充电桩设计之电川 充电板的驱动控制程序
aiot_bigbear 发表于 2022/09/25 02:08:38 2022/09/25
【摘要】 文章目录 1.驱动代码 2.头文件定义 1.驱动代码 //#include "sys.h" //#include "usart.h" #include <st...
1.驱动代码
//#include "sys.h"
#include <string.h>
#include "dianchuan.h"
#include "app4g.h"
#include "project_config.h"
#include "cjson_middleware.h"
DianChuan_Frame DianChuanTxFrame = {0};
DianChuan_Frame DianChuanRxFrame = {0};
SOP	    LEN	    CMD	    SESSION_ID	    DATA	SUM
1Byte   1Byte   1Byte   6Bytes          n       1Byte
void DianChuan_ConstructTxCmdFrame(DianChuan_Frame *frame,u8 cmd,u8 *session_id,u8 *data,u8 datalen)
    u8 i =0;
    if(frame == NULL)
        return;
    else
        memset(frame,0,sizeof(DianChuan_Frame));
    frame->sop = DIANCHUAN_TX_SOP;
    frame->len = 0;
    frame->cmd = cmd;
    frame->len++;
    frame->sum = cmd;
    if(s
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
文章来源: blog.csdn.net,作者:悟空胆好小,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xushx_bigbear/article/details/122739118
评论(0
