大数据ClickHouse(十八):Spark 写入 ClickHouse API
Lansonli 发表于 2022/09/03 00:25:24 2022/09/03
【摘要】 ​Spark 写入 ClickHouse APISparkCore写入ClickHouse,可以直接采用写入方式。下面案例是使用SparkSQL将结果存入ClickHouse对应的表中。在ClickHouse中需要预先创建好对应的结果表。一、导入依赖<!-- 连接ClickHouse需要驱动包--><dependency> <groupId>ru.yandex.clickhouse</gr...
一、导入依赖
<dependency>
  <groupId>ru.yandex.clickhouse</groupId>
  <artifactId>clickhouse-jdbc</artifactId>
  <version>0.2.4</version>
  <!-- 去除与Spark 冲突的包 -->
  <exclusions>
    <exclusion>
        <groupId>com.fasterxml.jackson.core</groupId>
        <artifactId>jackson-databind</artifactId>
    </exclusion>
    <exclusion>
        <groupId>net.jpountz.lz4</groupId>
        <artifactId>lz4</artifactId>
    </exclusion>
</exclusions>
</dependency>
<!-- Spark-core -->
<dependency>
  <groupId>org.apache.spark</groupId>
  <artifactId>spark-core_2.11</artifactId>
  <version>2.3.1</version>
</dependency>
<!-- SparkSQL -->
<dependency>
  <artifactId>spark-sql_2.11</artifactId>
</dependency>
<!-- SparkSQL  ON  Hive-->
<dependency>
  <artifactId>spark-hive_2.11</artifactId>
</dependency>
二、代码编写
val session: SparkSession = SparkSession.builder().master("local").appName("test").getOrCreate()
val jsonList = List[String](
  "{\"id\":1,\"name\":\"张三\",\"age\":18}",
  "{\"id\":2,\"name\":\"李四\",\"age\":19}",
  "{\"id\":3,\"name\":\"王五\",\"age\":20}"
//将jsonList数据转换成DataSet
import session.implicits._
val ds: Dataset[String] = jsonList.toDS()
val df: DataFrame = session.read.json(ds)
df.show()
//将结果写往ClickHouse
val url = "jdbc:clickhouse://node1:8123/default"
val table = "test"
val properties = new Properties()
properties.put("driver", "ru.yandex.clickhouse.ClickHouseDriver")
properties.put("user", "default")
properties.put("password", "")
properties.put("socket_timeout", "300000")
df.write.mode(SaveMode.Append).option(JDBCOptions.JDBC_BATCH_INSERT_SIZE, 100000).jdbc(url, table, properties)
