SpringBoot动态修改日志级别
西魏陶渊明 发表于 2022/09/25 03:02:23 2022/09/25
【摘要】 SpringBoot1.5新特性 目录 安装依赖测试显示日志级别测试修改日志级别 1.在pom中添加依赖 <parent> <groupId>org.spring...
SpringBoot1.5新特性
目录
  1. 安装依赖
  2. 测试显示日志级别
  3. 测试修改日志级别
1.在pom中添加依赖
<parent>
    <artifactId>spring-boot-starter-parent</artifactId>
    <version>1.5.1.RELEASE</version>
    <relativePath/> <!-- lookup parent from repository -->
</parent>
<dependencies>
    <dependency>
        <artifactId>spring-boot-starter-actuator</artifactId>
    </dependency>
    <dependency>
        <artifactId>spring-boot-starter-web</artifactId>
    </dependency>
</dependencies>
2.开始测试
http://localhost:8080/loggers
服务:
s.b.a.e.m.MvcEndpointSecurityInterceptor : Full authentication is required to access actuator endpoints. Consider adding Spring Security or set 'management.security.enabled' to false.
需要手动设置management.security.enabled=false
- 继续测试
服务返回:
levels: [
"OFF",
"ERROR",
"WARN",
"INFO",
"DEBUG",
"TRACE"
loggers: {
ROOT: {
configuredLevel: "INFO",
effectiveLevel: "INFO"
elephant: {
configuredLevel: "DEBUG",
effectiveLevel: "DEBUG"
3.修改日志级别
POST请求
http://localhost:8080/loggers/{elephant}
{}中根据/loggers方法返回的目录级别添加
eg:
我要修改elephant.zybank.rest目录下级别
就使用下面请求方法
http://localhost:8080/loggers/elephant.zybank.rest
请求体中使用json
    "configuredLevel": "DEBUG"
登录服务器
curl -H "Content-Type: application/json" -X POST --data
文章来源: springlearn.blog.csdn.net,作者:西魏陶渊明,版权归原作者所有,如需转载,请联系作者。
原文链接:springlearn.blog.csdn.net/article/details/77584839
