Sprint Boot 打Jar包并启动
清雨小竹 发表于 2022/09/25 00:48:29 2022/09/25
【摘要】 pom.xml <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4....
pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <groupId>com.yunfeng</groupId>
  <artifactId>YFEidApi</artifactId>
  <version>1</version>
  <packaging>jar</packaging>
  <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>0.5.0.M7</version>
  </parent>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <groupId>org.thymeleaf</groupId>
            <artifactId>thymeleaf-spring3</artifactId>
        </dependency>
        <dependency>
        	<groupId>org.apache.tomcat</groupId>
        	<artifactId>tomcat-servlet-api</artifactId>
        	<version>9.0.0.M22</version>
        	<scope>provided</scope>
        </dependency>
    </dependencies>
    <properties>
        <start-class>com.eid.controller.App</start-class>
    </properties>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
            <artifactId>maven-compiler-plugin</artifactId>
            <configuration>
              <source>1.8</source>
              <target>1.8</target>
            </configuration>
          </plugin>
        </plugins>
    </build>
    <repositories>
        <repository>
            <id>spring-milestone</id>
            <url>http://repo.spring.io/libs-milestone</url>
            <snapshots>
                <enabled>false</enabled>
            </snapshots>
        </repository>
    </repositories>
    <pluginRepositories>
        <pluginRepository>
            <snapshots>
            </snapshots>
        </pluginRepository>
    </pluginRepositories>
</project>
package com.eid.controller;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.EnableAutoConfiguration;
import org.springframework.context.annotation.ComponentScan;
@ComponentScan
@EnableAutoConfiguration
public class App {
    	System.out.println("Start App Class....");
        SpringApplication.run(App.class, args);
import org.springframework.web.bind.annotation.RequestMapping;
@RestController
public class TestController {
    @RequestMapping("/t1")
    public String  showPerson() {
        return "test";
App.java和TestController.java放到 package里:com.eid.controller。名字要用controller
启动 Java -jar xxx.jar
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/77008540
