JUnit单测类属性注入
西魏陶渊明 发表于 2022/09/25 01:11:37 2022/09/25
【摘要】 通过前面的阅读我们已经能拿到了所有的容器启动参数。那么我们可以思考下。我们自己的 单测类其实并没有交给容器来管理,那么我们的单测类中的属性都是什么时候注入的呢? 答案就在 TestExecutionListener public interface TestExecutionListener { default vo...
  1. public interface TestExecutionListener {
  2. default void beforeTestClass(TestContext testContext) throws Exception {
  3. }
  4. default void prepareTestInstance(TestContext testContext) throws Exception {
  5. }
  6. default void beforeTestMethod(TestContext testContext) throws Exception {
  7. }
  8. default void beforeTestExecution(TestContext testContext) throws Exception {
  9. }
  10. default void afterTestExecution(TestContext testContext) throws Exception {
  11. }
  12. default void afterTestMethod(TestContext testContext) throws Exception {
  13. }
  14. default void afterTestClass(TestContext testContext) throws Exception {
  15. }
  16. }
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
通过名字我们发现了貌似一个可以进行依赖注入的类。没错就是在这里,在单侧方法执行前。通过
  1. public class DependencyInjectionTestExecutionListener extends AbstractTestExecutionListener {
  2. @Override
  3. public void beforeTestMethod(TestContext testContext) throws Exception {
  4. if (Boolean.TRUE.equals(testContext.getAttribute(REINJECT_DEPENDENCIES_ATTRIBUTE))) {
  5. if (logger.isDebugEnabled()) {
  6. logger.debug("Reinjecting dependencies for test context [" + testContext + "].");
  7. }
  8. injectDependencies(testContext);
  9. }
  10. }
  11. protected void injectDependencies(TestContext testContext) throws Exception {
  12. Object bean = testContext.getTestInstance();
  13. Class<?> clazz = testContext.getTestClass();
  14. AutowireCapableBeanFactory beanFactory = testContext.getApplicationContext().getAutowireCapableBeanFactory();
  15. beanFactory.autowireBeanProperties(bean, AutowireCapableBeanFactory.AUTOWIRE_NO, false);
  16. beanFactory.initializeBean(bean, clazz.getName() + AutowireCapableBeanFactory.ORIGINAL_INSTANCE_SUFFIX);
  17. testContext.removeAttribute(REINJECT_DEPENDENCIES_ATTRIBUTE);
  18. }
  19. }
文章来源: springlearn.blog.csdn.net,作者:西魏陶渊明,版权归原作者所有,如需转载,请联系作者。
原文链接:springlearn.blog.csdn.net/article/details/125858100
