Android IP多播MulticastSocket UDP实现
aiot_bigbear 发表于 2022/09/25 05:13:23 2022/09/25
【摘要】 UDP多播 在智能设备领域 用处很多,WIFI密码配置等。 以下是自己动手实现的一个例子,算是总结下相关方面知识了,温故而知新。 package com.jy.viewpagefragment; import java.io.IOException; import java.net.DatagramPacket; import ...
import java.net.InetAddress;
import java.net.MulticastSocket;
import java.net.SocketException;
import java.net.UnknownHostException;
import java.util.Timer;
import java.util.TimerTask;
import com.jy.example2.R;
import com.jy.example2.R.id;
import com.jy.example2.R.layout;
import com.jy.example2.R.menu;
import android.app.Activity;
import android.content.Context;
import android.net.wifi.WifiManager;
import android.net.wifi.WifiManager.MulticastLock;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.util.Log;
import android.view.Menu;
import android.view.MenuItem;
import android.widget.TextView;
public class UdpMultiMainActivity extends Activity {
//private InetAddress group;
private Handler handler; // 声明一个Handler对象
private static final String TAG="UdpMultiMainActivity";
private static final int MULTICAST_PORT=5111;
//private static final String GROUP_IP="224.5.0.7";
//239.255.255.250
private static final String GROUP_IP="239.255.255.250";
private static byte[] sendData;
     MulticastSocket multicastSocket = null;
     InetAddress group = null;
     MulticastLock mlock;
   static{
       sendData=new byte[4];
       // 0xEE78F1FB
       sendData[3] = (byte) 0xEE;
       sendData[2] = (byte) 0x78;
       sendData[1] = (byte) 0xF1;
       sendData[0] = (byte) 0xFB;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_udp_multi_main);
// 实例化一个Handler对象
handler = new Handler() {
@Override
public void handleMessage(Message msg) {
// 更新UI
TextView tv = (TextView) findViewById(R.id.udptext); // 获取TextView组件
if (msg.what == 0x101) {
tv.setText(msg.getData().getString("title")); // 设置标题
//iv.setImageResource(path[msg.arg1]); // 设置要显示的图片
super.handleMessage(msg);
//WifiManager wm=(WifiManager)getSystemService(WIFI_SERVICE);
WifiManager wm = (WifiManager) getSystemService(Context.WIFI_SERVICE);
mlock=wm.createMulticastLock("mygroup");
mlock.acquire();
//创建多播组
try {
multicastSocket = new MulticastSocket(MULTICAST_PORT);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
        try {
        //multicastSocket.setLoopbackMode(true);
//设置本MulticastSocket发送的数据报被回送到自身
multicastSocket.setLoopbackMode(false);
Log.d("multicastSocket","setLoopbackMode false ");
} catch (SocketException e) {
try {
group = InetAddress.getByName(GROUP_IP);
} catch (UnknownHostException e) {
        try {
multicastSocket.joinGroup(group);
        Timer timer=new Timer();
      //  timer.schedule(new MyTimerTask(),3000);
        timer.schedule(new MyTimerTask(), 3 * 1000, 1 * 1000); //利用timer.schedule方法
        Thread t = new Thread(new MyThread()); // 创建新线程
t.start(); // 开启线程
       // new Thread().start();
       // new MyThread.start();
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.udp_multi_main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
//时间任务
class MyTimerTask extends TimerTask{
//byte[] bs = new byte[1024];
@Override
public void run() {
// TODO Auto-generated method stub
//DatagramPacket packet = new DatagramPacket(sendData,sendData.length, group, Integer.valueOf(pro.getProperty("multicast_port")));
String ip=null;
    //   byte[] multicast_string="multicastSocket";
       DatagramPacket packet=new DatagramPacket(sendData, sendData.length,group,MULTICAST_PORT);
      // for(;;){
        try {
        multicastSocket.send(packet);
            Log.d(TAG,">>>send packet ok");
Log.d(TAG,">>>send packet IOException");
//Thread t = new Thread(new Runnable()
class MyThread implements Runnable{
DatagramPacket packet=null;
byte[] receiveData=new byte[256];
String ip=null;
// DatagramPacket packet=new DatagramPacket(sendData, sendData.length,group,MULTICAST_PORT);
public void run() {
Log.d("run==","MyThread start");
packet=new DatagramPacket(receiveData, receiveData.length);
try {
multicastSocket.receive(packet);
} catch (IOException e1) {
e1.printStackTrace();
Message m = handler.obtainMessage(); // 获取一个Message
m.arg1 = 1; // 保存要显示广告图片的索引值
m.what = 0x101; // 设置消息标识
Bundle bundle = new Bundle(); // 获取Bundle对象
bundle.putString("title", "get data"); // 保存标题
m.setData(bundle); // 将Bundle对象保存到Message中
handler.sendMessage(m); // 发送消息
String packetIpAddress=packet.getAddress().toString();
packetIpAddress=packetIpAddress.substring(1, packetIpAddress.length());
Log.d(TAG,"packet ip address: "+packetIpAddress);
//03-10 14:40:53.433: D/UdpMultiMainActivity(31357): packet ip address: 192.168.123.28
StringBuilder packetContent=new StringBuilder();
for(int i=0;i<receiveData.length;i++){
if(receiveData[i]==0){
break;
packetContent.append((char)receiveData[i]);
ip=packetContent.toString();
Log.d(TAG,"packet content ip is: "+ip);
//if(ip.equals(packetIpAddress)){
int flag=1;
if(flag==1){
Log.d(TAG,"find server ip address: "+ip);
//break;
}else{
Log.d(TAG,"not find server ip address, continue …");
try {
Thread.sleep(1000);
} catch (InterruptedException e) {
private void closeWifiBrocast(){
if (mlock != null){
mlock.release();
mlock = null;
Log.e("closeWifiBrocast","closeWifiBrocast");
protected void onDestroy() {
closeWifiBrocast();
//timer.cancel(); //退出计时器
// flag= false;
super.onDestroy();
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/44175631
