IOS文件操作
清雨小竹 发表于 2022/09/25 01:30:17 2022/09/25
【摘要】 1.从cache文件夹拷贝到document文件夹 NSString *sqlFile = @"test.zip"; NSArray *cachePath= NSSearchPathForDirectoriesInDomains(NSCachesDirectory, NSUserDomainMask, YES); ...
  1. NSString *sqlFile = @"test.zip";
  2. NSArray *cachePath= NSSearchPathForDirectoriesInDomains(NSCachesDirectory, NSUserDomainMask, YES);
  3. NSString *cacheDir = [cachePath objectAtIndex:0];
  4. NSString *databasePath = [cacheDir stringByAppendingPathComponent:sqlFile];
  5. NSLog(databasePath);
  6. NSFileManager *fileManager = [NSFileManager defaultManager];
  7. // Copy the database sql file from the resourcepath to the documentpath
  8. if ([fileManager fileExistsAtPath:databasePath])
  9. {
  10. //NSString *databasePathFromApp = [[[NSBundle mainBundle] resourcePath] stringByAppendingPathComponent:sqlFile];
  11. NSArray *paths = NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES);
  12. NSString *documentpath = ([paths count] > 0) ? [paths objectAtIndex:0] : nil;
  13. NSString* databasePathFromApp = [documentpath stringByAppendingString:@"/test.zip"] ;
  14. NSLog(databasePathFromApp);
  15. NSError *error;
  16. [fileManager copyItemAtPath:databasePath toPath:databasePathFromApp error:&error];
  17. // if (error != nil) {
  18. // NSLog(@"[Database:Error] %@", error);
  19. // }
  20. }
2.从document文件夹拷贝到cache文件夹
  1. NSString *sqlFile = @"qxd.db";
  5. NSFileManager *fileManager = [NSFileManager defaultManager];
  6. // Copy the database sql file from the resourcepath to the documentpath
  7. if (![fileManager fileExistsAtPath:databasePath]) {
  8. NSString *databasePathFromApp = [[[NSBundle mainBundle] resourcePath] stringByAppendingPathComponent:sqlFile];
  9. NSError *error;
  10. [fileManager copyItemAtPath:databasePathFromApp toPath:databasePath error:&error];
  11. // if (error != nil) {
  12. // NSLog(@"[Database:Error] %@", error);
  13. // }
  14. }
文章来源: zzzili.blog.csdn.net,作者:清雨小竹,版权归原作者所有,如需转载,请联系作者。
原文链接:zzzili.blog.csdn.net/article/details/8424125
