Linux下的iwpriv(iwlist、iwconfig)的简单应用
aiot_bigbear 发表于 2022/09/25 02:32:59 2022/09/25
【摘要】 无线网络飞速发展的今天,许多设备都提供了连接无线网络的功能。 那么Linux下的wifi到底该怎么配置、连接呢?? 开始配置之前,我们要说说iw家族。iw是linux下常用的wifi配置工具,网上有相应的库和源码。全名为wirelessTools。 配置wifi模块,并连接相应的无线网络过程:主要使用iwpriv命令 ...
1. 扫描可用的无线网络:
[cpp]  view plain copy
  1. iwlist wifi-name scanning
其中wifi-name为无线网卡的名字,比如网卡eth0就是系统默认的网卡名字, wifi-name可以用ifconfig查看,一般为ra0。
2. 看扫描到的网络信息,按要连接的网络类型进行配置。以下为扫描到的网络:
[html]  view plain copy
  1. iwlist ra0 scanning
  2. ===>rt_ioctl_giwscan. 11(11) BSS returned, data->length = 1427
  3. ra0       Scan completed :
  4.           Cell 01 - Address: C4:CA:D9:1D:9E:A0
  5.                     Protocol:802.11b/g/n
  6.                     ESSID:""
  7.                     Mode:Managed
  8.                     Frequency:2.412 GHz (Channel 1)
  9.                     Quality=7/100  Signal level=-87 dBm  Noise level=-82 dBm
  10.                     Encryption key:off
  11.                     Bit Rates:54 Mb/s
  12.           Cell 02 - Address: FC:75:16:A1:A9:16
  13.                     Protocol:802.11b/g/n
  14.                     ESSID:"jxj_rd"
  15.                     Mode:Managed
  16.                     Frequency:2.452 GHz (Channel 9)
  17.                     Quality=94/100  Signal level=-53 dBm  Noise level=-92 dBm
  18.                     Encryption key:on
  19.                     Bit Rates:54 Mb/s
  20.                     IE: WPA Version 1
  21.                         Group Cipher : TKIP
  22.                         Pairwise Ciphers (2) : TKIP CCMP
  23.                         Authentication Suites (1) : PSK
  24.                     IE: IEEE 802.11i/WPA2 Version 1
  25.                         Group Cipher : TKIP
  26.                         Pairwise Ciphers (2) : TKIP CCMP
  27.                         Authentication Suites (1) : PSK
  28.           Cell 03 - Address: C4:CA:D9:02:2A:70
  29.                     Protocol:802.11b/g/n
  30.                     ESSID:""
  31.                     Mode:Managed
  32.                     Frequency:2.462 GHz (Channel 11)
  33.                     Quality=83/100  Signal level=-57 dBm  Noise level=-92 dBm
  34.                     Encryption key:off
  35.                     Bit Rates:54 Mb/s
  36.           Cell 04 - Address: 14:D6:4D:75:CA:9C
  37.                     Protocol:802.11b/g/n
  38.                     ESSID:"liangym"
  39.                     Mode:Managed
  40.                     Frequency:2.472 GHz (Channel 13)
  41.                     Quality=100/100  Signal level=-27 dBm  Noise level=-92 dBm
  42.                     Encryption key:on
  43.                     Bit Rates:54 Mb/s
  44.                     IE: WPA Version 1
  45.                         Group Cipher : CCMP
  46.                         Pairwise Ciphers (1) : CCMP
  47.                         Authentication Suites (1) : PSK
  48.                     IE: IEEE 802.11i/WPA2 Version 1
  49.                         Group Cipher : CCMP
  50.                         Pairwise Ciphers (1) : CCMP
  51.                         Authentication Suites (1) : PSK
如上:ESSID项的值即为无线网络的名字,如上的“jxj_rd”等。如果值为空,说明在无线路由勾选了隐藏ESSID的选项。
ESSID是很关键的,如果被隐藏了,也不是不能连接,而是需要破解,用到其他的工具,非常麻烦。至于如何破解,不是本文叙述的内容,有兴趣的朋友可以网上搜索。
得到了网络的信息,接下来就是配置连接选项了。以连接"jxj_rd"为例,我们看看具体的过程:
(1) 设置要连接的网络类型:
  1. iwpriv ra0 set NetworkType=Infra
(2) 设置要连接的无线网络的安全模式:
  1. iwpriv ra0 set AuthMode=WPA2PSK
(3) 设置网络加密方式:(CCMP即为AES)
  1. iwpriv ra0 set EncrypType=TKIP
(4) 设置连接时的密码: ********为加密网络的密码
  1. iwpriv ra0 set WPAPSK=*******
(5) 连接该网络:有两种方式:
    <1> 用iwpriv命令
  1. iwpriv ra0 set SSID=jxj_rd
    <2> 用iwconfig命令
  1. iwconfig ra0 essid jxj_rd
至此,如果密码正确,就可以连接上网络jxj_rd了。如果你不放心,可以用命令查看状态:
  1. iwpriv ra0 connStatus
当然,你也可以用iwconfig命令查看状态,这里不再赘述。
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/47042165
