Ali云主机安装Nginx和JAVA
西魏陶渊明 发表于 2022/09/25 03:47:51 2022/09/25
【摘要】 防火墙配置 http://www.cnblogs.com/moxiaoan/p/5683743.html liuxin@KK-MINI  ~/.ssh  ssh root@120.27.217.101 Last login: Sat May 13 12:23:50 2017 from 101.81.52.22 Welcome...
防火墙配置
Welcome to Alibaba Cloud Elastic Compute Service !
是在是中不到JDK7在哪里下载,yum源里都是openjdk
http://download.csdn.net/download/love254443233/9179483
于是就在本地下载了,然后传服务器上,没有端口限制,如果有就 -P port
scp  ./Desktop/jdk-7u79-linux-x64.tar.gz  root@120.27.217.101:/root
jdk-7u79-linux-x64.tar.gz        100%  146MB   3.7MB/s   00:40
 liuxin@KK-MINI  ~  ssh root@120.27.217.101
Last login: Sat May 13 12:54:52 2017 from 27.115.24.210
  • 解压 tar -zxvf jdk-7u75-linux-x64.tar.gz
  • 配置java环境 ~/.bas_profile
  • 配置java环境变量就不讲了,直接
[root@izbp1gtcdnye16djqbbqjdz ~]# ls
jdk1.7.0_79  jdk-7u79-linux-x64.tar.gz
[root@izbp1gtcdnye16djqbbqjdz ~]# vi /etc/profile
[root@izbp1gtcdnye16djqbbqjdz ~]# . /etc/pro
profile    profile.d/ protocols
[root@izbp1gtcdnye16djqbbqjdz ~]# . /etc/profile
[root@izbp1gtcdnye16djqbbqjdz ~]# java -version
java version "1.7.0_79"
Java(TM) SE Runtime Environment (build 1.7.0_79-b15)
Java HotSpot(TM) 64-Bit Server VM (build 24.79-b02, mixed mode)
(1)使用yum安装nginx需要包括Nginx的库,安装Nginx的库
rpm -Uvh http://nginx.org/packages/centos/7/noarch/RPMS/nginx-release-centos-7-0.el7.ngx.noarch.rpm
(2)使用下面命令安装nginx
yum install nginx
(3)启动Nginx
systemctl status nginx.service
用systemctl restart nginx.service重启
(4) cat /etc/nginx/nginx.conf 配置地址
worker_processes  1;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server {
        listen       80;
        server_name  127.0.0.1:8080;
        location / {
            proxy_pass   http://127.0.0.1:8080;
server下的结点:
listen:监听80端口
server_name:转发到哪个地址
proxy_pass:代理到哪个地址
nginx常用命令(要进入到nginx的目录):
开启:start nginx
重启:nginx -s reload
文章来源: springlearn.blog.csdn.net,作者:西魏陶渊明,版权归原作者所有,如需转载,请联系作者。
原文链接:springlearn.blog.csdn.net/article/details/102425300
