linux U盘/SD卡 热插拔以及自动挂载完整机制
aiot_bigbear 发表于 2022/09/25 00:52:35 2022/09/25
【摘要】 /mnt/nand # mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 50000000Hz, actual 50000000HZ di...
/mnt/nand # mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 50000000Hz, actual 50000000HZ div = 1)
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.68 GiB
 mmcblk0: p1
/mnt/nand # ls -l /dev/m*
crw-rw----    1 root     root        1,   1 Jan  2 23:39 /dev/mem
brw-rw----    1 root     root      179,   0 Jan  2 23:40 /dev/mmcblk0
brw-rw----    1 root     root      179,   1 Jan  2 23:40 /dev/mmcblk0p1
crw-rw----    1 root     root       90,   0 Jan  2 23:39 /dev/mtd0
crw-rw----    1 root     root       90,   1 Jan  2 23:39 /dev/mtd0ro
crw-rw----    1 root     root       90,   2 Jan  2 23:39 /dev/mtd1
crw-rw----    1 root     root       90,   3 Jan  2 23:39 /dev/mtd1ro
crw-rw----    1 root     root       90,   4 Jan  2 23:39 /dev/mtd2
crw-rw----    1 root     root       90,   5 Jan  2 23:39 /dev/mtd2ro
crw-rw----    1 root     root       90,   6 Jan  2 23:39 /dev/mtd3
crw-rw----    1 root     root       90,   7 Jan  2 23:39 /dev/mtd3ro
crw-rw----    1 root     root       90,   8 Jan  2 23:39 /dev/mtd4
crw-rw----    1 root     root       90,   9 Jan  2 23:39 /dev/mtd4ro
brw-rw----    1 root     root       31,   0 Jan  2 23:39 /dev/mtdblock0
brw-rw----    1 root     root       31,   1 Jan  2 23:39 /dev/mtdblock1
brw-rw----    1 root     root       31,   2 Jan  2 23:39 /dev/mtdblock2
brw-rw----    1 root     root       31,   3 Jan  2 23:39 /dev/mtdblock3
brw-rw----    1 root     root       31,   4 Jan  2 23:39 /dev/mtdblock4
/mnt/nand # mmc0: card 1234 removed
·增加script “mdev.conf”(/etc/mdev.conf)
# Block devices
# for usb
sd[a-z][0-9]      0:6     660 */path/automount.sh /tmp/vrecord/videoclips/
# for sd/mmc card
mmcblk[0-9]p[0-9] 0:6     660 */path/automount.sh /tmp/vrecord/videoclips/
·增加script “automount.sh”(/path/automount.sh)
#!/bin/sh
destdir=$1
my_umount()
       if grep -qs "^/dev/$1 " /proc/mounts ; then
               umount "${destdir}";
       fi
       [ -d "${destdir}/$1" ] && rmdir "${destdir}"
my_mount()
       mkdir -p "${destdir}" || exit 1
       usleep(20)
       if [ -e /dev/${1}p1 ]; then
               devname=${1}p1
       else
               devname=${1}
       fi
       if ! mount -t auto -o sync "/dev/$1" "${destdir}"; then
               # failed to mount, clean up mountpoint
               rmdir "${destdir}"
               exit 1
       fi
case "${ACTION}" in
add|"")
        my_umount ${MDEV}
        my_mount ${MDEV}
remove)
       my_umount ${MDEV}
esac
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/123364818
