bool ContainChinese(this string self)
            return Regex.IsMatch(self, @"[\u4e00-\u9fa5]");
        /// <summary>
        /// The string value is valid Email.
        /// </summary>
        /// <returns>return true if the string value is valid email, otherwise return false.</returns>
        public static bool IsValidEmail(this string self)
            return Regex.IsMatch(self, @"^([\w-\.]+)@((\[[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.)|(([\w-]+\.)+))([a-zA-Z]{2,4}|[0-9]{1,3})(\]?)$");
        /// <summary>
        /// The string value is valid mobile phone number or not.
        /// </summary>
        /// <returns>return true if the string value is valid mobile phone number, otherwise return false.</returns>
        public static bool IsValidMobilePhoneNumber(this string self)
            return Regex.IsMatch(self, @"^0{0,1}(13[4-9]|15[7-9]|15[0-2]|18[7-8])[0-9]{8}$");
        /// <summary>
        /// Uppercase the first char.
        /// </summary>
        /// <returns>return an string which uppercase the first char by the string.</returns>
        public static string UppercaseFirst(this string self)
            return char.ToUpper(self[0]) + self.Substring(1);
        /// <summary>
        /// Lowercase the first char.
        /// </summary>
        /// <returns>return an string which lowercase the first char by the string.</returns>
        public static string LowercaseFirst(this string self)
            return char.ToLower(self[0]) + self.Substring(1);
        #region Path
        /// <summary>
        /// Combine path.
        /// </summary>
        /// <param name="toCombine"></param>
        /// <returns></returns>
        public static string PathCombine(this string self, string toCombine)
            return Path.Combine(self, toCombine);
        /// <summary>
        /// Get the sub files path in the directory.
        /// </summary>
        /// <param name="recursive"></param>
        /// <param name="suffix"></param>
        /// <returns>return the list contains sub files path in the directory.</returns>
        public static List<string> GetDirSubFilePathList(this string self, bool recursive = false, string suffix = "")
            List<string> retList = new List<string>();
            var di = new DirectoryInfo(self);
            if (!di.Exists)
                return retList;
            var files = di.GetFiles();
            foreach (var file in files)
                if (!string.IsNullOrEmpty(suffix))
                    if(!file.FullName.EndsWith(suffix, StringComparison.CurrentCultureIgnoreCase))
                        continue;
                retList.Add(file.FullName);
            if (recursive)
                var dirs = di.GetDirectories();
                foreach (var dir in dirs)
                    retList.AddRange(GetDirSubFilePathList(dir.FullName, recursive, suffix));
            return retList;
        #endregion
        #region File
        /// <summary>
        /// Get the file is exists or not.
        /// </summary>
        /// <returns>return true if the file is exists, otherwise return false.</returns>
        public static bool ExistsFile(this string self)
            return File.Exists(self);
        /// <summary>
        /// Delete the file if it is exists.
        /// </summary>
        /// <returns>return true if the file is exists and delete it, otherwise return false.</returns>
        public static bool DeleteFileCarefully(this string self)
            if (File.Exists(self))
                File.Delete(self);
                return true;
            return false;
        /// <summary>
        /// Encrypt the file if it is exists.
        /// </summary>
        /// <returns>return true if the file is exists and encrypt it, otherwise return false.</returns>
        public static bool EncryptFileCarefully(this string self)
                File.Encrypt(self);
                return true;
            return false;
        /// <summary>
        /// Decrypt the file if it is exists.
        /// </summary>
        /// <returns>return true if the file is exists and decrypt it, otherwise return false.</returns>
        public static bool DecryptFileCarefully(this string self)
                File.Decrypt(self);
                return true;
            return false;
        #endregion
        #region Directory
        /// <summary>
        /// Create the directory if it is not exists.
        /// </summary>
        public static string CreateDirectoryCarefully(this string self)
            if (!Directory.Exists(self))
                Directory.CreateDirectory(self);
            return self;
        /// <summary>
        /// Delete the directory if it is exists.
        /// </summary>
        public static void DeleteDirectoryCarefully(this string self)
            if (Directory.Exists(self))
                Directory.Delete(self);
        /// <summary>
        /// </summary>
        public static void DeleteDirectoryCarefully(this string self, bool recursive)
                Directory.Delete(self, recursive);
        /// <summary>
        /// Clear the directory if it is exists.
        /// </summary>
        public static void ClearDirectoryCarefully(this string self)
                Directory.Delete(self, true);
        #endregion
文章来源: coderz.blog.csdn.net,作者:CoderZ1010,版权归原作者所有,如需转载,请联系作者。
原文链接:coderz.blog.csdn.net/article/details/109056973
