CC2540与CC2541的区别
aiot_bigbear 发表于 2022/09/25 02:57:02 2022/09/25
【摘要】 http://see.sl088.com/wiki/CC2540%E4%B8%8ECC2541%E7%9A%84%E5%8C%BA%E5%88%AB  目录  [隐藏]  1 发现2 困扰3 基本特性差异 3.1 特性差异3...
发现
  • 看起来就像特性第二页所述:多了一个I2C接口,少了USB控制器
  • CC2541少了一档发射功率+4db
困扰
  • 真是有意思 为何速率也多了一档,而且有专门的一章文档描述-CC2541 2M速率
基本特性差异
特性差异
  • CC2541看起来可以选择250-kbps 500-kbps 1-Mbps 2-Mbps速率
CC2540
CC2541
引脚差异
  • 有趣的就是DP,DL(DM)被SCL SCK取代了
  • 引脚对应,可用于对应模块
2脚:引脚标示USB_N对应电路标示DM(相当于D-),对应CC2541的SDA(IIC功能)
3脚:引脚标示USB_P对应电路标示DP(相当于D+),对应CC2541的SCL(IIC功能)
CC2540
CC2541
见识
个人局域网 - 蓝牙低耗能技术 - CC2541 - TI 沿途见识[1]
如果 CC2540 上的 USB 未启用并且 CC2541 上的 I2C/ 额外 I/O 未启用,那么 CC2541 与 CC2540 在 6-mm x 6-mm 方形扁平无引脚 (QFN)40 封装内引脚兼容。 与 CC2540 相比,CC2541 提供更低 RF 流耗。 CC2541 没有 CC2540 所具有的 USB 接口,并在 TX 模式中提供较低的最大输出功率。 CC2541 还增加了 1 个 HW I2C 接口。
CC2541 与 CC2533 优化 RF4CE IEEE 802.15.4 SoC 引脚兼容。
CC2540和CC2541区别_奔腾似海_新浪博客 沿途见识[2]
TI Just released their new second Bluetooth Lower Energy single-mode SoC IC, the CC2541. ICs and EMKs, the modules that plug into the CC2540 Development Kit are now also available.
The CC2541 is similar to existing TI CC2540, but there are some differences:
Optimized TX power consumption. CC2541 draws 18.2 mA @ 0 dBm (14.3 mA when using TPS62730), compared to 27 mA @ 0 dBm for CC2540. Due to this optimization, maximum output power is 0 dBm for CC2541, compared with +4 dBm for CC2540.
There is also a minor improvement in RX current; 17.9 mA versus 19.6 mA (14.7 mA versus 15.8 mA when using TPS62730).
The USB interface has been removed on CC2541. It has been replaced by a hardware I2C interface.
In addition to Bluetooth low energy/Bluetooth Smart, CC2541 supports proprietary radio communication at 2 Mbps, 1 Mbps, 500 kbps and 250 kbps.
The CC2541 can be configured to be over-the-air compatible with CC2500/CC2510/CC2511 at 500 kbps and 250 kbps and with the 2.4 GHz RFICs from Nordic Semiconductor at 2 Mbps, 1 Mbps or 250 kbps the CC2540 only supported BLE.
As long as you don’t use USB or I2C, the CC2540 and CC2541 are 100% pin-compatible, including using the same values for the RF matching components, so it is easy to move back and forth between the two.
On the software side, the modules are 100% compatible, as the BLE stack masks some minor differences in the radio interface. The latest version of the BLE stack has full support for both CC2540 and CC2541.
If you are unsure whether to use CC2540 or CC2541, here are some points to consider:
If you’re concerned with active power consumption, use CC2541, as it will save you 30% in TX and around 10% in RX.
If you need +4 dBm output power, you should choose the CC2540.
If you need a USB interface, you should choose the CC2540.
If you need I2C, you should choose the CC2541.
If you want to communicate using a proprietary protocol, you should choose the CC2541.
If none of the above apply, it doesn’t matter which one you choose.
If cost is important, CC2541 is priced slightly lower than CC2540.
引用信息
以下是[CC2540与CC2541的区别]所有用到的引用信息,向这些伟大的家伙致敬:
  1. 跳转^ http://www.ti.com.cn/product/cn/cc2541
  2. 跳转^ http://blog.sina.com.cn/s/blog_533074eb010178i5.html
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/45171831
