Unity 编辑器开发实战【AssetDatabase】- 获取资产的依赖项、引用项
CoderZ1010 发表于 2022/09/25 05:17:39 2022/09/25
【摘要】 Unity AssetDatabase类中提供了获取资产依赖项的API,如果我们想要获取某一资产被哪些资产引用,可以通过如下思路去实现: 1.获取工程中的所有资产; 2.遍历每一项资产,获取其依赖项列表; 3.如果资产A的依赖项列表中包含资产B,则资产B被资产A引用。 用到的核心API: 1.根据guid获取资产路径 /...
1.获取工程中的所有资产;
2.遍历每一项资产,获取其依赖项列表;
用到的核心API:
1.根据guid获取资产路径
  1. //
  2. // 摘要:
  3. // Gets the corresponding asset path for the supplied GUID, or an empty string if
  4. // the GUID can't be found.
  5. //
  6. // 参数:
  7. // guid:
  8. // The GUID of an asset.
  9. //
  10. // 返回结果:
  11. // Path of the asset relative to the project folder.
  12. public static string GUIDToAssetPath(string guid)
  13. {
  14. return GUIDToAssetPath_Internal(new GUID(guid));
  15. }
2.根据资产路径获取资产的类型
  1. //
  2. // 摘要:
  3. // Returns the type of the main asset object at assetPath.
  4. //
  5. // 参数:
  6. // assetPath:
  7. // Filesystem path of the asset to load.
  8. [MethodImpl(MethodImplOptions.InternalCall)]
  9. public static extern Type GetMainAssetTypeAtPath(string assetPath);
3.根据资产路径获取该资产的依赖项:
  1. //
  2. // 摘要:
  3. // Returns an array of all the assets that are dependencies of the asset at the
  4. // specified pathName. Note: GetDependencies() gets the Assets that are referenced
  5. // by other Assets. For example, a Scene could contain many GameObjects with a Material
  6. // attached to them. In this case, GetDependencies() will return the path to the
  7. // Material Assets, but not the GameObjects as those are not Assets on your disk.
  8. //
  9. // 参数:
  10. // pathName:
  11. // The path to the asset for which dependencies are required.
  12. //
  13. // recursive:
  14. // Controls whether this method recursively checks and returns all dependencies
  15. // including indirect dependencies (when set to true), or whether it only returns
  16. // direct dependencies (when set to false).
  17. //
  18. // 返回结果:
  19. // The paths of all assets that the input depends on.
  20. public static string[] GetDependencies(string pathName)
  21. {
  22. return GetDependencies(pathName, recursive: true);
  23. }
4.根据资产路径及类型加载资产
  1. //
  2. // 摘要:
  3. // Returns the first asset object of type type at given path assetPath.
  4. //
  5. // 参数:
  6. // assetPath:
  7. // Path of the asset to load.
  8. //
  9. // type:
  10. // Data type of the asset.
  11. //
  12. // 返回结果:
  13. // The asset matching the parameters.
  14. [MethodImpl(MethodImplOptions.InternalCall)]
  15. [NativeThrows]
  16. [PreventExecutionInState(AssetDatabasePreventExecution.kGatheringDependenciesFromSourceFile, PreventExecutionSeverity.PreventExecution_ManagedException, "Assets may not be loaded while dependencies are being gathered, as these assets may not have been imported yet.")]
  17. [TypeInferenceRule(TypeInferenceRules.TypeReferencedBySecondArgument)]
  18. public static extern UnityEngine.Object LoadAssetAtPath(string assetPath, Type type);
下面实现的工具,既可以获取资产的依赖项,也可以获取资产的引用项:
代码如下:
  1. using System;
  2. using UnityEngine;
  3. using UnityEditor;
  4. using System.Linq;
  5. using System.Collections.Generic;
  6. namespace SK.Framework
  7. {
  8. public class AssetsStatistics : EditorWindow
  9. {
  10. [MenuItem("SKFramework/Assets Statistics")]
  11. private static void Open()
  12. {
  13. GetWindow<AssetsStatistics>("Assets Statistics").Show();
  14. }
  15. private Vector2 selectedListScroll;
  16. //当前选中项索引
  17. private int currentSelectedIndex = -1;
  18. private enum Mode
  19. {
  20. Dependence,
  21. Reference,
  22. }
  23. private Mode mode = Mode.Dependence;
  24. private Vector2 dependenceListScroll;
  25. private Vector2 referenceListScroll;
  26. private string[] dependenciesArray;
  27. private string[] referenceArray;
  28. private void OnGUI()
  29. {
  30. OnListGUI();
  31. OnMenuGUI();
  32. }
  33. private void OnListGUI()
  34. {
  35. if (Selection.assetGUIDs.Length == 0) return;
  36. selectedListScroll = EditorGUILayout.BeginScrollView(selectedListScroll);
  37. for (int i = 0; i < Selection.assetGUIDs.Length; i++)
  38. {
  39. //通过guid获取资产路径
  40. string path = AssetDatabase.GUIDToAssetPath(Selection.assetGUIDs[i]);
  41. GUILayout.BeginHorizontal(currentSelectedIndex == i ? "SelectionRect" : "dragtab first");
  42. //获取资产类型
  43. Type type = AssetDatabase.GetMainAssetTypeAtPath(path);
  44. GUILayout.Label(EditorGUIUtility.IconContent(GetIconName(type.Name)), GUILayout.Width(20f), GUILayout.Height(15f));
  45. GUILayout.Label(path);
  46. //点击选中
  47. if(Event.current.type == EventType.MouseDown && GUILayoutUtility.GetLastRect().Contains(Event.current.mousePosition))
  48. {
  49. currentSelectedIndex = i;
  50. Event.current.Use();
  51. GetDependencies();
  52. }
  53. GUILayout.EndHorizontal();
  54. }
  55. EditorGUILayout.EndScrollView();
  56. }
  57. private void OnMenuGUI()
  58. {
  59. GUILayout.FlexibleSpace();
  60. GUILayout.BeginVertical("Box", GUILayout.Height(position.height * .7f));
  61. {
  62. GUILayout.BeginHorizontal();
  63. {
  64. Color color = GUI.color;
  65. GUI.color = mode == Mode.Dependence ? color : Color.gray;
  66. if (GUILayout.Button("依赖", "ButtonLeft"))
  67. {
  68. mode = Mode.Dependence;
  69. }
  70. GUI.color = mode == Mode.Reference ? color : Color.gray;
  71. if (GUILayout.Button("引用", "ButtonRight"))
  72. {
  73. mode = Mode.Reference;
  74. }
  75. GUI.color = color;
  76. }
  77. GUILayout.EndHorizontal();
  78. switch (mode)
  79. {
  80. case Mode.Dependence: OnDependenceGUI(); break;
  81. case Mode.Reference: OnReferenceGUI(); break;
  82. }
  83. }
  84. GUILayout.EndVertical();
  85. }
  86. private void GetDependencies()
  87. {
  88. string guid = Selection.assetGUIDs[currentSelectedIndex];
  89. string path = AssetDatabase.GUIDToAssetPath(guid);
  90. dependenciesArray = AssetDatabase.GetDependencies(path);
  91. }
  92. private void OnDependenceGUI()
  93. {
  94. EditorGUILayout.HelpBox("该资产的依赖项", MessageType.Info);
  95. if (currentSelectedIndex != -1)
  96. {
  97. dependenceListScroll = EditorGUILayout.BeginScrollView(dependenceListScroll);
  98. for (int i = 0; i < dependenciesArray.Length; i++)
  99. {
  100. string dependency = dependenciesArray[i];
  101. GUILayout.BeginHorizontal("dragtab first");
  102. Type type = AssetDatabase.GetMainAssetTypeAtPath(dependency);
  103. GUILayout.Label(EditorGUIUtility.IconContent(GetIconName(type.Name)), GUILayout.Width(20f), GUILayout.Height(15f));
  104. GUILayout.Label(dependency);
  105. if (Event.current.type == EventType.MouseDown && GUILayoutUtility.GetLastRect().Contains(Event.current.mousePosition))
  106. {
  107. var obj = AssetDatabase.LoadAssetAtPath(dependency, type);
  108. EditorGUIUtility.PingObject(obj);
  109. Event.current.Use();
  110. }
  111. GUILayout.EndHorizontal();
  112. }
  113. EditorGUILayout.EndScrollView();
  114. }
  115. }
  116. private void OnReferenceGUI()
  117. {
  118. EditorGUILayout.HelpBox("该资产的引用项(需点击刷新按钮获取,需要一定时间)", MessageType.Info);
  119. GUI.enabled = currentSelectedIndex != -1;
  120. if (GUILayout.Button("刷新"))
  121. {
  122. if (EditorUtility.DisplayDialog("提醒", "获取工程资产之间的引用关系需要一定时间,是否确定开始", "确定", "取消"))
  123. {
  124. Dictionary<string, string[]> referenceDic = new Dictionary<string, string[]>();
  125. string[] paths = AssetDatabase.GetAllAssetPaths();
  126. for (int i = 0; i < paths.Length; i++)
  127. {
  128. referenceDic.Add(paths[i], AssetDatabase.GetDependencies(paths[i]));
  129. EditorUtility.DisplayProgressBar("进度", "获取工程资产之间的依赖关系", i + 1 / paths.Length);
  130. }
  131. EditorUtility.ClearProgressBar();
  132. string guid = Selection.assetGUIDs[currentSelectedIndex];
  133. string path = AssetDatabase.GUIDToAssetPath(guid);
  134. referenceArray = referenceDic.Where(m => m.Value.Contains(path)).Select(m => m.Key).ToArray();
  135. }
  136. }
  137. GUI.enabled = true;
  138. if(referenceArray != null)
  139. {
  140. referenceListScroll = EditorGUILayout.BeginScrollView(referenceListScroll);
  141. {
  142. for (int i = 0; i < referenceArray.Length; i++)
  143. {
  144. string reference = referenceArray[i];
  145. GUILayout.BeginHorizontal("dragtab first");
  146. Type type = AssetDatabase.GetMainAssetTypeAtPath(reference);
  147. GUILayout.Label(EditorGUIUtility.IconContent(GetIconName(type.Name)), GUILayout.Width(20f), GUILayout.Height(15f));
  148. GUILayout.Label(reference);
  149. if (Event.current.type == EventType.MouseDown && GUILayoutUtility.GetLastRect().Contains(Event.current.mousePosition))
  150. {
  151. var obj = AssetDatabase.LoadAssetAtPath(reference, type);
  152. EditorGUIUtility.PingObject(obj);
  153. Event.current.Use();
  154. }
  155. GUILayout.EndHorizontal();
  156. }
  157. }
  158. EditorGUILayout.EndScrollView();
  159. }
  160. }
  161. private string GetIconName(string typeName)
  162. {
  163. switch (typeName)
  164. {
  165. case "Material": return "d_Material Icon";
  166. case "Mesh": return "d_Mesh Icon";
  167. case "AnimationClip": return "d_AnimationClip Icon";
  168. case "GameObject": return "d_Prefab Icon";
  169. case "Texture2D": return "d_Texture Icon";
  170. case "MonoScript": return "d_cs Script Icon";
  171. case "AnimatorController": return "d_AnimatorController Icon";
  172. case "DefaultAsset": return "d_DefaultAsset Icon";
  173. case "TextAsset": return "d_TextAsset Icon";
  174. case "TimelineAsset": return "d_UnityEditor.Timeline.TimelineWindow";
  175. default: return "d__Help@2x";
  176. }
  177. }
  178. private void OnSelectionChange()
  179. {
  180. currentSelectedIndex = -1;
  181. Repaint();
  182. }
  183. }
  184. }
文章来源: coderz.blog.csdn.net,作者:CoderZ1010,版权归原作者所有,如需转载,请联系作者。
原文链接:coderz.blog.csdn.net/article/details/123796260
