用DeepAR做股票价格预测
darkpard 发表于 2022/09/12 09:39:04 2022/09/12
【摘要】 DeepAR是亚马逊提出的一种时间序列预测算法,通过在大量时间序列上训练自回归递归网络模型,从相关的时间序列中有效学习全局模型,进而对时间序列进行预测。它能应对季节性、周期性等问题。本文探索下该模型在股票预测中的应用。安装包!pip install baostock==0.8.8!pip install mxnet==1.7.0.post2!pip install gluonts==0.9....
  1. 安装包
!pip install gluonts==0.9.5
!pip install matplotlib==3.3.1
2. 导入包
    import baostock as bs
    from gluonts.dataset import common
    from gluonts.model import deepar
    from gluonts.mx.trainer import Trainer
    from gluonts.evaluation.backtest import make_evaluation_predictions
    from tqdm.autonotebook import tqdm
    import os
    3. 数据准备
    3.1. 变量初始化
      stock_list = ['sh.603198', 'sh.600809', 'sh.600519'] #以三个白酒股为例
      train_list = []
      test_list = []
      prediction_length = 20 #预测长度
      3.2. 数据下载函数
        def get_stockdata(code):
            rs = bs.query_history_k_data_plus(code,
                                              'date,close,volume,turn',
                                              start_date='2020-09-01',
                                              end_date='2022-09-01',
                                              frequency='d', adjustflag='2')
            return rs.get_data()
        3.3. 连上baostock
          lg = bs.login()
          3.4. 数据下载与划分
            for stock_id in stock_list:
                df = get_stockdata(stock_id)
                train_dic = {'start':df.date[0],
                             'target':df.close,
                             'cat':int(stock_id.split('.')[1]),
                             'dynamic_feat':[df.volume, df.turn]}
                    test_dic = {'start':df.date[0],
                            'target':df.close[:-prediction_length],
                            'dynamic_feat':[df.volume[:-prediction_length], df.turn[:-prediction_length]]}
                train_list.append(train_dic)
                test_list.append(test_dic)
            3.5. 数据封装
              train_data = common.ListDataset(train_list, freq='1d')
              test_data = common.ListDataset(test_list, freq='1d')
              4. 建模与训练
              4.1. 构建训练器
                estimator = deepar.DeepAREstimator(
                    prediction_length=prediction_length,
                    context_length=60,
                    freq='1d',
                    num_layers=2,
                    num_cells=64,
                    trainer=Trainer(epochs=20,
                                    learning_rate=1e-2,
                                    num_batches_per_epoch=32))
                4.2. 模型训练
                  predictor = estimator.train(train_data)
                  5. 股价预测
                    forecast_it, ts_it = make_evaluation_predictions(
                        dataset=test_data,
                        predictor=predictor,
                        num_samples=100)
                    6. 模型评估与可视
                    6.1. 数据封装
                      tss = list(tqdm(ts_it, total=len(test_data)))
                      forecasts = list(tqdm(forecast_it, total=len(test_data)))
                      6.2. 新建存放文件夹
                        plot_log_path = './plots/'
                        directory = os.path.dirname(plot_log_path)
                        if not os.path.exists(directory):
                            os.makedirs(directory)
                        6.3. 结果可视化
                          def plot_prob_forecasts(ts_entry, forecast_entry, path, sample_id):
                              plot_length = 150
                              prediction_intervals = (50, 80)
                              legend = ['observations', 'median prediction'] + [f'{k}% prediction interval' for k in prediction_intervals][::-1]
                              _, ax = plt.subplots(1, 1, figsize=(10, 7))
                              ts_entry[-plot_length:].plot(ax=ax)
                              forecast_entry.plot(prediction_intervals=prediction_intervals, color='g')
                              ax.axvline(ts_entry.index[-prediction_length], color='r')
                              plt.legend(legend, loc='upper left')
                              plt.savefig('{}forecast_{}.png'.format(path, sample_id))
                              plt.close()
                          6.4. 将结果存入刚新建的文件夹
                            for i in tqdm(range(len(stock_list))):
                                ts_entry = tss[i]
                                forecast_entry = forecasts[i]
                                plot_prob_forecasts(ts_entry, forecast_entry, plot_log_path, i)
                            6.5. 预测结果
                            在刚刚新建的文件夹下可以看到
                            三个股票的预测结果如下:
                            可以看到,只有第三个票的结果勉强可以接受,想要将这种预测方法运用于实战也还需要深入地研究。
