c#
清雨小竹 发表于 2022/09/25 01:56:26 2022/09/25
【摘要】 1.MySql连接     <connectionStrings>   <add name="mysql" connectionString="server=localhost;port=3306;user id=zzzili;password=zzzili123;database=z...
1.MySql连接
  <connectionStrings>
  <add name="mysql" connectionString="server=localhost;port=3306;user id=zzzili;password=zzzili123;database=zzzili;CharSet=gb2312;" providerName="MySql.Data.MySqlClient"/>
  </connectionStrings>
 private string mysqlYunfeng = System.Configuration.ConfigurationManager.ConnectionStrings["mysql"].ConnectionString;
2.数据操作
         using (MySqlDataReader dr = MySqlHelper.ExecuteReader(mysqlYunfeng, sql))
             if (dr.HasRows == true)
                 while (dr.Read())
                     if (dr[0].ToString() == "Logo")
                         node.LogoVersion = dr[1].ToString();
                     else if (dr[0].ToString() == "City")
                         node.CityVersion = dr[1].ToString();
MySqlParameter[] paras = new MySqlParameter[4];
           paras[0] = new MySqlParameter("@stuNum",stuNum);
           paras[1] = new MySqlParameter("@answer",answer);
           paras[2] = new MySqlParameter("@score",score);
           paras[3] = new MySqlParameter("@exid",ex_id);
3.Json序列化
        //JavaScriptSerializer类在System.Web.Extensions.dll中,注意添加这个引用
        JavaScriptSerializer serializer = new JavaScriptSerializer();
        //JSON序列化
        string result = serializer.Serialize(node);
4.Request.QueryString[""].ToString();
5.输出调试信息
System.Diagnostics.Debug.WriteLine(returnStr);
6.sql中的判断
select  case when a>b  then a
              when b>c then b
        esle c   end
from table_name
where ...
7.web Table写入Excel
protected void Button1_Click(object sender, EventArgs e)
            BndTableList(this.txtTime.Text, null);
            StringBuilder tstr = new StringBuilder();
            foreach (TableRow row in Table1.Rows)
                foreach (TableCell cell in row.Cells)
                    tstr.AppendFormat("{0}	",cell.Text);
                tstr.Append("\r\n");
            WriteFile(tstr.ToString());
        private void WriteFile(string str)
            System.IO.File.WriteAllText("C:\\upload\\aaa.xls", str, Encoding.UTF8);
8.方法不在Swagger文档中显示
[HttpPost]
[ApiExplorerSettings(IgnoreApi = true)]
public void Test(){
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/19191483
