海量数据模拟
西魏陶渊明 发表于 2022/09/25 02:08:09 2022/09/25
【摘要】 作者: 西魏陶渊明 博客: https://blog.springlearn.cn/ (opens new window) 西魏陶渊明 莫笑少年江湖梦,谁不少年梦江湖 # 一、创建表 create table dept( dno int(5) pr...
西魏陶渊明
莫笑少年江湖梦,谁不少年梦江湖
# 一、创建表
  1. create table dept
  2. (
  3. dno int(5) primary key default 0,
  4. dname varchar(20) not null default '',
  5. loc varchar(30) default ''
  6. ) engine =innodb default charset=utf8;
  7. create table emp
  8. (
  9. eid int(5) primary key,
  10. ename varchar(20) not null default '',
  11. job varchar(20) not null default '',
  12. deptno int(5) not null default 0
  13. ) engine =innodb default charset=utf8;
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
# 二、存储函数插入海量数量
存储过程无return,存储函数有。
# 1. 创建存储函数生成id和name
name随机字符串
  1. delimiter $
  2. create function randstring(n int) returns varchar(255)
  3. begin
  4. declare all_str varchar(100) default 'abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ';
  5. declare return_str varchar(255) default '';
  6. declare i int default 0;
  7. while i <n
  8. do
  9. set return_str = concat(return_str,substring(all_str,rand()*52,1));
  10. set i = i+1;
  11. end while;
  12. return return_str;
  13. end $
ERROR 1418 (HY000): This function has none of DETERMINISTIC, NO SQL, or READS SQL DATA in its declaration and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable)
如果开启了慢慢查询日志,在开启存储函数就会冲突,解决办法1就是管理慢日志查询。
解决办法2:
show variables like '%log_bin_trust_function_creators%';
set global log_bin_trust_function_creators=1;
id随机数
  1. delimiter $
  2. create function rand_num()returns int(5)
  3. begin
  4. declare i int default 0;
  5. set i = floor(rand() * 100);
  6. return i;
  7. end $;
1 2 3 4 5 6 7
# 2. 通过存储过程插入海量数据emp
  1. create procedure insert_emp(in eid_start int(10),in data_times int(10))
  2. begin
  3. declare i int default 0;
  4. set autocommit = 0;
  5. repeat
  6. insert into emp values(eid_start + i,randstring(5),'other',rand_num());
  7. set i = i + 1;
  8. until i = data_times
  9. end repeat;
  10. commit;
  11. end $;
# 2. 通过存储过程插入海量数据dept
  1. create procedure insert_dept(in dno_start int(10),in data_times int(10))
  2. begin
  5. repeat
  6. insert into dept values(dno_start+i,randstring(6),randstring(8));
  7. set i = i + 1;
  9. end repeat;
  10. commit;
  11. end$
# 3. 插入海量数据
delimiter ;分割符改回原来
员工表插入80w条数据 call insert_emp(1000,800000); 部门表插入30条数据 call insert_dept(10,30);
  1. mysql> select count(1) from emp;
  2. +----------+
  3. | count(1) |
  4. +----------+
  5. | 800000 |
  6. +----------+
  7. 1 row in set (0.05 sec)
  8. mysql> select count(1) from dept;
  9. +----------+
  10. | count(1) |
  11. +----------+
  12. | 30 |
  13. +----------+
  14. 1 row in set (0.00 sec)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
# 三、利用profiles分析海量数据
# 1. 打开profiles
  1. set profiling = on;
  2. show variables like '%profiling%';
  3. mysql> set profiling = on;
  4. Query OK, 0 rows affected, 1 warning (0.00 sec)
  5. mysql> show variables like '%profiling%';
  6. +------------------------+-------+
  7. | Variable_name | Value |
  8. +------------------------+-------+
  9. | have_profiling | YES |
  10. | profiling | ON |
  11. | profiling_history_size | 15 |
  12. +------------------------+-------+
  13. 3 rows in set (0.00 sec)
# 2. 查询每条耗时
profiles会记录每个sql的耗时
  1. mysql> show profiles;
  2. +----------+------------+-----------------------------------+
  3. | Query_ID | Duration | Query |
  4. +----------+------------+-----------------------------------+
  5. | 1 | 0.00164000 | show variables like '%profiling%' |
  6. | 2 | 0.04513900 | select count(1) from emp |
  7. | 3 | 0.00056200 | select count(1) from dept |
  8. +----------+------------+-----------------------------------+
  9. 3 rows in set, 1 warning (0.00 sec)
1 2 3 4 5 6 7 8 9
但是这样不能精确匹配到耗时在哪里。此时可以使用profile精确来分析sql
# 3. 精确查询耗时
精确 根据上面的Query_ID来精确查找 show profile all for query 2;
  1. +--------------------------------+----------+----------+------------+-------------------+---------------------+--------------+---------------+---------------+-------------------+-------------------+-------------------+-------+-------------------------+----------------------+-------------+
  2. | Status | Duration | CPU_user | CPU_system | Context_voluntary | Context_involuntary | Block_ops_in | Block_ops_out | Messages_sent | Messages_received | Page_faults_major | Page_faults_minor | Swaps | Source_function | Source_file | Source_line |
  3. +--------------------------------+----------+----------+------------+-------------------+---------------------+--------------+---------------+---------------+-------------------+-------------------+-------------------+-------+-------------------------+----------------------+-------------+
  4. | starting | 0.000106 | 0.000094 | 0.000012 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | NULL | NULL | NULL |
  5. | Executing hook on transaction | 0.000008 | 0.000004 | 0.000004 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | launch_hook_trans_begin | rpl_handler.cc | 1106 |
  6. | starting | 0.000013 | 0.000010 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | launch_hook_trans_begin | rpl_handler.cc | 1108 |
  7. | checking permissions | 0.000009 | 0.000007 | 0.000003 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | check_access | sql_authorization.cc | 2202 |
  8. | Opening tables | 0.000047 | 0.000045 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | open_tables | sql_base.cc | 5587 |
  9. | init | 0.000012 | 0.000008 | 0.000003 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | execute | sql_select.cc | 661 |
  10. | System lock | 0.000014 | 0.000012 | 0.000003 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | mysql_lock_tables | lock.cc | 332 |
  11. | optimizing | 0.000010 | 0.000007 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | optimize | sql_optimizer.cc | 213 |
  12. | statistics | 0.000037 | 0.000023 | 0.000014 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 0 | optimize | sql_optimizer.cc | 423 |
  13. | preparing | 0.000025 | 0.000023 | 0.000003 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | optimize | sql_optimizer.cc | 497 |
  14. | executing | 0.000007 | 0.000004 | 0.000003 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | exec | sql_executor.cc | 228 |
  15. | Sending data | 0.044768 | 0.072019 | 0.003191 | 0 | 810 | 0 | 0 | 0 | 0 | 0 | 9 | 0 | exec | sql_executor.cc | 304 |
  16. | end | 0.000018 | 0.000009 | 0.000010 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | execute | sql_select.cc | 714 |
  17. | query end | 0.000006 | 0.000004 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | mysql_execute_command | sql_parse.cc | 4520 |
  18. | waiting for handler commit | 0.000013 | 0.000011 | 0.000001 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | ha_commit_trans | handler.cc | 1533 |
  19. | closing tables | 0.000009 | 0.000008 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | mysql_execute_command | sql_parse.cc | 4566 |
  20. | freeing items | 0.000026 | 0.000012 | 0.000013 | 0 | 0 | 0 | 0 | 1 | 0 | 0 | 0 | 0 | mysql_parse | sql_parse.cc | 5237 |
  21. | cleaning up | 0.000011 | 0.000009 | 0.000002 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | dispatch_command | sql_parse.cc | 2147 |
  22. +--------------------------------+----------+----------+------------+-------------------+---------------------+--------------+---------------+---------------+-------------------+-------------------+-------------------+-------+-------------------------+----------------------+-------------+
  23. 18 rows in set, 1 warning (0.00 sec)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
我们可以看到信息太多了,我们其实只用关系几列的数据就行了。
  1. mysql> show profile cpu,block io for query 2;
  2. +--------------------------------+----------+----------+------------+--------------+---------------+
  3. | Status | Duration | CPU_user | CPU_system | Block_ops_in | Block_ops_out |
  4. +--------------------------------+----------+----------+------------+--------------+---------------+
  5. | starting | 0.000106 | 0.000094 | 0.000012 | 0 | 0 |
  6. | Executing hook on transaction | 0.000008 | 0.000004 | 0.000004 | 0 | 0 |
  7. | starting | 0.000013 | 0.000010 | 0.000002 | 0 | 0 |
  8. | checking permissions | 0.000009 | 0.000007 | 0.000003 | 0 | 0 |
  9. | Opening tables | 0.000047 | 0.000045 | 0.000002 | 0 | 0 |
  10. | init | 0.000012 | 0.000008 | 0.000003 | 0 | 0 |
  11. | System lock | 0.000014 | 0.000012 | 0.000003 | 0 | 0 |
  12. | optimizing | 0.000010 | 0.000007 | 0.000002 | 0 | 0 |
  13. | statistics | 0.000037 | 0.000023 | 0.000014 | 0 | 0 |
  14. | preparing | 0.000025 | 0.000023 | 0.000003 | 0 | 0 |
  15. | executing | 0.000007 | 0.000004 | 0.000003 | 0 | 0 |
  16. | Sending data | 0.044768 | 0.072019 | 0.003191 | 0 | 0 |
  17. | end | 0.000018 | 0.000009 | 0.000010 | 0 | 0 |
  18. | query end | 0.000006 | 0.000004 | 0.000002 | 0 | 0 |
  19. | waiting for handler commit | 0.000013 | 0.000011 | 0.000001 | 0 | 0 |
  20. | closing tables | 0.000009 | 0.000008 | 0.000002 | 0 | 0 |
  21. | freeing items | 0.000026 | 0.000012 | 0.000013 | 0 | 0 |
  22. | cleaning up | 0.000011 | 0.000009 | 0.000002 | 0 | 0 |
  23. +--------------------------------+----------+----------+------------+--------------+---------------+
  24. 18 rows in set, 1 warning (0.01 sec)
  25. mysql>
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
# 4. 全局查询日志
仅仅在调优和开发中使用,生产要关闭
show variables like '%general_log%';
开启全局日志记录并将sql都写入到表中
  1. set global general_log = 1;
  2. set global log_output = 'table';
1 2
  1. mysql> show variables like '%general_log%';
  2. +------------------+------------------------------------+
  3. | Variable_name | Value |
  4. +------------------+------------------------------------+
  5. | general_log | OFF |
  6. | general_log_file | /usr/local/var/mysql/localhost.log |
  7. +------------------+------------------------------------+
  8. 2 rows in set (0.01 sec)
  9. mysql> set global general_log = 1;
  10. Query OK, 0 rows affected (0.00 sec)
  11. mysql> show variables like '%general_log%';
  12. +------------------+------------------------------------+
  13. | Variable_name | Value |
  14. +------------------+------------------------------------+
  15. | general_log | ON |
  16. | general_log_file | /usr/local/var/mysql/localhost.log |
  17. +------------------+------------------------------------+
  18. 2 rows in set (0.01 sec)
开启之后就可以在mysql库中的general_log表中进行查询
select * from mysql.general_log;
将sql设置到文件中
  2. set global log_output = 'file';
  3. set global general_log_file='/Users/liuxin/general.log';
1 2 3
最后求关注,求订阅,谢谢你的阅读!
文章来源: springlearn.blog.csdn.net,作者:西魏陶渊明,版权归原作者所有,如需转载,请联系作者。
原文链接:springlearn.blog.csdn.net/article/details/125857977
