Metronic Angular
清雨小竹 发表于 2022/09/25 00:37:07 2022/09/25
【摘要】 1.手动强制刷新 $scope.$apply(); 2.select的使用 <select class="form-control form-filter input-sm" ng-model="row.specsId" ng-options="item.id as item.specsName for item in sh...
1.手动强制刷新
$scope.$apply();
2.select的使用
  1. <select class="form-control form-filter input-sm" ng-model="row.specsId"
  2. ng-options="item.id as item.specsName for item in shopSpecsList">
  3. <option value="">请选择...</option>
  4. </select>
 select2的使用
  1. '../assets/global/plugins/select2/css/select2.min.css',
  2. '../assets/global/plugins/select2/css/select2-bootstrap.min.css',
  3. '../assets/global/plugins/select2/js/select2.full.min.js',
  4. '../assets/pages/scripts/components-select2.min.js',
  1. <select class="bs-select form-control select2" data-placeholder="请选择..." ng-model="detail.role"
  2. ng-options="item.id as item.name for item in rolelist">
  3. </select>
  4. <script>
  5. ComponentsSelect2.init(); // init todo page
  6. </script>
3.radio
  1. <div class="col-md-9">
  2. <div class="mt-radio-inline">
  3. <label class="mt-radio mt-radio-outline">
  4. <input type="radio" name="priceDiscountEnable" ng-model="detail.priceDiscountEnable" value="true" ng-checked="detail.priceDiscountEnable==true"> 允许
  5. <span></span>
  6. </label>
  7. <label class="mt-radio mt-radio-outline">
  8. <input type="radio" name="priceDiscountEnable" ng-model="detail.priceDiscountEnable" value="false" ng-checked="detail.priceDiscountEnable==false"> 不允许
  9. <span></span>
  10. </label>
  11. </div>
  12. </div>
4.checkbox
  1. <div class="form-group">
  2. <label class="control-label col-md-3">是否热门</label>
  3. <div class="col-md-9">
  4. <input type="checkbox" class="make-switch" data-size="small" id="isHot" checked>
  5. </div>
  6. </div>
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/109802007
