如何使用iOS手势UIGestureRecognizer
清雨小竹 发表于 2022/09/25 04:04:17 2022/09/25
【摘要】 UIKit中包含了UIGestureRecognizer类,用于检测发生在设备中的手势。UIGestureRecognizer是一个抽象类,定义了所有手势的基本行为,它有下面一些子类用于处理具体的手势:      1、拍击UITapGestureRecognizer (任意次数的拍击)&nbs...
    2、向里或向外捏UIPinchGestureRecognizer (用于缩放)
    3、摇动或者拖拽UIPanGestureRecognizer
    4、滑动UISwipeGestureRecognizer (以任意方向)
    5、旋转UIRotationGestureRecognizer (手指朝相反方向移动)
    6、长按UILongPressGestureRecognizer
对于不同类型的手势识别器,具有不同的配置属性。比如UITapGestureRecognizer,可以配置拍击次数。界面接收到手势之后,可以发送一 个消息,用于处理响应手势动作后的任务。当然,不同的手势识别器,发送的消息方法也会有所不同。下面列举几个具体示例代码:
一个手指,拍击两次手势
复制代码
// 创建一个手势识别器
UITapGestureRecognizer *oneFingerTwoTaps =
  [[[UITapGestureRecognizer alloc] initWithTarget:self action:@selector(oneFingerTwoTaps)] autorelease];
// Set required taps and number of touches
[oneFingerTwoTaps setNumberOfTapsRequired:2];
[oneFingerTwoTaps setNumberOfTouchesRequired:1];
// Add the gesture to the view
[[self view] addGestureRecognizer:oneFingerTwoTaps];
消息方法oneFingerTwoTaps
- (void)oneFingerTwoTaps
  NSLog(@"Action: One finger, two taps");
复制代码
两个手指,拍击两次手势
复制代码
UITapGestureRecognizer *twoFingersTwoTaps =
  [[[UITapGestureRecognizer alloc] initWithTarget:self action:@selector(twoFingersTwoTaps)] autorelease];
[twoFingersTwoTaps setNumberOfTapsRequired:2];
[twoFingersTwoTaps setNumberOfTouchesRequired:2];
[[self view] addGestureRecognizer:twoFingersTwoTaps];
消息方法twoFingersTwoTaps
- (void)twoFingersTwoTaps {
  NSLog(@"Action: Two fingers, two taps");
复制代码
一个手指向上、向下滑动手势
复制代码
// 向上滑动
UISwipeGestureRecognizer *oneFingerSwipeUp =
  [[[UISwipeGestureRecognizer alloc] initWithTarget:self action:@selector(oneFingerSwipeUp:)] autorelease];
[oneFingerSwipeUp setDirection:UISwipeGestureRecognizerDirectionUp];
[[self view] addGestureRecognizer:oneFingerSwipeUp];
- (void)oneFingerSwipeUp:(UISwipeGestureRecognizer *)recognizer
  CGPoint point = [recognizer locationInView:[self view]];
  NSLog(@"Swipe up - start location: %f,%f", point.x, point.y);
// 向下滑动
UISwipeGestureRecognizer *oneFingerSwipeDown =
  [[[UISwipeGestureRecognizer alloc] initWithTarget:self action:@selector(oneFingerSwipeDown:)] autorelease];
[oneFingerSwipeDown setDirection:UISwipeGestureRecognizerDirectionDown];
[[self view] addGestureRecognizer:oneFingerSwipeDown];
- (void)oneFingerSwipeDown:(UISwipeGestureRecognizer *)recognizer
  NSLog(@"Swipe down - start location: %f,%f", point.x, point.y);
复制代码
旋转手势
复制代码
UIRotationGestureRecognizer *twoFingersRotate =
  [[[UIRotationGestureRecognizer alloc] initWithTarget:self action:@selector(twoFingersRotate:)] autorelease];
[[self view] addGestureRecognizer:twoFingersRotate];
- (void)twoFingersRotate:(UIRotationGestureRecognizer *)recognizer
  // Convert the radian value to show the degree of rotation
  NSLog(@"Rotation in degrees since last change: %f", [recognizer rotation] * (180 / M_PI));
复制代码
向里或向外捏的手势
复制代码
UIPinchGestureRecognizer *twoFingerPinch =
  [[[UIPinchGestureRecognizer alloc] initWithTarget:self action:@selector(twoFingerPinch:)] autorelease];
[[self view] addGestureRecognizer:twoFingerPinch];
- (void)twoFingerPinch:(UIPinchGestureRecognizer *)recognizer
  NSLog(@"Pinch scale: %f", recognizer.scale);
复制代码
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/8597198
