在内核中通过/proc/kallsyms获得符号的地址
Linux内核符号表/proc/kallsyms的形成过程 ---------------------------------------------------------------------------
./scripts/kallsyms.c负责生成System.map ./kernel/kallsyms.c负责生成/proc/kallsyms
./scripts/kallsyms.c解析vmlinux(.tmp_vmlinux)生成kallsyms.S(.tmp_kallsyms.S),然后内核编译过程中将kallsyms.S(内核符号表)编入内核镜像uImage
内核启动后./kernel/kallsyms.c解析uImage形成/proc/kallsyms
/proc/kallsyms包含了内核中的函数符号(包括没有EXPORT_SYMBOL)、全局变量(用EXPORT_SYMBOL导出的全局变量)
为了更好地调试内核,引入了kallsyms。kallsyms抽取了内核用到的所有函数地址(全局的、静态的)和非栈数据变量地址,生成一个数据块,作为只读数据链接进kernel image,相当于内核中存了一个System.map。需要配置CONFIG_KALLSYMS
.config CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y 符号表中包括所有的变量(包括没有用EXPORT_SYMBOL导出的变量) CONFIG_KALLSYMS_EXTRA_PASS=y
make menuconfig General setup ---> [*] Configure standard kernel features (for small systems) ---> [*] Load all symbols for debugging/ksymoops [*] Include all symbols in kallsyms [*] Do an extra kallsyms pass
注: 配置CONFIG_KALLSYMS_ALL之后,就不需要修改all_symbol静态变量为1了
/dav/test # cat /proc/kallsyms | grep snd_write_bypass 805330a0 r __ksymtab_snd_write_bypass 8054504d r __kstrtab_snd_write_bypass 8086e068 B snd_write_bypass
int snd_write_bypass = 0; EXPORT_SYMBOL_GPL(snd_write_bypass);
[ 1858.449705] hello.ko,Hello, World - this is the kernel speaking [ 1858.468448] current hello module usecount=10 [ 1858.476576] snd_write_bypass a=0x8086e068 v=0/dav/test # /dav/test # /dav/test # cat /proc/kallsyms | grep snd_write_bypass 805330a0 r __ksymtab_snd_write_bypass 8054504d r __kstrtab_snd_write_bypass 8086e068 B snd_write_bypass
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/49764199
cloudbbs@huaweicloud.com
