Sql
清雨小竹 发表于 2022/09/25 00:10:31 2022/09/25
【摘要】 using System.Data.OleDb;using MySql.Data.MySqlClient;using System.Data;using System.Data.SqlClient;    void LinkMySql()     &nb...
using System.Data;
 void LinkMySql()
            string str = "Server=localhost;Database=test;Uid=root;Pwd=zz;";
            MySqlConnection con = new MySqlConnection(str);
            try
                con.Open();
                MySqlCommand cmd = new MySqlCommand();
                cmd.Connection = con;
                cmd.CommandText = "ProcTest1";
                cmd.CommandType = CommandType.StoredProcedure;
                MySqlDataReader dr = cmd.ExecuteReader();
                while(dr.Read())
                    Response.Write(dr["c1"].ToString()+"<br>");
                Response.Write("ok");
                con.Close();
            catch(Exception ee)
                Response.Write(ee.ToString());
            finally
                con.Close();
        void LinkSqlServer()
            string str = "server='(local)';databse='mytable';uid='sa';pwd='sa'";
            SqlConnection con = new SqlConnection(str);
            try
                con.Open();
                SqlDataAdapter da = new SqlDataAdapter("select * from t1",con);
                SqlCommand cmd = new SqlCommand("insert into t1", con);
                con.Close();
            catch(Exception ee)
        void LinkAccess()
            string str = "provider=Microsoft.Jet.OLEDB.4.0 ;Data Source=" + Server.MapPath("access.mdb") + "";
            OleDbConnection con = new OleDbConnection(str);
            try
                con.Open();
                con.Close();
            catch (Exception ee)
                Response.Write("<script>alert('连接失败');</script>");
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/8265422
