Vertica的这些事(三)—— 谈谈vertica的flex table
数据社 发表于 2022/09/25 02:35:03 2022/09/25
【摘要】 Json格式对于现在所有的软件开发者都不陌生,很多数据格式都用他来存储,我们来看一下vertica是怎么处理json数据的。这就是vertica的flex table! 首先创建一个json文件: {...
首先创建一个json文件:
{"name": "Everest", "type":"mountain", "height":29029, "hike_safety": 34.1}
{"name": "Mt St Helens", "type":"volcano", "height":29029, "hike_safety": 15.4}
{"name": "Denali", "type":"mountain", "height":17000, "hike_safety": 12.2}
{"name": "Kilimanjaro", "type":"mountain", "height":14000 }
{"name": "Mt Washington", "type":"mountain", "hike_safety": 50.6}
然后我们创建一个flex table:
dbadmin=> CREATE FLEX TABLE start_json();
CREATE TABLE
然后把数据copy进去:
dbadmin=> COPY start_json FROM '/home/dbadmin/qcfData/*json*' PARSER fjsonparser();
 Rows Loaded
           5
(1 row)
查询结果:
dbadmin=> select * from start_json();
ERROR 4256:  Only relations and subqueries are allowed in the FROM clause
dbadmin=>  SELECT maptostring(__raw__) FROM start_json;
                                               maptostring
   "height" : "29029",
   "hike_safety" : "34.1",
   "name" : "Everest",
   "type" : "mountain"
   "height" : "29029",
   "hike_safety" : "15.4",
   "name" : "Mt St Helens",
   "type" : "volcano"
   "height" : "17000",
   "hike_safety" : "12.2",
   "name" : "Denali",
   "type" : "mountain"
   "height" : "14000",
   "name" : "Kilimanjaro",
   "type" : "mountain"
   "hike_safety" : "50.6",
   "name" : "Mt Washington",
   "type" : "mountain"
(5 rows)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
发现很好的解析了json文件,并且格式化了文件。
查询json数据:
dbadmin=>  SELECT start_json.type,start_json.name FROM start_json;
   type   |     name
 mountain | Everest
 volcano  | Mt St Helens
 mountain | Denali
 mountain | Kilimanjaro
 mountain | Mt Washington
(5 rows)
此时如果使用 * 查询 会出现乱码:
SELECT * FROM start_json;
需要使用函数 compute_flextable_keys
select compute_flextable_keys(‘start_json’);
然后查询就可以有结果
综上,flex table 对json格式的数据提供了很好的存储于展示。
文章来源: dataclub.blog.csdn.net,作者:数据社,版权归原作者所有,如需转载,请联系作者。
原文链接:dataclub.blog.csdn.net/article/details/51892935
