K8S 压测工具推荐
隔壁老汪 发表于 2022/09/24 23:33:16 2022/09/24
【摘要】 https://github.com/kubeflow/kubebench https://github.com/kubernetes/kubernetes/tree/master/cluster/kubemark kubebench The goal of Kubebench is to make it easy t...
kubebench
The goal of Kubebench is to make it easy to run benchmark jobs on Kubeflow with various system and model settings. Kubebench enables benchmarks by leveraging Kubeflow's capability of managing TFJobs, as well as Argo based workflows.
Quick Start
NOTE: the quick start guide serves as a demo that helps you quickly go through a Kubebench Job. The components installed may not be suitable for production use. Please ref
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/126668433
