NXP KL03--10 KL03/KL17/KL27的KL FLASH存储大小端问题( IS little END)
aiot_bigbear 发表于 2022/09/25 04:28:35 2022/09/25
【摘要】 NXP KL03–10 KL03/KL17/KL27的KL FLASH存储大小端问题( IS little END) #define Magic_Start 0x11121314 #define Mag...
#define Magic_End 0x15161718
typedef struct
unsigned int magic_start;
unsigned int flag;
unsigned int flag1;
unsigned int flag2;
unsigned int flag3;
unsigned int magic_end;
}Flash_Data;
从代码以及FLASH读取数据可以看出,FALSH布局是小端的,14是地址,在Magic_Start 也是低地址
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/124136942
评论(0
