mindspore两日集训营202209-金箍棒应用
irrational 发表于 2022/09/25 00:37:01 2022/09/25
【摘要】 pip install https://ms-release.obs.cn-north-4.myhuaweicloud.com/1.8.0/GoldenStick/any/mindspore_gs-0.1...
pip install https://ms-release.obs.cn-north-4.myhuaweicloud.com/1.8.0/GoldenStick/any/mindspore_gs-0.1.0-py3-none-any.whl --trusted-host ms-release.obs.cn-north-4.myhuaweicloud.com -i https://pypi.tuna.tsinghua.edu.cn/simple
cd ./golden_stick/scripts/
bash run_standalone_train_gpu.sh ../quantization/simqat/ ../quantization/simqat/lenet_mnist_config.yaml ../../data/
出现了这样一句报错
run_standalone_train_gpu.sh: line 76: ulimit: max user processes: cannot modify limit: Operation not permitted
正确的做法是,在root下执行命令,
ulimit -u unlimited
然后把sh文件里同样的这句话注释掉
然后就跑起来了,很快的
获得的ckpt比一般的要小
打印网络结构非常简单,直接print(network)
LeNet5Opt<
  (_handler): LeNet5<
    (conv1): Conv2d<input_channels=1, output_channels=6, kernel_size=(5, 5), stride=(1, 1), pad_mode=valid, padding=0, dilation=(1, 1), group=1, has_bias=False, weight_init=normal, bias_init=zeros, format=NCHW>
    (conv2): Conv2d<input_channels=6, output_channels=16, kernel_size=(5, 5), stride=(1, 1), pad_mode=valid, padding=0, dilation=(1, 1), group=1, has_bias=False, weight_init=normal, bias_init=zeros, format=NCHW>
    (relu): ReLU<>
    (max_pool2d): MaxPool2d<kernel_size=2, stride=2, pad_mode=VALID>
    (flatten): Flatten<>
    (fc1): Dense<input_channels=400, output_channels=120, has_bias=True>
    (fc2): Dense<input_channels=120, output_channels=84, has_bias=True>
    (fc3): Dense<input_channels=84, output_channels=10, has_bias=True>
  (DenseQuant): QuantizeWrapperCell<
    (_handler): DenseQuant<
      in_channels=84, out_channels=10, weight=Parameter (name=DenseQuant._handler.weight, shape=(10, 84), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant._handler.bias, shape=(10,), dtype=Float32, requires_grad=True)
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 10), quant_delay=900>
    (_input_quantizer): SimulatedFakeQuantizerPerLayer<bit_num=8, symmetric=False, narrow_range=False, ema=False(0.999), per_channel=False, quant_delay=900>
    (_output_quantizer): SimulatedFakeQuantizerPerLayer<bit_num=8, symmetric=False, narrow_range=False, ema=False(0.999), per_channel=False, quant_delay=900>
  (Conv2dBnFoldQuant): QuantizeWrapperCell<
    (_handler): Conv2dBnFoldQuant<
      in_channels=1, out_channels=6, kernel_size=(5, 5), stride=(1, 1), pad_mode=valid, padding=0, dilation=(1, 1), group=1, fake=True, freeze_bn=10000000, momentum=0.997
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 6), quant_delay=900>
      (batchnorm_fold): BatchNormFoldCell<>
  (Conv2dBnFoldQuant_1): QuantizeWrapperCell<
      in_channels=6, out_channels=16, kernel_size=(5, 5), stride=(1, 1), pad_mode=valid, padding=0, dilation=(1, 1), group=1, fake=True, freeze_bn=10000000, momentum=0.997
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 16), quant_delay=900>
  (DenseQuant_1): QuantizeWrapperCell<
      in_channels=400, out_channels=120, weight=Parameter (name=DenseQuant_1._handler.weight, shape=(120, 400), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant_1._handler.bias, shape=(120,), dtype=Float32, requires_grad=True), activation=ReLU<>
      (activation): ReLU<>
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 120), quant_delay=900>
  (DenseQuant_2): QuantizeWrapperCell<
      in_channels=120, out_channels=84, weight=Parameter (name=DenseQuant_2._handler.weight, shape=(84, 120), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant_2._handler.bias, shape=(84,), dtype=Float32, requires_grad=True), activation=ReLU<>
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 84), quant_delay=900>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
这样就可以了。
然后评估
bash run_eval_gpu.sh ../quantization/simqat/ ../quantization/simqat/lenet_mnist_config.yaml ../../data/ ./train/ckpt/checkpoint_lenet-10_2187.ckpt
精度非常高的。
第一个作业完成了。
然后是第二个作业。
alexnet
先把全精度跑通
bash run_standalone_train_gpu.sh cifar10 ~/haahsummer/pro57msgs/models/official/cv/alexnet/data/cifar-10-batches-bin ckpt
30轮有点太久,跑了4~5个小时。一个模型427.9M
然后是测试
bash run_standalone_eval_gpu.sh cifar10 ~/haahsummer/pro57msgs/models/official/cv/alexnet/data/cifar-10-batches-bin ckpt/checkpoint_alexnet-30_1875.ckpt 0
网络结构就打印出来了。
最后acc只有0.1,不知道原因是什么,在学校里有个课题我们也尝试用了女alexnet,效果也不是很好,那我们恐怕需要微调参数了,而且仔细看训练的loss,波动后也没有明显的下降。
要使用金箍棒
写一个algorithm.py
train和eval分别导入
eval中添加
现在看来像alexnet这种比较大的网络,还是不要在本地比较好。
上面是全精度训练的结果。fp32训练后精度为0.88
我们添加量化训练的eval和train逻辑,把对应部分量化。
fp32训练结果如图,15s一个epoch在这里插入图片描述
loss有序下降,并且训练速度比本地快得多。
量化训练用时明显比全精度训练慢了很多,一百多s一个epoch
量化测试采用刚刚生成的ckpt,并在测试脚本里添加打印量化后的网络的逻辑。
AlexNetOpt<
  (_handler): AlexNet<
    (conv1): Conv2d<input_channels=3, output_channels=64, kernel_size=(11, 11), stride=(4, 4), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True, weight_init=normal, bias_init=zeros, format=NCHW>
    (conv2): Conv2d<input_channels=64, output_channels=128, kernel_size=(5, 5), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True, weight_init=normal, bias_init=zeros, format=NCHW>
    (conv3): Conv2d<input_channels=128, output_channels=192, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True, weight_init=normal, bias_init=zeros, format=NCHW>
    (conv4): Conv2d<input_channels=192, output_channels=256, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True, weight_init=normal, bias_init=zeros, format=NCHW>
    (conv5): Conv2d<input_channels=256, output_channels=256, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True, weight_init=normal, bias_init=zeros, format=NCHW>
    (max_pool2d): MaxPool2d<kernel_size=3, stride=2, pad_mode=VALID>
    (fc1): Dense<input_channels=9216, output_channels=4096, has_bias=True>
    (fc2): Dense<input_channels=4096, output_channels=4096, has_bias=True>
    (fc3): Dense<input_channels=4096, output_channels=10, has_bias=True>
    (dropout): Dropout<keep_prob=1.0>
  (Conv2dQuant): QuantizeWrapperCell<
    (_handler): Conv2dQuant<
      in_channels=3, out_channels=64, kernel_size=(11, 11), stride=(4, 4), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 64), quant_delay=900>
  (Conv2dQuant_1): QuantizeWrapperCell<
      in_channels=64, out_channels=128, kernel_size=(5, 5), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 128), quant_delay=900>
  (Conv2dQuant_2): QuantizeWrapperCell<
      in_channels=128, out_channels=192, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 192), quant_delay=900>
  (Conv2dQuant_3): QuantizeWrapperCell<
      in_channels=192, out_channels=256, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 256), quant_delay=900>
  (Conv2dQuant_4): QuantizeWrapperCell<
      in_channels=256, out_channels=256, kernel_size=(3, 3), stride=(1, 1), pad_mode=same, padding=0, dilation=(1, 1), group=1, has_bias=True
      in_channels=9216, out_channels=4096, weight=Parameter (name=DenseQuant._handler.weight, shape=(4096, 9216), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant._handler.bias, shape=(4096,), dtype=Float32, requires_grad=True)
      (fake_quant_weight): SimulatedFakeQuantizerPerChannel<bit_num=8, symmetric=True, narrow_range=False, ema=False(0.999), per_channel=True(0, 4096), quant_delay=900>
      in_channels=4096, out_channels=4096, weight=Parameter (name=DenseQuant_1._handler.weight, shape=(4096, 4096), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant_1._handler.bias, shape=(4096,), dtype=Float32, requires_grad=True)
      in_channels=4096, out_channels=10, weight=Parameter (name=DenseQuant_2._handler.weight, shape=(10, 4096), dtype=Float32, requires_grad=True), has_bias=True, bias=Parameter (name=DenseQuant_2._handler.bias, shape=(10,), dtype=Float32, requires_grad=True)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
打印网络结构
训练后的精度为0.87几乎没有变化
ok顺利完成。
文章来源: blog.csdn.net,作者:irrationality,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_54227557/article/details/126800367
