html格式化显示
清雨小竹 发表于 2022/09/25 00:34:24 2022/09/25
【摘要】 - (NSString *)flattenHTML:(NSString *)html trimWhiteSpace:(BOOL)trim { NSScanner *theScanner = [NSScanner scannerWithString:html]; NSString *text = nil; whi...
  1. - (NSString *)flattenHTML:(NSString *)html trimWhiteSpace:(BOOL)trim {
  2. NSScanner *theScanner = [NSScanner scannerWithString:html];
  3. NSString *text = nil;
  4. while ([theScanner isAtEnd] == NO) {
  5. // find start of tag
  6. [theScanner scanUpToString:@"<" intoString:NULL] ;
  7. // find end of tag
  8. [theScanner scanUpToString:@">" intoString:&text] ;
  9. // replace the found tag with a space
  10. //(you can filter multi-spaces out later if you wish)
  11. html = [html stringByReplacingOccurrencesOfString:
  12. [ NSString stringWithFormat:@"%@>", text]
  13. withString:@""];
  14. }
  15. html = [html stringByReplacingOccurrencesOfString:@" " withString:@""];
  16. // trim off whitespace
  17. return trim ? [html stringByTrimmingCharactersInSet:[NSCharacterSet whitespaceAndNewlineCharacterSet]] : html;
  18. }
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/26686551
