SpringBoot动态修改日志级别
西魏陶渊明 发表于 2022/09/25 05:32:54 2022/09/25
【摘要】 SpringBoot1.5新特性 目录 安装依赖测试显示日志级别测试修改日志级别 1.在pom中添加依赖 <parent> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-start...
SpringBoot1.5新特性
目录
  1. 安装依赖
  2. 测试显示日志级别
  3. 测试修改日志级别
1.在pom中添加依赖
  1. <parent>
  2. <groupId>org.springframework.boot</groupId>
  3. <artifactId>spring-boot-starter-parent</artifactId>
  4. <version>1.5.1.RELEASE</version>
  5. <relativePath/> <!-- lookup parent from repository -->
  6. </parent>
  7. <dependencies>
  8. <dependency>
  9. <groupId>org.springframework.boot</groupId>
  10. <artifactId>spring-boot-starter-actuator</artifactId>
  11. </dependency>
  12. <dependency>
  13. <groupId>org.springframework.boot</groupId>
  14. <artifactId>spring-boot-starter-web</artifactId>
  15. </dependency>
  16. </dependencies>
2.开始测试
http://localhost:8080/loggers
服务:
  1. s.b.a.e.m.MvcEndpointSecurityInterceptor : Full authentication is required to access actuator endpoints. Consider adding Spring Security or set 'management.security.enabled' to false.
需要手动设置management.security.enabled=false
  • 继续测试
服务返回:
  1. {
  2. levels: [
  3. "OFF",
  4. "ERROR",
  5. "WARN",
  6. "INFO",
  7. "DEBUG",
  8. "TRACE"
  9. ],
  10. loggers: {
  11. ROOT: {
  12. configuredLevel: "INFO",
  13. effectiveLevel: "INFO"
  14. },
  15. elephant: {
  16. configuredLevel: "DEBUG",
  17. effectiveLevel: "DEBUG"
  18. },
  19. ...
3.修改日志级别
POST请求
http://localhost:8080/loggers/{elephant}
{}中根据/loggers方法返回的目录级别添加
eg:
我要修改elephant.zybank.rest目录下级别
就使用下面请求方法
http://localhost:8080/loggers/elephant.zybank.rest
请求体中使用json
  1. {
  2. "configuredLevel": "DEBUG"
  3. }
登录服务器
  1. curl -H "Content-Type: application/json" -X POST --data
  2. '
  3. {
  4. "configuredLevel": "DEBUG"
  5. }
  6. '
  7. http://localhost:8080/loggers/elephant.zybank.rest
文章来源: springlearn.blog.csdn.net,作者:西魏陶渊明,版权归原作者所有,如需转载,请联系作者。
原文链接:springlearn.blog.csdn.net/article/details/102425306
