Unity 如何实现游戏中技能的扇形攻击范围
CoderZ1010 发表于 2022/09/06 18:38:51 2022/09/06
【摘要】 假设人物A向正前方释放一个技能,攻击范围为一个扇形,如何判断人物B是否在该范围内受到攻击。        1. 向量A的正前方forward 与 A指向B的向量direction 的角度offsetAngle小于扇形角度的1/2        2. 向量direction的模长magnitude,即A到B的距离小于半径        满足上面这两个条件即可判断B在扇形区域内,涉及的运算:点乘...
        满足上面这两个条件即可判断B在扇形区域内,涉及的运算:点乘积、反余弦
/// <summary>
/// 判断target是否在扇形区域内
/// </summary>
/// <param name="sectorAngle">扇形角度</param>
/// <param name="sectorRadius">扇形半径</param>
/// <param name="attacker">攻击者的transform信息</param>
/// <param name="target">目标</param>
/// <returns>目标target在扇形区域内返回true 否则返回false</returns>
public bool IsInRange(float sectorAngle, float sectorRadius, Transform attacker, Transform target)
    //攻击者位置指向目标位置的向量
    Vector3 direction = target.position - attacker.position;
    //点乘积结果
    float dot = Vector3.Dot(direction.normalized, transform.forward);
    //反余弦计算角度
    float offsetAngle = Mathf.Acos(dot) * Mathf.Rad2Deg; //弧度转度
    return offsetAngle < sectorAngle * .5f && direction.magnitude < sectorRadius;
扇形范围由扇形的角度和半径构成,定义变量:
//扇形角度
[SerializeField] private float angle = 80f;
//扇形半径
[SerializeField] private float radius = 3.5f;
//物体B
[SerializeField] private Transform b;
 定义bool类型变量flag,用来记录判断结果:
private bool flag;
private void Update()
    flag = IsInRange(angle, radius, transform, b);
完整测试脚本:
using UnityEngine;
using UnityEditor;
public class Foo : MonoBehaviour
    //扇形角度
    //扇形半径
    //物体B
    private bool flag;
    /// <summary>
    /// </summary>
        //攻击者位置指向目标位置的向量
        //点乘积结果
        //反余弦计算角度
    private void OnDrawGizmos()
        Handles.color = flag ? Color.cyan : Color.red;
        float x = radius * Mathf.Sin(angle / 2f * Mathf.Deg2Rad);
        float y = Mathf.Sqrt(Mathf.Pow(radius, 2f) - Mathf.Pow(x, 2f));
        Vector3 a = new Vector3(transform.position.x - x, 0f, transform.position.z + y);
        Vector3 b = new Vector3(transform.position.x + x, 0f, transform.position.z + y);
        Handles.DrawLine(transform.position, a);
        Handles.DrawLine(transform.position, b);
        float half = angle / 2;
        for (int i = 0; i < half; i++)
            x = radius * Mathf.Sin((half - i) * Mathf.Deg2Rad);
            x = radius * Mathf.Sin((half - i - 1) * Mathf.Deg2Rad);
            b = new Vector3(transform.position.x - x, 0f, transform.position.z + y);
            Handles.DrawLine(a, b);
            a = new Vector3(transform.position.x + x, 0f, transform.position.z + y);
